#33306 - 26/06/2001 05:48 Volume problems
Andrew
Hi there. Got a couple of questions relating to volumes (when the Empeg is used in the house with my amp).
1) I have noticed (more so since I upgraded to 1.03 but that is probably coincidence) that there is a kind of background hissing noise from the speakers when the Empeg is paused. Does anyone know why this is? I don't remember it before but maybe I'm just playing my music louder these days :-)
2) The manual states that when connecting to an external amp, you should increase the volumne level to 0db. When I do this, I get a severely distorted sound from the amp (kind of like it's being overloaded). My amp is certainly not cheap (and neither are the speakers) so what is going on here? I can't make comparisons to how it plays in the car as I am yet to fit it (long story there!).
3) Is there a version of the 1.03 kernel that includes Voladj? I thought that maybe the code might need changing which is why I haven't seen it mentioned here. Any info?
Andy
26GB MKII Blue #090000727
#33307 - 26/06/2001 06:01 Re: Volume problems [Re: Andrew]
schofiel
It could be the empeg is over-driving the input you are using on your amp. It outputs around 3.7 V at line out. What would be worth doing is looking at your amp's specs to see if the input you are using is suited to a drive voltage at this level. If there is another, use that at 0 dB. If not, retain the same one, but by dropping the empeg output by steps of 3 dB you correspondingly reduce it's output level by 50%. If your amp will tolerate (say) 2V line in, then set the empeg to -3 dB and this will be adequate.
As for the hissing noise, it could stem from overdriving your amp's inputs, which sound to be quite sensitive. Experiment a little with levels. Otherwise, I would say - don't light any matches!
#33308 - 26/06/2001 07:13 Re: Volume problems [Re: schofiel]
Terminator
Loc: Dallas, TX
I thought the home outputs were running at 1.75 volts?
Sean
#33309 - 26/06/2001 07:46 Re: Volume problems [Re: Terminator]
schofiel
Acckk - yes, you're right. They are lower voltage.
This could still be overvolting his line input - the level reduction should still work.
#33310 - 26/06/2001 08:28 Re: Volume problems [Re: schofiel]
The empeg is lower voltage than most CD players, so there really shouldn't be a problem at 0dB. What amp is it, and what input have you got it connected to?
#33311 - 26/06/2001 11:12 Re: Volume problems [Re: altman]
Andrew
Hugo,
the amp I'm using is a Sony TA-VA777ES (costs £1500). It's really an AV amp but is rated well as a normal amp. I've got Mission speakers all round, the front two being 702e floorstanders.
I'm currently looking at the specs for the amp to see what voltage the input should be.
Andy
#33312 - 26/06/2001 11:18 Re: Volume problems [Re: Andrew]
EngelenH
Loc: Belgium/Holland
Just a silly question, but into what input (i.e. AUX, Tape, CD etc) did you plug the empeg and did you try (just to be sure) to plug into a different input channel yet ?
Hans
Mk2 - Blue & Red - 080000431
Mk2 This message will selfdestruct in 5 seconds to prevent reproduction.
#33313 - 26/06/2001 11:19 Re: Volume problems [Re: Andrew]
Andrew
OK, I've looked in the amp's manual and these numbers mean nothing to me so I'd appreciate it if someone could translate!
Phono in:
Signal to noise ratio 86 dB (A, 5mV)
Sensitivity: 4 mV
Impedance 50 kilohms
Frequency response 20Hz ~ 20 kHz RIAA +- 0.5 dB
Does this reveal anything?
Andy
#33314 - 26/06/2001 11:21 Re: Volume problems [Re: Andrew]
WAIT! You are plugged into a PHONO IN? This would be a special input for a standard phonograph / record player. This is usually more heavily amplified, and is not considered line level. Do you have any other inputs available? PHONO IN could be the problem.
Paul G.
SN# 090000587 (40GB Smoke)
#33315 - 26/06/2001 11:21 Re: Volume problems [Re: EngelenH]
Andrew
I pluggeed it into the PHONO input. I haven't tried it on any of the others. I notice from the amp's manual that the phono input has different ratings to all the other inputs which all have common ratings.
Andy
#33316 - 26/06/2001 11:23 Re: Volume problems [Re: pgrzelak]
Andrew
Ah, ok. Well, this amp has several thousand inputs so I will experiment with the other inputs. I'll let you know how I get on.
Andy
#33317 - 26/06/2001 11:23 Re: Volume problems [Re: Andrew]
Try it in a different input. The phono in usually passes through an extra amplificiation step to bring it to line level before the standard amp. You might want to try another input, or lower your empeg level from 0db down significantly. I don't know how low, but it would be significantly lower.
Paul G.
#33318 - 26/06/2001 11:24 Re: Volume problems [Re: Andrew]
Cool! I think this will solve it.
Paul G.
#33319 - 26/06/2001 11:36 Re: Volume problems [Re: pgrzelak]
Andrew
Wahey!!! Thanks everyone. I put it into the MD/DAT input and it is fine. I'm using 0dB without problems and the hissing is MUCH reduced (still appears when I pause the Empeg and put the volume WAY up on the amp).
BTW, wish list for the MK3 : digital out (optical or coax).
Thanks to all those who helped. Does anyone have any info for me regarding the voladj mod and the 1.03 kernel (see point 3 on my original post)?
Andy
Edited by Andrew on 26/06/01 07:37 PM.
