#33997 - 07/07/2001 04:12 Non MP3 files
Hi everyone.
QUick question: wha happens if by mistake you drop a non-mp3 file in the emplode window and then sync? Does the file get tranfered to the empeg hdd? Does empeg recognize mp3s from other kind of files during sync?
Thank you all
______________________________
MK II BLUE 12GB
090000923
#33998 - 07/07/2001 05:28 Re: Non MP3 files [Re: Taym]
edwin
Loc: Druten, The Netherlands
Files with other extensions than .mp3 will be excluded by emplode, so dragging an entire directory with all sorts of files in them will only transfer .mp3 files.
If you deliberately renamed some files with an .mp3 extension, they will be transfered as well. In this way you could take other files with you. Use displayserver to retrieve the file.
Edwin de Vaan
mk2 rev.7 Trillian # 080000263 6+20Gb blue/red
[white]­­______________[/white]
Edwin de Vaan aka FLaSHmAStER
#33999 - 07/07/2001 10:14 Re: Non MP3 files [Re: edwin]
You took the words right out of my mouth, Edwin. Thanks.
I often rename files to ".mp3" so that I can use the empeg to taxi them home and retrieve them with displayserver. You get more storage space than you would with an iomega drive. Not quite as convenient, but it's certainly cooler to use your car stereo as a file taxi.
A couple of tips:
- Remember that Displayserver only works on Ethernet, so you can't retrieve the file via USB. There is another program floating around on this BBS called "EmpegTaxi" that uses USB, but we're talking about Displayserver here. Since you're using Emplode to send the file to the empeg, you can use USB or ethernet for that. But for getting the file off the empeg with Displayserver, you need ethernet. Keep that in mind as you're planning the taxi operation.
- I always stick my taxi files in the "Unattached Items" folder, to keep them separate from the rest of the files.
- The empeg might try to play those files if they come up in the shuffle, even if you put them in "Unattached Items". If this happens, it won't hurt anything, it will just say that the MP3 file is invalid. Just skip to the next track and unpause it.
- To reduce the chances that the empeg will try to play the file, and to make transfers easier, I always zip my stuff into one large zip file and send that to the empeg.
- If you do the steps carefully, you can even rename the file extension as-you-go. When creating the zip file, name it ".zip.mp3" when prompted for the file name. When retrieving it from displayserver, right-click on it and hit "Save target as..." and remove the .mp3 extension before hitting Save.
- Don't forget to use emplode to delete the zip file from the empeg when you're done.
Now... who was working on EmpegTaxi? Is there a more user-friendly version of it yet?
#34000 - 08/07/2001 04:13 Re: Non MP3 files [Re: tfabris]
Rod
Loc: Australia
This is exactly what I have been doing too. The zip files are definitely the way to go.
I did have the W2K service pack 2 on there at once stage (still as an EXE file). It came up in the shuffle and the empeg tried to play it (didn’t say MP3 file is invalid as it does for ZIP files). Had to reload the .upgrade to get things going again.
Rod.
#34001 - 08/07/2001 10:36 Re: Non MP3 files [Re: Rod]
EngelenH
Loc: Belgium/Holland
ROFLMAO !!!!! So MicroSoft finally did it !!! They created a Linux Virus and it's called Windows 2000 Service Pack 2 !!!
[sounds of someone choking in laughter]
Hans
Mk2 - Blue & Red - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#34002 - 08/07/2001 10:43 EmpegTaxi [Re: tfabris]
Jazzwire
Loc: Guernsey
I got as far as getting a file list off the empeg by taking control of the usb and serial console. Now I can automate the transfer of a file by locating the size from the file list and sending the right command through the serial port.
However...
The empeg -> PC transfer seems to work fine, providing your PC is fast enough. Without a program on the empeg to split the file into chunks and CRC them, I can't ensure the file is actually the same (In most cases it works fine, but I'd like confirmation. At least if you use a zip file you gain some CRC checking)
Direct PC -> empeg transfer seems to generate a file of the correct size, but it's full of junk... =(
As I see it, the choices are...
  • Implement a packet protocol with checksum and retry, and use a program on the empeg to generate/receive the packets (Basically what the empeg software does)
  • Implement the PC side of the empeg protocol in object pascal and use the existing player software to do the packet and file manipulation.
