Page 2 of 2 < 1 2
#341648 - 29/01/2011 00:38 Re: iPhone 4 battery life [Re: siberia37]
A123 batteries are popular with RCers already. But they are bigger and heavier batteries so only appropriate for large planes or surface vehicles.
There are several variants of the LiFePO chemistry, the A123 being the most obvious example. They all suffer from rather lower terminal voltage than the normal LiPo ones, and all the ones I've seen have metal casings, so the do certainly have a lower energy density/weight ratio. That said, they're all pretty much bomb-proof as far as 'uncontrolled battery excursions' go, ie don't go bang if you do something silly to them.
However, they tend to be quite expensive, which seems to be the main reason that they're not used as much in RC planes. The weight isn't as much of an issue as you might think, as this type of battery tends to be used in quite large aircraft that can handle it easily.
Then can be charged at more than 1C rate though- something LiPos batteries can't do safely.
Most of the newer LiPo chemistry variants can be charged at considerably more than 1C now, some I've tried claim up to 5C, although 3C is more likely correct if you want decent cell life. The discharge rate is truly frightening, I have seen up to 35C continuously and 70C in bursts for some of the newest cells, which for example on a 5Ah battery could be over 350A shocked You can easily start a car with a battery you can put in your pocket.
They seem to have remarkably low internal resistance, so they don't even get warm at the rated discharge level. This could work against you, as if the things really did have a 10x current level of energy storage, you could get almost all of it out in a few seconds. They already have the energy density to potentially take your hand off, so...
#341656 - 29/01/2011 01:49 Re: iPhone 4 battery life [Re: pca]
If anyone is interested in RC-class LiPo packs, the best prices I've found are at hobbyking.com for the Turnigy stuff.
I just picked up a classic Tamiya Porsche 959 to rebuild as a shelf queen late last year and in late November I grabbed a Jammin SCRT-10 (1/10 Short Course) to modify and run. This year I plan to convert a 1970's metal Tonka Bronco into RC. smile
#341698 - 30/01/2011 02:34 Re: iPhone 4 battery life [Re: tman]
Doubt they'll be still good. Lithium batteries start to degrade the minute you've manufactured them. If they're not in proper storage conditions (temperature and charge level) as well then the degradation is going to happen even faster.
They've gone through 5 hot summers in a non-AC veranda which turns into a greenhouse, and 5 quite cold winters where it definitely must have gone below 0°C.
I guess I can dispose them. Am I correct in assuming that they should not explode/fire up if broken or short-circuited, when without charge?
#341729 - 31/01/2011 20:27 Re: iPhone 4 battery life [Re: Taym]
When totally discharged (ie, to near zero) they should be fine (should be able to go to standard battery disposal). Got any meaty resistors around? smile
#341735 - 01/02/2011 00:34 Re: iPhone 4 battery life [Re: altman]
aka. low-wattage incandescent bulbs?
#341743 - 01/02/2011 02:00 Re: iPhone 4 battery life [Re: Taym]
Even if they're completely flat, don't try to break them open or short them :P
#341766 - 01/02/2011 23:27 Re: iPhone 4 battery life [Re: altman]
Ok, I'll eventually dispose them. But no, no resistors left around, sorry. smile
Plenty of those around, actually. How low?
Ok smile I'll actually make sure they're well protected, if there's still some chance of fire or explosion. The worst thing is to keep them there and forget they even exist.
Page 2 of 2 < 1 2
