#348945 - 07/11/2011 00:11
Ongoing sync fail problem with large hdd
Loc: NC
Everytime I put new music on my empeg the sync fails when it's rebuilding the database. Actually what happens is the rebuild takes longer on the empeg than emplode allows for and when emplode reaches the end of the rebuilding databases progress bar it crashes and the sync fails. Then I have to go through the pain in the ass serial rebuild. This wouldn't be so bad except for my desktop doesn't have a serial or even a parallel port so I have to break out my old pc, hook it up and rebuild....PAIN!!! What the hell is causing these annoying problems!? Please help!!
I have a MKIIA with a 250gb WD hdd and using the developers version.
Edited by deadsled13 (07/11/2011 00:14)
Check out The Tremors the best hillbilly rock n roll you ever set your corn fuel soaked ears to. MK2a 250gig #030102295
#348947 - 07/11/2011 01:22
Re: Ongoing sync fail problem with large hdd
[Re: deadsled13]
Doesn't solve your problem, but you can get a USB->Serial adapter for like $3. Seems like it would be less trouble than dragging out the old computer.
#348958 - 07/11/2011 08:45
[Re: JBjorgen]
Perhaps your music db is getting too large now and causing timeouts. You can always try using mp3tofid https://github.com/empeg/mp3tofid to add tunes to your player. Or you might have better luck with the timeout issue if you try using Jemplode. I'm not sure, but I think I remember reading or being told that version 3 of the empeg software builds doesn't always sync with emplode and that certain 3rd party apps that automatically load during boot and that are running while trying to sync might interfere with the process so if you've added any apps around the time this problem started occurring, it's best to exit those apps or stop them from auto-loading in the boot sequence. That's my 2 cents - I hope it helps.
#349004 - 07/11/2011 22:53
[Re: Hollywood Justin]
Loc: NC
Not familiar with mp3 to fid, how do I use it? I do have a large db of files, probably 35-45,000 files maybe more, maybe less. Do I need to do anything special to the hdd before hand? Should I rebuild it before I use the mp3 to fid?
thanks
#349013 - 08/11/2011 02:24
[Re: deadsled13]
Loc: NC
Here's my hyperterminal output if it helps....
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009 Processor: Intel StrongARM-1100 revision 9 Checking for extra DRAM: c1000000: wrote ffffffff, read e28cc001 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 30102295) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x99380 Tuner: loopback=0, ID=-1 show_message("Hijack v508 by Mark Lord") empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004e00). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0x8080 ide_data_test: wrote 0xffff read 0x8080 ide_data_test: wrote 0xaaaa read 0x8080 ide_data_test: wrote 0x5555 read 0x8080 ide_data_test: wrote 0x0000 read 0xefff ide_data_test: wrote 0xffff read 0xefff ide_data_test: wrote 0xaaaa read 0xefff ide_data_test: wrote 0x5555 read 0xefff hda: WDC WD2500BEVE-00WZT0, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD2500BEVE-00WZT0, 238475MB w/8192kB Cache, CHS=30401/255/63, LBA48 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:f 7 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press Starting player Timezone: EST Restored terminal settings Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Abnormal player termination Player received SIGINT, user interruption Switching to shell-player loop Starting bash. Shell exit Starting playTimezone: EST er Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" kftpd: listening on port 21 khttpd: listening on port 80 player.cpp : 385:empeg-car 2.01 2004/07/06. ! tags.cpp : 61:Failed to open tags (0xc0041002). Restored terminal settings Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Abnormal player termination Player received SIGINT, user interruption Switching to shell-player loop Starting bash. empeg:/empeg/bin#
#349014 - 08/11/2011 02:32
[Re: deadsled13]
Hi,
Yup. That's the failure. I always have to do the commanded database rebuild when that happens.
I know it's a pain but what would you do without the foresight someone had to put the commanded database rebuild in the software?
At least you don't lose your database or have to reload it. Now, that would be real annoying!
#349015 - 08/11/2011 03:03
[Re: Ross Wellington]
Loc: NC
Well, how do I prevent this from happening again? Every time I sync it happens.
#349017 - 08/11/2011 04:48
[Re: deadsled13]
Hi,
I always command a re-build through the serial link before I re-sync. It's just easier that way and it saves me time and frustration.
#349022 - 08/11/2011 11:47
[Re: deadsled13]
Well, how do I prevent this from happening again? Every time I sync it happens. It's in the FAQ, somewhere..  This is from memory, and undoubtedly is missing a step or two: rw player # wait for it to rebuild everything.. Control^C ro exit
#349028 - 08/11/2011 20:14
#349031 - 08/11/2011 20:57
[Re: JBjorgen]
I'm pretty sure he's doing that procedure, manually at the shell prompt, already. His problem is (if I'm reading him right) that he does that procedure, and it fixes the problem once. Then the next time he synchs with Emplode, the problem returns.
