#322297 - 17/05/2009 01:06
Need help diagnosing tuner problems
A while back, my tuner reception went bad, and I'm trying to figure out what might be going on. The symptoms are:
1. FM reception on most channels is non-existent, but on a few channels, it's quite clear. 2. The FM channels that come in clear now are ones that I don't remember being very strong before. 3. Channels that were strong before are 100% static now. 4. AM reception is very poor, with high pitched whining on all channels. 5. Behind the high pitched whining, I can hear some of the stronger channels, but just barely. 6. The change from good reception to horrible reception seemed to happen overnight. One day I could listen to dozens of AM and FM stations, the next day almost all of them are static.
I pulled my dash apart tonight to see if it was an antenna connection problem, but couldn't find anything wrong. As I jiggled the antenna around I could get a tiny bit of signal on some channels that weren't coming in previously, but the improvement was almost negligible. The red light on the back of the tuner was on, and the tuner seems to be operational other than the horrible reception.
Anyone know what might be going on? Would a replacement tuner module solve the problem?
#322301 - 17/05/2009 08:07
Re: Need help diagnosing tuner problems
[Re: tonyc]
I would guess that more likely it's a bad antenna connection or bad antenna ground.
#322347 - 18/05/2009 13:50
[Re: Shonky]
How would I go about confirming this diagnosis? I should note that if I disconnect the antenna wire from the tuner module, reception gets *way* worse -- so it's not like the antenna connection is completely dead.
One other data point I discovered today is that on the AM dial, no matter what station I select, I get a faint signal of one particular station at 1020 kHz. That station happens to be the strongest in my area, but I find it strange that I can hear it even if I go all the way to 1400 kHz I can still hear that same station.
My antenna is in my car's glass, if that makes any difference...
Edited by tonyc (18/05/2009 13:51)
#322358 - 18/05/2009 15:40
[Re: tonyc]
I disagree with Shonky. I don't think it's a bad antenna connection. It sounds like bad wiring between the empeg and the tuner, or a bad tuner.
Double check that you haven't lost any wiring connections between the tuner and the empeg, then start going down the "bad tuner module" diagnosis road. Heck, I'd just say send Stu the module right now. Or, if you happen to know a local empegger, have them bring over their module for a test swap.
#322376 - 19/05/2009 04:45
Since he's getting diode detection of the strongest AM station, I don't think it's in the external wiring. It's something in the tuner.
#322387 - 19/05/2009 12:06
[Re: tonyc]
This sounds like the classic tuner death syndrome that afflicts factory tuners. There's a tiny IC (op-amp?) inside the sealed RF module that dies for whatever reason, and the result is nearly always static on FM, and sometimes reception on AM.
I've been addressing that by replacing the RF module with the one used by PCATS tuners, with a bit of pin hackery.
If this is what's really wrong with tonyc's radio, then that's probably the only option for repair. A full PCATS kit might be an even better option, since most of the cost is in the RF module.
Edited by mlord (19/05/2009 12:08)
#322405 - 19/05/2009 17:32
Yeah, if that's the case, I'm going to have to order an assembled PCATS kit. Is anyone stateside still building them, by any chance, or do I have to order from the UK and deal with expensive shipping?
#322408 - 19/05/2009 17:53
[Re: tonyc]
Definitely (re-)test it, by disconnecting the car antenna from it, and using a long length of wire as a temporary antenna instead. Household 14AWG romex works fine, as does a paperclip in my office here.  Cheers
#322425 - 20/05/2009 02:22
All I had handy was 12AWG Romex. I connected it tonight and got marginally more signal than no antenna at all (well, the static was louder, anyway), but couldn't actually get any stations, FM or AM. With the car's antenna, I'd at least get a bit of signal on a couple stations as described above.
Is this what you'd expect from a defective tuner?
#322427 - 20/05/2009 02:33
[Re: tonyc]
#322468 - 21/05/2009 13:45
Loc: Champaign, IL
I wonder if that's not what's wrong with mine. I still get stations both local and 50miles (80km) away.
I just show no signal strength even though RDS even pops up.
I will add that the Stereo indicator blinks out a lot (but only shortly. Like a 98/2 on/off duty cycle..
-Ben
p.s. Sealed, eh? Maybe I should take a looky. Anyone know what chip is under there?
#322469 - 21/05/2009 13:47
Loc: Champaign, IL
OH! Wait - it's in the RF section? Probably a gain-stage.
(not as much an op-amp as it is a common-emitter style gain block.)
I'm gonna crack open my tuner and take a look asap. THAT could definitely be the failure mode I'm dealing with right now.
-Ben
#322470 - 21/05/2009 13:56
[Re: benjammin]
I'm gonna crack open my tuner and take a look asap. THAT could definitely be the failure mode I'm dealing with right now Open up the radio, but not the sealed RF tuner module. Instead, you can probe on the pins from it to see if this is really the problem or not. You'll have to poke at the datasheet for the RF module (microtune 1384 ufc/wfc, or 1385 ufc) to see which pins mean what, but I could get FM audio from an earlier output when probing around the dead component. Eg. on the 1384wfc, pins 15-18 -- one of those had (muxed) audio, but the final output did not. Thus the failed component was between those two pins, whichever two they were. Cheers
Edited by mlord (21/05/2009 13:59)
#322473 - 21/05/2009 14:17
Loc: Champaign, IL
Gah. I hate google sometimes. Anyone (Mark?) have the datasheet handy? I have the 1385 unit. -Ben
#322543 - 26/05/2009 02:17
Loc: Champaign, IL
ok, I'll let you know what I find.
I'm going to desolder the top tonight.
