Page 2 of 2 < 1 2
#343834 - 28/03/2011 14:24 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
player: permission fault on section, address=0xffffffd8, code 2
0xffffffd8 is -40
Oh, duh.. I just clued into what that means: -40 was probably an errno return from some function that normally returns a pointer on success.
So.. -40 = -ELOOP = "Too many levels of symbolic links".
Does that filesystem have a symbolic link that points at itself, or at the same directory that contains the link, or something ?
#343835 - 28/03/2011 14:30 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
A way to perhaps get more debug info, would be to kill off the player after booting, and then rerun it with strace:
rwm
strace -f player &> /drive0/log
rom
Then post the /drive0/log file here as an attachment.
In case you don't already have strace, I'm attaching it again to this post. Put it onto your empeg, mark it as executable, and give the full pathname for it in the above command.
strace.binary (500 downloads)
Description: strace command for the empeg.
#343852 - 29/03/2011 05:00 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
I have to demonstrate my inexperience again.
How do I load the strace into the the player and make it executable? After it is loaded is it just a reane and permissions thing?
Do you want it loaded into root?
Thanks,
#343855 - 29/03/2011 06:55 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
Using your favourite serial terminal program:
# rw;rwm
# cd /drive0
(in terminal program, use ZModem to send the file; the developer build of the player has the necessary bits on it)
# mv strace.binary strace
# chmod +x strace
(what Mark said earlier)
#343856 - 29/03/2011 09:36 Re: Using SATA Laptop Drives with Empeg [Re: Roger]
Or just FTP it over, which might be simpler than Zmodem in this era. smile
#343857 - 29/03/2011 10:52 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Doh! Forgot that Hijack has FTP. Nah. Go old-school.
#343909 - 31/03/2011 16:39 Re: Using SATA Laptop Drives with Empeg [Re: Roger]
Ross Wellington
Hi,
I tried this, the log file is not being updated. I put the strace executable in root. This is what I am doing...
After the player boots, I do the following
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
q
Dead temp.sensor, status=0x00
Restored terminal settings
No secondary hard disk
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# rwm
empeg:/empeg/bin# strace -f player &> /drive0/log
empeg:/empeg/bin# rom
empeg:/empeg/bin# exit
logout
Shell exit
Starting player
Timezone: GB
player.cpp : 385:empeg-car 2.01 2004/07/06.
Vcb: 0x4086d000
After this, I loaded emplode and loaded a few smaller (5MB), which it worked, then a few more small files. It even worked with a 41MB load. When I tried a 120MB load, it choked (actually, it completed instantly).
I checked the log file on /drive0/log and there was no change from the time it was created and only had 32 Bytes. When I tried to stop the player, it said that it couldn't find a shell and just continued to complete an exit. I was however, able to ftp into the player and the log file was unchanged.
After I powered down the player, and rebooted, it returned a shell prompt when I exited. I checked the log file and it was unchanged (byte count, date & time). The player operated normally (played the tunes I loaded except the 3 songs that made up the 120MB files).
What am I doing wrong?
#343920 - 31/03/2011 20:45 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
Load the database and all while that instance of the player (above) is running. Do not control^C or exit until done with the test.
#343929 - 31/03/2011 23:03 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
Per the above listing, you do want me to quit, set-up the strace, and then ** Not exit ** right?
I tried that first (not exiting). It was not able to find the player with emplode, it looked like the player software wasn't running. I think I was able to ftp into the player though. After I exited, emplode could see the player.
That's why I exited. That was the only way emplode would see the player.
Are writes to the log file not allowed by permissions or the rom command?
Guess I need a list of commands to cover my lack of understanding (yeah, I know I'm embarrased to ask, I'm sure you have other things to do...).
Thanks,
#343932 - 31/03/2011 23:53 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
The player will run V E R Y S L O W L Y with strace, so be extra patient. The log file it produces will be enormous. The "rwm" command stands for "readable/writable music" partition, which is the biggest place to save a big log file.
Since the whole idea is to capture an "strace" log of the player, it is not useful to run the player without strace, because doing that won't give us the log.
So if you cannot get it working under strace, then forget about it. It just might not be feasible.
"strace" stands for "system-call tracer". It's a program that installs itself between the application ("player") and the Linux kernel (operating system), and records every single event where the application invokes any kernel service. So it's a great way to see what a program is really doing under the hood, especially if the program is crashing at some point.
#343933 - 31/03/2011 23:55 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
What are you actually doing to make the player crash, anyway?
You said something about "tried a 120MB load", but what does that statement actually mean?
#343940 - 01/04/2011 02:14 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
I would assume that means he tried to transfer 120 mb of music to the empeg via emplode.