His theory is that it's because he's got so many songs that the database is too big, and it passes the Emplode timeout for database rebuilds. I'm not sure that's true, but certainly something is going wrong here, above and beyond what that FAQ entry covers.
#349035 - 08/11/2011 21:27
If he's doing it correctly at the command-line, then emplode is not involved.
#349038 - 08/11/2011 21:57
If he's doing it correctly at the command-line, then emplode is not involved. Not exactly what I meant, sorry. I'll try to be more specific. That FAQ entry, that command-line fix, is supposed to be a single-shot fix that solves the problem permanently. It's supposed to correct the error so that you can then start synching with Emplode normally, and it works normally every time thereafter. What he's saying is, after he applies the fix, the fix isn't permanent. The player works correctly once, immediately after he has done the command-line fix. But then, the next time he tries to run emplode, it re-induces the problem, and now the problem is back and then he has to do the fix again. What he wants is a permanent fix that allows him to use emplode like the rest of us.
#349041 - 09/11/2011 00:26
If the command-line thing isn't working, then something's wrong with the commands being used. So either the disks are not being set r/w for the operation, or perhaps the player is crashing.
Enabling swap for the operation would be a good idea to prevent most types of crashes.
#349044 - 09/11/2011 03:31
[Re: JBjorgen]
Hi,
Thanks to Roger, this is what I do...
--------------------------- COMMANDED DATABASE RE-BUILD ---------------------------
If you get.....
The database and playlist files were not created during the last build.
The player is capable of rebuilding the database completely from scratch.
Type q
rwm cd /empeg/var ls -la
If there is no Playlists or Database Files, they need to be created. There are no tags, if there isn't a database or playlist for them to exist.
mount -n -o remount,rw,nocheck /drive0 mount -n -o remount,rw,nocheck /drive1 - only if it has two drives
Delete /empeg/var/{tags,playlists,database,database3} - if they exist.
Ctrl+D to restart the player and Wait. It will return the following when it completes the re-build.
Prolux 4 empeg car - 2.1434 Jul 5 2004 Vcb: 0x4086d000
Ctrl+C to stop player.
rom
Power Cycle the player _________________________ -- roger
It works every time. Be sure to do the rom command.
#349047 - 09/11/2011 07:54
So either the disks are not being set r/w for the operation, or perhaps the player is crashing. You're right, but I think that you and Tony are arguing at cross-purposes. The fix in the FAQ deals with one-off database rebuild problems. Once done, it ought to be possible to run emplode again and again with no further problems. Setting the disks r/w and rebuilding the database at the command line only works until the next time he runs emplode. Thus, it's not a permanent fix. In this case, the FAQ is incorrect. This fix is never going to be permanent in the face of emplode or player crashes while rebuilding the database. That said: even if emplode crashes during the sync, the player is supposed to continue with the rebuild even without it.
#349048 - 09/11/2011 08:25
[Re: Roger]
Hey, deadsled13, I've never tried using mp3tofid so I can't help you with that option. Ask tonyc or one of these other carpal tunnel guys.
#349050 - 09/11/2011 15:44
Loc: NC
Tony is 100% correct. Everytime I do the the "building databases" fix from the FAQ it works great, just like it's supposed to. UNTIL I want to add new music and I try to sync with emplode and it times out during the final rebuild, almost like emplode doesn't want to wait for the empeg. Once the progress bar reaches it's end emplode crashes and the sync is ruined and I have to rebuild again via hyperterminal.
I didn't used to have this problem until I went with a single large hdd and it didn't start until after I filled it with a crap ton of music.
#349051 - 09/11/2011 16:10
[Re: deadsled13]
UNTIL I want to add new music and I try to sync with emplode and it times out during the final rebuild, almost like emplode doesn't want to wait for the empeg. Once the progress bar reaches it's end emplode crashes and the sync is ruined and I have to rebuild again via hyperterminal. Okay, here's a question. When the "progress bar reaches its end and emplode crashes"... What stage of the synch operation does that happen during? Does it happen during the "rebuilding music databases" stage of the synch operation? If so, then what do you do? Do you reboot the empeg at that point? If so, that very thing might be the problem. I think what Roger is trying to say is, that if you left the empeg completely alone at that moment, and just let it sit there for a while, it should theoretically finish the database rebuild on its own without emplode's help. Not sure if that's actually true in practice, but it's worth a try.
#349052 - 09/11/2011 16:16
Loc: NC
Yes, that's what happens. I honestly can't remember if I let it sit in the past, seems like I did and it didn't change anything, it takes a long time to rebuild the next time I power cycle.