  • Find a compatible USB PPP driver, and run TCP-IP
  • Find a kind soul who can compile emptool for win32, and use that to do the transfers
  • Other
So I'm stuck at the moment, as I know very little C++, and I'm unable to compile emptool or the protocol libs in C++ builder...
If anyone has any ideas it's probably a good idea to start a thread in Programming...
Jazz
(List 112, Mk2 12 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
Jazz
(List 112, Mk2 42 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
#34003 - 08/07/2001 11:28 Re: EmpegTaxi [Re: Jazzwire]
First of all, I've never had a problem with EmpegTaxi feeding me a bad file. I've used it a bunch of times. Second of all, I only ever use zipfiles, so the lack of a checksum is no problem (for me).
Not a problem, because you don't need to use "your" method for sending files to the Empeg. The empeg already has a perfectly good method for sending files to it through Emplode. All those things you listed as work-arounds... you don't need them. You only need Emplode.
By the way-- in version 1.1 of emplode, you will get to see the FID when you look at a column of files, making retrieval easier if you're using this kind of method.
Anyway, another option to look at is to dig into the open-source code for Emptool and see how it sends the files. You could use some variation of that method. Hugo keeps hinting that the emptool sources could be fairly easily modified into a taxi program if you so desired.
In any case, would you mind releasing that version of EmpegTaxi that controls the serial port and makes it easier to retrieve files? All I'd need is a way to easily grab one file out of "Unattached Items" and then I wouldn't need Displayserver any more. (I can use EmpegTaxi to retrieve the files right now, but I hate having to muck about at the bash prompt to do it.)
#34004 - 08/07/2001 14:47 Re: EmpegTaxi [Re: tfabris]
Jazzwire
Loc: Guernsey
Yes, I agree for EmpegTaxi you can use empload... But I was aiming to write a USB connection object to be used for bi-directional connections (e.g. displayserver over USB). I could try to re-implement the empeg protocol from the emptool source, but C++ is not my primary language (it's probably down there at number 12!)
As to the next release, well I've got it searching by title. It needs cleaning up a little (i.e. error handling) but I should have something within a few days...
Jazz
Jazz
#34005 - 08/07/2001 16:48 Re: EmpegTaxi [Re: Jazzwire]
I await the release anxiously!
#34006 - 09/07/2001 12:27 EmpegTaxi Alpha 2 [Re: tfabris]
Jazzwire
Loc: Guernsey
Wait no longer.. =)
http://nrg.nu/files/empegTaxi.zip
I'll announce it in general later, when I confirm that it works for other people than me... =)
Jazz
Jazz
#34007 - 09/07/2001 12:40 Re: EmpegTaxi Alpha 2 [Re: Jazzwire]
Thanks!
I've run into a snag...
I'm running additional software on the unit that requires more "Q"s than the default empeg configuration. There's the initial drop-to-shell from the player, but then it runs a script that needs at least one more Q to get out of its wait-for-button-press thing.
Is there a way you could get it to send a few extra Qs in succession? I think that I'm not the only one running extra shell scripts at player exit, and I think they are mostly all designed to exit with an additional Q.
I'm pretty sure that extra Q's at the bash prompt won't hurt anything...
#34008 - 09/07/2001 12:43 Re: EmpegTaxi Alpha 2 [Re: tfabris]
Also... heh...
My player's prompt from bash is called by a shell script, so it has different prompting than Empeg's. Instead of saying "empeg:/empeg/bin#", it says something like "bash:/empeg/bin#".
Perhaps all it needs to look for is "/empeg/bin#" for its initial connection?
#34009 - 09/07/2001 13:16 Re: EmpegTaxi Alpha 2 [Re: tfabris]
Crap, my prompt doesn't say what I thought it did. It simply says:
bash-2.03#
Yuck.
Wonder how you'd work around that in EmpegTaxi? Maybe allow the "search for" string to be configurable? Or just look for #? Yikes, I dunno!
#34010 - 09/07/2001 14:09 Re: EmpegTaxi Alpha 2 [Re: tfabris]
export PS1="empeg:\w# "
#34011 - 09/07/2001 15:02 Re: EmpegTaxi Alpha 2 [Re: Roger]
I'm sure that's one of those newfangled linux commands I don't understand.
Guess I'll try sticking that in my init and see what it does, eh?