-Ben
#322545 - 26/05/2009 03:34
[Re: benjammin]
Loc: Champaign, IL
Hey -- this Chip (TEA6848H) can tune US Weather band! Does anyone know if this capability is available down the line? That would be so cool if the Empeg could still do this.  -Ben
#322546 - 26/05/2009 03:45
[Re: benjammin]
Does anyone know if this capability is available down the line? That would be so cool if the Empeg could still do this. Not all of the empeg tuners supported weather band. Some of the production ones and some of the PCATS ones were US weather band capable but not all of them. If you can write something to send the proper commands to the tuner via the serial port then it'd work.
#322548 - 26/05/2009 04:20
[Re: benjammin]
Yeah, the weather band thing was discussed on this BBS before. They never put it into the software because of what was already mentioned: Not all of the tuner modules had that available.
#322549 - 26/05/2009 04:39
Loc: Champaign, IL
Bummer.
Anyway - From what I can see, my pinout is different from the one you provided Mark. (although I appreciate the post)
Is there a thread on here that describes the operation of the radio module (as a whole) with the tuner module? I see the tuner is I2C based.. and I see the radio PCB has a PIC16C73B on there. What's it's purpose?
From what I can tell, there's no (with Mark's info and what I'm seeing on this IC) that there's no L/R output for Stereo. So I'm guessing that's being done elsewhere...
I'd love to hear some expert info since I'm just tearing into this for the first time.
#322556 - 26/05/2009 10:55
[Re: benjammin]
The empeg DSP does the FM MPX decoding.
The PIC converts serial commands from the empeg unit into I2C commands for the tuner module. Documentation on the tuner module is/was floating around the forum at some point.
Mark's pinout is for the tuner module and not the chip inside.
#322575 - 26/05/2009 14:34
[Re: tman]
Loc: Champaign, IL
The empeg DSP does the FM MPX decoding. Mark's pinout is for the tuner module and not the chip inside. That part I got... and I'm saying.. it's different from the module I have in my hand. I can with absolute certainty that RF_IN in pin 1 while RF (and Pwr) Ground is on pins 2 and 5. While the power supply is connected to 3 and 4. Mark's list shows 22 pins, my module only has 16. That tells me enough right there to know there's something different going on. Thanks for your input though. It all helps form the "picture" a little faster.  -Ben
#322577 - 26/05/2009 14:43
[Re: benjammin]
I can with absolute certainty that RF_IN in pin 1 while RF (and Pwr) Ground is on pins 2 and 5. While the power supply is connected to 3 and 4. Mark's list shows 22 pins, my module only has 16. Datasheet for Temic 1384. I can't find the datasheet for the Temic 1385 that you have but I assume its the same as it matches up with what you saw. Not sure what Mark posted.
#322579 - 26/05/2009 14:59
[Re: benjammin]
Loc: Champaign, IL
I found a datasheet for the 1384 UFC.... and it more closely matches the first sets of pins (and the number) of my module.
(thanks for the link, but I already downloaded the same thing. Hilarious)
Anyway - I see now.. the 1834/1385UFC (what I have) has 16pins while the -WFC module has the >16pins...
Moving along....
-Ben
#322583 - 26/05/2009 15:15
[Re: benjammin]
Anyway - I see now.. the 1834/1385UFC (what I have) has 16pins while the -WFC module has the >16pins... I've not got a tuner module handy at the moment but the PCATS tuner construction manual shows it having a 1385UFC 3x0197 that has 22 pins...
#322585 - 26/05/2009 15:21
[Re: tman]
Basically, you're on your own. It *should* work but nobody has done it. Patrick and Hugo never mentioned anything about the PIC not being able to passthrough the necessary commands to the tuner.
#322590 - 26/05/2009 15:56
[Re: tman]
Loc: Champaign, IL
Anyway - I see now.. the 1834/1385UFC (what I have) has 16pins while the -WFC module has the >16pins... I've not got a tuner module handy at the moment but the PCATS tuner construction manual shows it having a 1385UFC 3x0197 that has 22 pins... Wow - so there's no rhyme or reason. Nice. Well -- I'm gonna crack out my Comm analyzer next, but the prelim numbers from a really strong nearby station show me: Audio @ FM-MPX: ~1.5Vp-p (sounds good - manual lists 75KHz=606mV (I'm assuming peak and not p-p)) Level Output: 3.43V (how many bars does the empeg show that as? and I'm assuming that's reported by the PIC on the Tuner Module? and the 1384ufc datasheet states 0-7VDC for the range with 3.3V = 100uV ) If I turn on the scope's FFT, I show the S/N being pretty darn good. (It's fun looking at the spectrum of an FM signal) When I get my comm analyzer hooked up, I'll edit this with a real SignalIn = Level reading.
Description: 1835 UFC - FM_MPX Output
#322630 - 26/05/2009 19:10
[Re: tman]
I've not got a tuner module handy at the moment but the PCATS tuner construction manual shows it having a 1385UFC 3x0197 that has 22 pins... Yeah, the PCATS radios use RF modules with more pins than the factory tuners -- a superset of pins, actually. And there's some mislabelling somewhere for the factory modules -- I seem to recall that the number on the module doesn't match the datasheet number/name. But it looks as if he's got it sorted now. Cheers
#322641 - 26/05/2009 20:58
Loc: Champaign, IL
Ok, then... it seems my tuner module is working ok. It's putting out voltages on Level pin that make sense for a given input. (i.e. it's maxing out while my display still shows no bars of signal.) So if the PIC is reporting that level via serial port, something broke there. If the receiver is reporting the signal via I2C -> RS232, something's broken there. I'm going to solder my receiver back in more fully.  -Ben
