#331125 - 19/03/2010 00:54 Need a Docking Pin
brax
Loc: Birmingham, AL
Ok long story short I broke one of my sleds docking pins. Can I get these from digikey or some place? If so does anyone have a part number?
One of my wires for AuxIn broke and I was trying to get the pin out and it broke.
#331126 - 19/03/2010 00:58 Re: Need a Docking Pin [Re: brax]
I'll bet that Stu has got some. Hit the "Repairs" link above.
#331127 - 19/03/2010 01:02 Re: Need a Docking Pin [Re: tfabris]
Also the parts list is here:
http://empegbbs.com/ubbthreads.php/ubb/showflat/Number/140368
However I'm confused because some of the dock connector parts are listed but Mark didn't specify if they were Mark1 or Mark2 dock parts?
#331128 - 19/03/2010 01:37 Re: Need a Docking Pin [Re: tfabris]
brax
Loc: Birmingham, AL
Thanks Tony. I just ordered a couple of digikey.
Edited by brax (19/03/2010 01:37)
#331143 - 19/03/2010 17:43 Re: Need a Docking Pin [Re: brax]
Were you able to determine if the digikey parts were for the Mark1 player or the Mark2 player?
#333027 - 17/05/2010 02:27 Re: Need a Docking Pin [Re: tfabris]
brax
Loc: Birmingham, AL
I ended up ordering both the H10085-ND and the H10087-ND. They were cheap and figured that since I was ordering I might as well and get a couple of both the power and the signal pins. I think these may be for the Mk1 because the H10087-ND did not look like mine. However it did work. I was able to crimp and add a little solder to the pin and it went in to my plug housing and fit in it very snug. Now both the left and right audio come in on the AUX input (hence the reason I am selling my tuner module now that I can get my HD Radio to come in again).
So long story short the singal terminal part number H10087-ND worked. I don't have any issues with the power (larger ones) so not sure about those. And to be honest I did not really even compare the ones in the sled to the ones I got from digikey.