#343950 - 01/04/2011 09:44 Re: Using SATA Laptop Drives with Empeg [Re: JBjorgen]
I might assume that too, but I'd really like know. smile
And it might be useful to know at what stage the thing dies -- during the file transfers, or during the database build ?
cheers
#343951 - 01/04/2011 09:46 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
I wonder if any of the player code "steals bits" from sector/block numbers for other purposes, eg. an "in use" bit for sectors in the dynamic data partition?
Because with a 1TB drive, 31 bits are needed just to address sectors, leaving only one bit "spare".
Roger?
#343954 - 01/04/2011 10:18 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Not as far as I'm aware. It's unlikely. That's not the kind of hack we'd have gone for. Validating checksums and block bitmaps are more in keeping with the empeg style.
#343961 - 01/04/2011 15:00 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
The player will run V E R Y S L O W L Y with strace [...]
Might it be a bit faster/more feasible if the strace logging is
restricted to a particular set of calls?
#343966 - 01/04/2011 16:29 Re: Using SATA Laptop Drives with Empeg [Re: canuckInOR]
Ross Wellington
Hi,
More information...
Mark asked:
Answer:
Yes it was 120MB of song database load through emplode. Mark has a valid point, I do weird things sometimes. <grin>
I hope what is listed below might help with his second question.
strace information
I was able to get strace to work. What I hadn't realized is that I needed to tell it where strace was. I decided to put strace in the root of drive0 (I thought it would run from the root of the empeg, I thought wrong). When I looked at the contents of the log file, it kept saying it was a bad command. As soon as I pointed to where strace was, as in ./strace ...., it worked. The log file does quickly fill with LOTS of data with the system call data. Dumb mistake, I know.
Unfortunately, as soon as I used it, in emplode, it needed to perform a Check on the Media. Without strace, it doesn't need to. Even on known good drives with fully rebuilt media (doesn't matter the size - 250GB or 500GB or interface type - EIDE or SATA), needs 2 passes to go through it, and dies. This included a drive with and without song database, all drives had been fixed for the missing tags and include the rom lock. I can re-create a log file if you need it.
So... I wanted to find out if it is a software or hardware problem. Now that I have a better understanding of ftp (didn't know it had the capability or how to use it a couple of days ago), I was able to get a better definition of what works and what doesn't.
I prepared a 250GB EIDE drive and placed 1GB of song database on it through emplode. I then opened an ftp session with the player, directed to the fids on drive0 and changed to an ftp session in Windows. I created a directory for the fids on my PC and copied the fids database from the player to the new fids directory on my PC. That obviously took a few minutes to do.
I then changed out the player drive, built a new drive on the player (put in the 500 GB SATA interfaced drive), opened a HyperTerm, quit the player software, made the music read/writable (RWM), and exited. I know this is dangerous, but, this is all development anyway.
I opened an ftp session in Windows and copied about 350MB of the fids database from the Windows directory into the drive0/fids directory. This took some time as well. After the copy completed, I mounted the drive (mount -n -o remount,rw,nocheck /drive0 - probably not neccessary at this point), CTRL^D to force a rebuild, Ctrl^C to stop it, and rom to lock.
It worked! The player has all that I down loaded, the structure is correct. It operates normally.
So I am able to copy large files across the SATA Adapter through an ftp session onto a 500 GB drive which points to some kind of other problem. Not a full fuzzy that the hardware path works but it helps define the problem more.
I could run strace in the ftp session if you want it as well.
What do you think?
Thanks,
#343967 - 01/04/2011 16:43 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
So it sounds like something in the emplode<-->player path was causing the problems. Again, since it's closed source, our best bet would be to see an strace log of that happening.
The reason it keeping doing "media checks" is probably because we mounted the music partition read/write so that we could put the huge strace log there.
So, to get this trace to work, I guess we'd need to find somewhere different to put the log file. Like perhaps a second non-built drive, or an otherwise unused partition on the main drive.
This could get complicated to explain, though.
#343980 - 01/04/2011 23:22 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
I tried to do something like what you asked (kind of a feeble attempt). I was still bothered by the rwm of the file system being open, it still got hung up on the media check, but I got a longer log file.
I used a 12GB drive that the file system was missing on, and directed the log file to that drive (drive1).
I have attached the strace file that I sent to drive1.
I can trash this drive if you will help to provide you the data you need.
Thanks,
emplode session strace log - SATA Adapter 500GB drive + 12GB Drive.txt (582 downloads)
#343981 - 02/04/2011 00:23 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
If you want to continue with this, then the idea is to get rid of the media check issue, by NOT USING rwm. If you can send the log elsewhere, not to the music drive, then the music drive does not need to be writeable any more, so no rwm command.
#343985 - 02/04/2011 01:12 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
Dumb question, can it be sent to my PC via ftp?
