#34191 - 09/07/2001 08:16 1.03: Still cannot use ethernet
Squid2k1
Loc: Ocean Floor
Just in case anyone was still wondering, my problem of using ethernet to synch with my EMPEG still does not work with v1.03. If I knew how I would add links to my previous posts. But, suffice to say, I am having to use USB when I would prefer Ethernet (I have a home network setup so that all my rooms are wired and I wanted to place my EMPEG in my HTS setup and leave it there and be able to manage it without having to bring it to my PC).
Squid2k1
18GB of Green Mk II Fury - Fast As A Shark
Squid2k1 --- 18GB of revived Green Mk II Fury - Fast As A Shark
#34192 - 09/07/2001 08:44 Re: 1.03: Still cannot use ethernet [Re: Squid2k1]
1. Get a trace from the player bootup (using 115200,8/n/1, no flow control).
2. Get a trace from emplode (Tools/Options/Troubleshooting)
Send them to carsupport@empeg.com -- they'll probably forward it on to me. I'll take a look.
#34193 - 09/07/2001 09:11 Re: 1.03: Still cannot use ethernet [Re: Roger]
Squid2k1
Loc: Ocean Floor
Roger, thanks. I will do that tonight (USA EST) and will forward it tomorrow/tonight.
Squid2k1
#34194 - 12/07/2001 08:24 Re: 1.03: Still cannot use ethernet [Re: Roger]
Squid2k1
Loc: Ocean Floor
Roger, I am about to send the information (been too busy, unfortunately) but I wanted to let you know that last night I had the problem and another problem. It could not find the EMPEG via ethernet at all after it failed the synch. Then this morning when I put it in the car the EMPEG displayed Rebuilding Music Databases... for awhile, then played normally.
Now I am at work and I just plugged it in and it gave me the Rebuilding Music Databases... It did not last as long but this has not happened before.
Squid2k1
#34195 - 12/07/2001 09:54 Re: 1.03: Still cannot use ethernet [Re: Squid2k1]
I think the "Long Rebuilding Music Databases" problem is because of a recent failed synch. I'm pretty sure it will continue to do that until you can do a successful re-synch. Once you've successfully re-synched, the message will go away.
