Page 2 of 5 < 1 2 3 4 5 >
#319043 - 10/02/2009 19:49 Re: how "stalk" works? [Re: Boelle]
Do you have a specific need to run the alpha software? Perhaps it has a previously unreported bug in the Stalk code.
I'd be curious to know if the stalk worked OK with the 2.0 final software.
#319045 - 10/02/2009 19:53 Re: how "stalk" works? [Re: tfabris]
Boelle
Loc: Denmark, Odense
need the auto eq at some point.... but need to get a very good mic
#319046 - 10/02/2009 19:58 Re: how "stalk" works? [Re: Boelle]
So you'd be OK to run 2.0 final for a while, then? I'd say try that and see if the stalk works. Remember that when switching back and forth between 3.0 Alpha and 2.0 Final, you might have to rebuild the databases manually. At least I remember having that problem.
#319047 - 10/02/2009 20:10 Re: how "stalk" works? [Re: tfabris]
Boelle
what about bens fan controller... do that run under 2.0 ?
#319048 - 10/02/2009 20:14 Re: how "stalk" works? [Re: Boelle]
I don't know for sure, but I'd hope that anyone designing an add-on for the player would intend for it to work under the most common configuration.
#319049 - 10/02/2009 20:15 Re: how "stalk" works? [Re: tfabris]
Boelle
but i will try the 2.01 final first and then hit the car... which is covered in a heavy layer of snow
#319050 - 10/02/2009 20:20 Re: how "stalk" works? [Re: Boelle]
Boelle
one way could be to use the alpha ver. to get the values for EQ.. and then go back to 2.01
#319051 - 10/02/2009 20:35 Re: how "stalk" works? [Re: Boelle]
Boelle
at least it did the rebuild in less than 1 min. so one step saved
#319052 - 10/02/2009 20:47 Re: how "stalk" works? [Re: Boelle]
Boelle
just opened emplode to check that stalk was enabled... but i want to do a disk check....
while i wait i was remembering one of the new features of hijack... to select boot logo... i selected the original one where the penguin waves at you... but i always displays the hijack default one...
#319053 - 10/02/2009 21:10 Re: how "stalk" works? [Re: Boelle]
Boelle
2.01 without hijack did not do the trick....
#319054 - 10/02/2009 21:21 Re: how "stalk" works? [Re: Boelle]
Boelle
2.01 with newest hijack same thing... stil only the seek/ams ring that changes the visuals... but a display codes it gives different codes for each button
#319055 - 10/02/2009 21:24 Re: how "stalk" works? [Re: Boelle]
Your post of the config.ini contents showed the stalk as correctly enabled.
Thank you for going to all the trouble of installing the 2.0 firmware. I am stumped as to why it's not working. Anyone else have any ideas?
#319056 - 10/02/2009 21:28 Re: how "stalk" works? [Re: tfabris]
Boelle
i did an extra check... would be rather stupid to get to the car and back to discover i had it disabled again
could it be the model of the stalk? i have read that there is 2 models...
also i cant get out of my mind that i cant select boot logo.. i can in hijack but it does not "remember" what i select
#319057 - 10/02/2009 21:47 Re: how "stalk" works? [Re: Boelle]
As long as it's an RM-X4S or an RM-X2S, you should be fine. Even so, your Button Codes Display seemed to show the correct value, meaning that the stalk is sending the correct signal to the player, so I'm wondering what's up.
You can put any boot logo you want into place with Jemplode. The original 2.0 software boot logo is here and can be installed to the player via Jemplode.:
http://empeg.miniinfo.net/anilogo/515.raw
#319058 - 10/02/2009 21:55 Re: how "stalk" works? [Re: tfabris]
Boelle
it said that animation upload failed.... do it upload via network or serial?
regarding the stalk i'm 100% sure it,s one of the 2... i will get the model number in 1 sec
#319059 - 10/02/2009 21:56 Re: how "stalk" works? [Re: Boelle]
Boelle
Sony RM-X2S Stalk
#319060 - 10/02/2009 21:59 Re: how "stalk" works? [Re: Boelle]
I'm pretty sure that Jemplode uses ethernet to install custom boot animations.
#319061 - 10/02/2009 22:08 Re: how "stalk" works? [Re: tfabris]
Boelle
it had a password set for ftp.. so now it works
#319062 - 10/02/2009 22:10 Re: how "stalk" works? [Re: Boelle]
Boelle
but i think i better get to bed... have to get up in around 6 hours... but backagain in something like 10-11 hours
#319063 - 10/02/2009 22:18 Re: how "stalk" works? [Re: Boelle]
Hopefully when you wake up someone will have figured out the stalk problem and posted a solution for you. I'm stumped: the thing should just be working.