#343998 - 02/04/2011 13:45 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
After the file is created locally, you can use FTP to transfer it to your PC.
If you want it to go directly to your PC, then you'll need more software on the empeg (this gets complicated rather quickly).
Eg. NFS configured on the empeg, so it can mount a (Linux) PC filesystem for writing out the log file directly.
Or perhaps run telnetd on the empeg, so that you can telnet in from another PC (putty on MS-Win) and run the strace player from within the telnet session. No log file required with this method, instead just let strace spew its output directly over telnet to the remote PC. Save the session log afterwards to save the log messages.
But again, this may all be beyond your current level of expertise.
#344000 - 02/04/2011 14:35 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
Yup, that stuff is way beyond my expertise level.
#344001 - 02/04/2011 14:50 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
Okay. Another way to capture the strace log locally on the empeg, is to install a second drive, which is not formatted for empeg use.
So basically start with a blank second (slave) drive -- no partitions, and boot into the empeg software. Hit control^C to kill off the player and get a command prompt.
At the command prompt, format the drive. Use as small a drive as you have available to you, because the larger the drive, the slower this step will be:
mke2fs /dev/sdb ## and say "y" when prompted
Then, mount it r/w:
mkdir /t ; mount /dev/sdb /t
If that works, then you can try the strace, without the rwm:
/strace player &> /t/strace.log
And afterwards use FTP to retrieve /t/strace.log from the empeg to a PC.
#344007 - 02/04/2011 23:23 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
I tried this and it produced the following results (I probably did something wrong):
Starting bash.
empeg:/empeg/bin# cd ../..
empeg:/# cd drive1
empeg:/drive1# ls -la
total 2
drwxr-xr-x 2 0 0 1024 Jun 2 1999 .
drwxr-xr-x 15 502 220 1024 Nov 24 13:28 ..
empeg:/drive1# cd ..
empeg:/# mke2fs /dev/sdb
mke2fs 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
Could not stat /dev/sdb --- No such file or directory
The device apparently does not exist; did you specify it correctly?
empeg:/# mke2fs /dev/hdb
Could not stat /dev/hdb --- No such file or directory
empeg:/# mke2fs /dev/hdc
/dev/hdc is entire device, not just one partition!
Proceed anyway? (y,n) y
hdc is mounted.
mke2fs: Device not configured while trying to determine filesystem size
empeg:/#
I tried to show that drive1 was blank. Then I tried the mke2fs command on sdb, it wasn't able to find it. Then on hdb, then it hdc (which it found). It doesn't look like it was mounted (no file system of course)?
Thanks,
#344009 - 03/04/2011 10:38 Re: Using SATA Laptop Drives with Empeg [Re: Ross Wellington]
Oh, right. I forgot that the empeg screws around with drive names in a non-standard fashion -- it's trying to assign the same names as a Mk1 empeg would.
So just change all occurances of "sdb" to "sdc" and try again. smile
#344022 - 04/04/2011 05:17 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
Still having trouble. It says that it can't stat the drive. It has the same response as above shown below:
empeg:/empeg/bin# mke2fs /dev/sdc ##
Could not stat /dev/sdc --- No such file or directory
empeg:/empeg/bin#
It does the same thing with and without the ##. I also went dierctly to the /bin directory and ran it from there with the same result.
I changed drives (another 12GB drive), tried it with hdc (instead of sdb or sdc), and it formatted fine (12GB, 90 inode tables). I was not able to get drive1 to mount. It gave the following response:
empeg:/empeg/bin# mkdir /t ; mount /dev/sdc /t
mkdir: cannot create directory `/t': File exists
mount: you must specify the filesystem type
empeg:/empeg/bin# mkdir /t ; mount /dev/hdc /t
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
I tried the strace as written above. It would not write an strace.log. I used the older method (./strace -f player &> /drive1/log), and it did write a 60k log file to drive1.
I tried to run emplode and it still thinks it needs to check the media and dies - but does write the log file on drive1. Is this because I am using hdc instead of sdc?
Meanwhile, I was able to format drive1 and write an strace log file to it. We at least know the hardware path works to drive1.
I still have something wrong somewhere, I guess.
What do you think?
Thanks for your time,
#344024 - 04/04/2011 06:38 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Except that the empeg uses hda and hdc, not sda and sdc.
#344032 - 04/04/2011 16:25 Re: Using SATA Laptop Drives with Empeg [Re: Roger]
Duh... you get that, Ross?
Thanks Roger!
#344047 - 05/04/2011 03:09 Re: Using SATA Laptop Drives with Empeg [Re: mlord]
Ross Wellington
Hi,
Yeah, that's what I did.
The responses above were using hdc.
It still had a problem somewhere.
Thanks,
Page 2 of 2 < 1 2