#33320 - 26/06/2001 11:39 Re: Volume problems [Re: Andrew]
EngelenH
Actually I was expecting you would say Phono, I made the same mistake too (a long time ago and not with the empeg, and if you tell anyone I will come pummel you around ). There is your problem then, phono inputs do indeed have different ratings, just use a different input and the problem will most likely be gone.
Tony, maybe something for a faq entry ?
Hans
#33321 - 26/06/2001 11:46 Re: Volume problems [Re: Andrew]
EngelenH
like this thread ? :
in technical
Hans
#33322 - 26/06/2001 11:54 Re: Volume problems [Re: EngelenH]
Andrew
I didn't realise it was such a well known silly mistake!! Ok everybody - don't tell anyone I did this or you'll all be in for a pummeling
#33323 - 26/06/2001 11:58 Re: Volume problems [Re: EngelenH]
Andrew
I did see that thread but in another thread, somebody mentioned that there will need to be some code changes to voladj and I wondered if Drakino knew that. I didn't want to install a potentially dodgy kernel. If anyone has used his kernel without problems, let me know.
Andy
#33324 - 26/06/2001 14:02 Re: Volume problems [Re: Andrew]
I recieved a new patch for the voladj from Richard. Things did change in 1.03, but not too much. If your using a program to select different settings for it, it does need to be recompiled. I have this as an attachment in the technical fourm thread.
I've also been running the kernel on my empeg now for about 5 hours with no problems, although I am not hearing the voladj. I may have made a mistake in the patch, or I may just be having a hard time telling. I wpuld appreciate it if someone else tried the kernel to see if the code is working right.
32513- (170 downloads)
#33325 - 26/06/2001 23:05 Re: Volume problems [Re: Andrew]
time
Loc: Pacific Northwest
I know you've got the problem solved, but one other thing to keep in mind... since you don't have the player installed using the RCA outs on the docking sled will net you the 4V outs which could also be overdriving the equipment. The RCA outs directly of the back of the chassis will provide the 1V outs that would be compatible with most home hi-fi systems.
Best regards,
#33326 - 27/06/2001 02:05 Re: Volume problems [Re: drakino]
BryanR
Loc: Berkshire, UK
Drakino,
Yesterday I installed the kernel and new voladj files that you posted in the Technical forum, and everything is working correctly (so thanks again for recompiling everything).
One question, though (and getting somewhat off-topic): I noticed that the voladj binary file seems to have reduced in size from 12KB to 6KB - I just wondered why?
Bryan.
Mark 2 #080000515
12GB Green (was Blue)
...and it's full!
Bryan.
#33327 - 27/06/2001 02:08 Re: Volume problems [Re: Andrew]
thinfourth2
Been there done that very common mistake also done it the other way round
"why my record deck so quiet?"
#33328 - 27/06/2001 09:42 Re: Volume problems [Re: BryanR]
No clue on that one. I opened the source code, changed the single thing that needed to be done (a 2 to a 3) and typed gcc voladj.c. This was from the empeg it's self.
#33329 - 28/06/2001 02:04 Re: Volume problems [Re: time]
Tim! You're still here! But... I thought...
Never mind, it's good to see your posts here.
#33330 - 28/06/2001 02:09 Re: Volume problems [Re: Andrew]
I just checked the Empeg Car manual, thinking that it probably had a warning about not plugging it into the Phono input on your amp.
Guess what? Not only does it have no warning, but it refers to the RCA jacks as Phono jacks. Oops!
Hey, Empeg guys, you might want to consider updating that in the next reprint of the manual, eh? Or perhaps include an addendum sheet in newly-shipped boxes or something?
#33331 - 28/06/2001 02:19 Re: Volume problems [Re: tfabris]
Ouch!
As long as you are updating the documentation, you might want to update all of the support addresses and references to empeg. There are spots where, for example, you refer to the "empeg car" program group, etc. Lastly, you will need to update the remote information for the new Rio remote.
I am certain that most of these changes are already done or in the works, but the version on the web site is a little dated.
Paul G.
#33332 - 28/06/2001 02:19 Re: Volume problems [Re: tfabris]
The lack of warning is possibly an oops (do ordinary line-level components such as CD players carry such a warning?), but "phono jack" is the standard term for those things in the UK, even when not used for RIAA-biased inputs. (Eeeh, I remember the days when RIAA were mainly known for being useful to the audio consumer...)
#33333 - 28/06/2001 04:08 Re: Volume problems [Re: peter]
Andrew
Yeah, I know the leads as Phono leads (RCA lead is a new term for me) but I had no idea about the different level inputs which is more to do with a general lack of audio knowledge.
Still, I do agree that this "avoid the phono input" point should be in both this BBS's FAQ and mentioned in the Empeg manual.
Andy
#33334 - 28/06/2001 04:13 Re: Volume problems [Re: tfabris]
You don't work for Rio either Tony, but you're here
#33335 - 28/06/2001 04:21 Re: Volume problems [Re: pgrzelak]
Are you looking at a Rio Car guide or an empeg guide? The Rio guide should be completely up to date.
As Peter said, "phono connector" is the English word for "RCA jack". The Rio Car guide refers to "phono (RCA) jacks" and states the line level. Maybe there should be a comment about not connecting them to the low level input of the amp.
I thought this was hifi general knowledge, but I guess a lot of people have never had contact with a record player. At our poker game last week I found it amazing to watch one of the players attempt to change the record and not have a clue how to use John's turntable. I feel so old!
