Page 2 of 2 < 1 2
#339188 - 07/11/2010 14:11 Re: Apple store is not listing any accessory SSD's for Macbook pros. [Re: drakino]
You can usually use lsof to see what the current file offset is in order to estimate copy duration.
#339209 - 07/11/2010 17:24 Re: Apple store is not listing any accessory SSD's for Macbook pros. [Re: wfaulk]
Here is a script somebody wrote, and which I modified, to use cp and show a progress bar..
#!/bin/sh
# Simple file/device copy command with a progress bar.
# This is VERY handle for drive-to-drive copies and the like.
src="$1"
dst="$2"
if [ "$src" = "" -o "$dst" = "" ]; then
        echo "missing src/dst param(s)" >&2
        exit 1
fi
if [ ! -e "$src" -o ! -r "$src" -o ! -f "$src" ]; then
        if [ ! -b "$src" ]; then
                echo "$src: not a regular file" >&2
                exit 1
        fi
fi
[ -d "$dst" ] && dst="${dst%/*}/${src##*/}"
if [ -e "$dst" -a ! -b "$dst" ]; then
        echo "$dst: already exists, not overwriting it" >&2
        exit 1
fi
if [ -b "$src" ]; then
        total_size=$(grep "\<${src##*/}\$" /proc/partitions | awk '{print $(NF-1) * 1024}')
else
        total_size=$(stat -c '%s' "$src")
fi
if [ "$total_size" = "" ]; then
        echo "$src: unable to determine total size, aborting"
        exit 1
fi
echo "Copying \"$src\" to \"$dst\":"
strace -q -ewrite cp -- "$src" "$dst" 2>&1 |\
        awk '{
                count += $NF
                if (count % 10 == 0) {
                        percent = count / total_size * 100
                        printf "%3d%% [", percent
                        for (i = 0; i <= percent; i++)
                                printf "="
                        printf ">"
                        for (i = percent; i < 100; i++)
                                printf " "
                        printf "]\r"
END { print "" }' total_size=$total_size count=0
#339211 - 07/11/2010 18:14 Re: Apple store is not listing any accessory SSD's for Macbook pros. [Re: mlord]
handle handy
Still cool.
Edited by gbeer (07/11/2010 18:14)
#339212 - 07/11/2010 18:15 Re: Apple store is not listing any accessory SSD's for Macbook pros. [Re: mlord]
Yeah, that's clearly easier than using dd. confused
#339216 - 07/11/2010 19:09 Re: Apple store is not listing any accessory SSD's for Macbook pros. [Re: wfaulk]
Bah, right, forgot about that.
As for Mark's script, wouldn't have worked for me, as I ran the clone while booted off an OS X DVD. So BSD instead of Linux, no strace on the DVD boot, and no /proc to poke.
I did like how simple cp was to use though for cloning. No worrying about block size tweaks for speed, it just worked. And from what I could tell from initially trying dd, cp ended up finishing a little sooner.
Page 2 of 2 < 1 2