#34012 - 09/07/2001 15:09 Re: EmpegTaxi Alpha 2 [Re: Jazzwire]
For some reason the zip file is getting corrupted when I download it with IE. It works fine with Netscape 6 through, odd it's usually the other way around...
__
#34013 - 09/07/2001 15:11 Re: EmpegTaxi Alpha 2 [Re: tfabris]
Jazzwire
Loc: Guernsey
I should of guessed you would break it... =)
If it times out, press cancel, and it will try to continue as if it received the correct string.
I'm working on a version with configurable prompt and q... =)
Jazz
Jazz
#34014 - 09/07/2001 15:13 Re: EmpegTaxi Alpha 2 [Re: andy]
Jazzwire
Loc: Guernsey
That's odd... As I downloaded it with Ie5.5 to check it uploaded correctly...
Jazz
Jazz
#34015 - 09/07/2001 15:16 Re: EmpegTaxi Alpha 2 [Re: Jazzwire]
Wohoo! Thanks!
#34016 - 09/07/2001 15:19 Re: EmpegTaxi Alpha 2 [Re: Jazzwire]
I tried it a couple of times before giving up and trying Netscape, odd.
__
#34017 - 09/07/2001 15:22 Re: EmpegTaxi Alpha 2 [Re: andy]
Again, GetRight comes to the rescue. My initial click with IE didn't work right away, so I canceled it and ran GetRight, got the file fine.
#34018 - 09/07/2001 15:27 Re: EmpegTaxi Alpha 2 [Re: Jazzwire]
It seems pretty fast, I guess that's because it doesn't have the overhead of the tranfer protocol that emplode has.
Very impressive.
__
#34019 - 09/07/2001 16:20 Re: EmpegTaxi Alpha 2 [Re: tfabris]
Jazzwire
Loc: Guernsey
Well this is going well...
I've finished the coding and testing of the new version, to find my web host has stopped responding (at least from here).
So I can't upload the new version... =(
I can't attach it to the BBS either, as it's a bit too big...
Ho Hum...
Jazz
Jazz
#34020 - 09/07/2001 16:28 Re: EmpegTaxi Alpha 2 [Re: Jazzwire]
You could e-mail it to me if you wanted. :-)
#34021 - 09/07/2001 16:37 Re: EmpegTaxi Alpha 2 [Re: tfabris]
By the way. After I installed 1.03 from scratch (fixing the Q and prompt), the Alpha2 version you posted earlier never finds anything. It acts like it works ("searching drive0, searching drive1, finishing, waiting for command"), but never finds anything, even just the letter "e".
Ah, I see. You need to insert the full file name, not just a substring. Okay, I understand that now. Substrings would be nice for the future, but I understand the way it is now. Cool.
#34022 - 09/07/2001 16:41 Re: EmpegTaxi Alpha 2 [Re: tfabris]
Jazzwire
Loc: Guernsey
It matches from the beginning of the title, so it will do a substring (sort of)
It's because of the way I use grep... When the new version appears, you can watch the serial debug console to see what it does... =)
Jazz
Jazz
#34023 - 09/07/2001 17:08 Re: EmpegTaxi Alpha 2 [Re: Jazzwire]
Cool, just used the new one you e-mailed me. Serial debug is cool. Substring search works well as long as you know it's the start of the file name.
My only remaining wish is that it would save whatever string you last entered into the "search" box so I don't have to retype "taxi" every time.
This is an amazing cool utility now, thanks!
#34024 - 09/07/2001 23:42 EmpegTaxi Alpha 4 [Re: tfabris]
Jazzwire
Loc: Guernsey
Well my WebHost appears to have returned, so I've uploaded a new version.
It now remembers the last "Search For" correctly as well as the configuration...
Jazz
Jazz
#34025 - 09/07/2001 23:49 Re: EmpegTaxi Alpha 4 [Re: Jazzwire]
Yep, as someone else said... it's like rubbing a lamp around here.
Thanks a million!
#34026 - 10/07/2001 10:44 Re: EmpegTaxi Alpha 4 [Re: tfabris]
By the way, I've tried replacing the "prompt" text with just a poundsign ("#") and it seems to work fine in my case. So no matter whether I've put a fresh copy of 1.03 or 1.1 on the player, or I've put in my custom init, or whatever, it still works.
Oh, and one other thing... if I hit the "close" button without first hitting the disconnect serial/usb buttons, the program locks up.