#319064 - 10/02/2009 23:01 Re: how "stalk" works? [Re: tfabris]
AndrewT
Loc: Oxford, UK
We have yet to see the entire config.ini in one post, so far we've seen it broken into two sections.
Bo, post the entire config.ini here just to be certain.
#319066 - 10/02/2009 23:36 Re: how "stalk" works? [Re: AndrewT]
I thought the most recent post of config.ini *was* the entire file. He removed all ir_translate data and reposted the whole file. It looks fine to me. I might be missing something though.
#319076 - 11/02/2009 01:46 Re: how "stalk" works? [Re: tfabris]
No, he actually has never shown us the real config.ini file, and I really cannot help any further until he does.
As evidence, he recently said he had an FTP password set -- no sign of that in the config.ini's that were posted.
#319084 - 11/02/2009 05:07 Re: how "stalk" works? [Re: mlord]
Boelle
ftp was in jemplode.. not in the ini
the last ini was the COMPLETE ini
#319085 - 11/02/2009 05:10 Re: how "stalk" works? [Re: Boelle]
Boelle
[Network]
Gateway=192.168.1.1
Netmask=255.255.255.0
IPAddress=192.168.1.11
DHCP=0
[synchronise]
seq_num=40
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[Options]
Name=Empeg
[controls]
stalk_side=right
[User Info]
Email=
Phone=
Name=Tina Andersen & Bo Herrmannsen
[display]
play_count=1
visual_names=1
caching=1
[kenwood]
disabled=0
[menu]
quit=0
sort_playlist=1
[shuffle]
deduplicate=1
[sense]
muteaction=0
mute=-1
[power]
off_timeout=60000
[hush]
hushpercent=20
[volumecap]
enabled=0
[ramp]
disabled=0
[tuner]
region=europe
[aux]
source=
title=
artist=
[hijack]
decimal_fidentry=1
;@MENUEXEC Set_Date_Time /rdate -s 192.168.1.1 &>/dev/null
temperature_correction=0 ;; default is -4
fan_control=1
fan_low=16
fan_high=21
#319096 - 11/02/2009 12:55 Re: how "stalk" works? [Re: Boelle]
Okay, that config.ini works fine in a player here, thanks.
So, the very obvious thing to do next is (always) to post a serial port trace from while trying to use the stalk. If anything is ever wrong with an empeg, there is almost always some useful information there.
In this case, I am betting that some components somewhere are slowly aging, and the A->D conversions of stalk values are showing up as out of range ("Stalk: no match for value=0xXX").
So you may need to fine tune the conversion scale, by adding/modifying these lines in config.ini:
[hijack]
;; Min/max A/D pairs for all ten buttons on a Right mounted Stalk
;; Button order is:
;;KOff,KSource,KAtt,KFront,KNext,KPrev,KVolUp,KVolDown,KRear,KBottom
;; Here are the built-in factory defaults for a Right-Hand-Side stalk:
stalk_rhs=0x00,0x07,0x10,0x1c,0x24,0x30,0x34,0x40,0x42,0x4e,0x54,0x60,0x68,0x74,0x7e,0x8a,0x94,0xa0,0xa0,0xb5
More info available here.
Edited by mlord (11/02/2009 17:12)
#319127 - 11/02/2009 16:55 Re: how "stalk" works? [Re: mlord]
Boelle
how do i do a serial port trace? might as well get it done
#319128 - 11/02/2009 17:01 Re: how "stalk" works? [Re: Boelle]
Connect with hyperterminal or some other terminal program. This part is going to be tricky because, since we want the serial traces from actual stalk activity, and the stalk hooks to the tuner module, and the tuner module can only connect to the car docking sled, then it will require the car docking sled and the computer to be in the same room.
Select "Transfer, Capture Text" in Hyperterminal to begin creating the log file.
Apply power to the player. Allow it to boot. Try some stalk commands.
Select "Transfer, Capture Text, Stop" when you have captured the desired activity.
Always do the capture-to-file thing. Do not try to do a cut-and-paste from the hyperterminal main window, it's got a bug that messes up the order of lines and characters when you copy from its main window.
#319129 - 11/02/2009 17:14 Re: how "stalk" works? [Re: Boelle]
Another way to check things, not involving us here, would be to just use the Hijack Button Code Display screen. Press each stalk button in turn, and compare the reported stalk value (from the display) with the min/max pairs for that button in the config.
The bet here is that some of them are "out of range", and the min/max ranges will require adjustment to compensate.
But if they show up as "in range", then we'll need serial port traces to help you further.
#319130 - 11/02/2009 17:15 Re: how "stalk" works? [Re: mlord]
I had him do that for the "next track" button (i.e., the "seek +" button) up above, and it came out as "5b" which according to the developer info section, is the correct value for seek+.
