#334654 - 30/06/2010 20:09
Re: Wallets
[Re: hybrid8]
And in my front right pocket I keep a roll of cash to balance out the bulge that's already on the left side. TMI
#335129 - 19/07/2010 15:09
Re: Wallets
[Re: hybrid8]
Okay, so I'd recommend staying away from the Ducti wallets.
For my birthday, a family friend sent me one of those duct tape wallets. I was expecting to replace my wallet, but like I said it might be over a decade old at this point and it's getting a little worn, so I thought I'd give it a try.
I removed all the stuff from my old wallet and started putting it into the new one when I ran into one very odd, very stupid flaw: essentially the front two card pockets are completely useless.
You can see in the attached photo that the rivet on the bottom clearly prevents the right-hand side of the cards in the two front pockets from sitting flush in their pocket. In that photo, that is the absolute farthest I can jam either of those cards into the wallet. Those both looks terrible and is not very functional on a day to day basis. It's so odd! It just seems like such an obvious design flaw.
I'll be going back to my old wallet, which is still holding up well enough for me...
#335131 - 19/07/2010 15:30
Re: Wallets
Tell me about it. They could have easily solved the problem by putting another rivet on the left side.
#335132 - 19/07/2010 15:42
Re: Wallets
[Re: hybrid8]
Huh. You'd expect them to have actually tested it with cards. Thats a pretty big design flaw if so.
#335134 - 19/07/2010 15:53
Re: Wallets
[Re: tman]
Next thing you'll want mobile phone manufacturers to test reception before putting their products on sale. That's preposterous.
#335135 - 19/07/2010 16:13
Re: Wallets
Loc: Northern Ireland
I didn't know about that, but I have the tri-fold design which doesn't have that flaw.
Geoff ---- ------- Mk1 Blue - was 4GB, now 16GB Mk2 Red - was 12GB, now 60GB
#335154 - 19/07/2010 23:58
Re: Wallets
You can see in the attached photo that the rivet on the bottom clearly prevents the right-hand side of the cards in the two front pockets from sitting flush in their pocket. Well, dummy, you just cut the bottom right corner off of each of your cards and then the wallet will work just fine.  tanstaafl.
#335161 - 20/07/2010 00:32
Re: Wallets
You can see in the attached photo that the rivet on the bottom clearly prevents the right-hand side of the cards in the two front pockets from sitting flush in their pocket. Well, dummy, you just cut the bottom right corner off of each of your cards and then the wallet will work just fine.  Good point! The strip is, after all, at the top, so I should be fine  I took a more practical approach: don't use the stupidly designed wallet  I was eventually able to get a card into that pocket, but with a force just shy of bending the damn card in half. So yes, it fits, but the design still blows.
#335178 - 20/07/2010 13:27
Re: Wallets
At least they used that really cheap super-low thread-count duct tape.
#335195 - 20/07/2010 15:25
Re: Wallets
At least they used that really cheap super-low thread-count duct tape. Maybe you have to buy a premium version which has the better tape and comes with the use of the 2 card pockets.
#335215 - 20/07/2010 20:27
Re: Wallets
[Re: tman]
Did you ever decide on a wallet, Bitt? I might actually be a little curious for my self now. I hadn't thought about how worn my wallet was, and it's looking pretty ratty...
#335223 - 20/07/2010 21:28
Re: Wallets
No, not yet.
#335224 - 20/07/2010 21:46
Re: Wallets
Shame there aren't any cheap online custom wallet sites like you can get for bags.
#335230 - 21/07/2010 00:12
Re: Wallets
Loc: Seattle, WA, U.S.A.
FYI, I emailed the folks at Bosca and they promptly and politely replied that, no, they did not expect to offer the 10-slot bi-fold again. So I guess I am stuck with my discolored Bosca for the duration. The fact that it isn't falling apart is some sort of advert for them, I guess.
Jim
#335232 - 21/07/2010 00:55
Re: Wallets
I've had a Ducti wallet for about 8-10 years now. Nary an issue with it, and no rivet where shown in your photo.
#363173 - 30/12/2014 01:20
Re: Wallets
After buying that wallet, I'd have no need for it. I'd have nothing left to put in it... tanstaafl. OK, after 17 years, the Bosca is getting just a bit ratty. I am thinking about getting a Bosca 12-slot model. Jim
