#319131 - 11/02/2009 17:16
Re: how "stalk" works?
For example, the button on the end of the stalk is the KSource button. It should always be generating codes within the range 0x10 - 0x1c, preferably 0x16 (mid-range).
If not, then add the config.ini lines shown earlier, and modify the range to match what the button is really doing.
Edited by mlord (11/02/2009 17:17)
#319132 - 11/02/2009 17:22
I had him do that for the "next track" button (i.e., the "seek +" button) up above, and it came out as "5b" Yeah, I saw that. Part of the problem here is that we have a guy who has never used a working stalk before, so things will be very confusing for him. And he may not notice when things actually work or not. So, perhaps he could also report here exactly what each button generates on the display, going through all of the buttons 2-3 times to get an average. Cheers
Edited by mlord (11/02/2009 17:22)
#319134 - 11/02/2009 17:36
Loc: Denmark, Odense
damn... i only have the cable that came with the player
#319136 - 11/02/2009 17:40
i can do that, in an hour or so, it's dinner time here
Edited by Boelle (11/02/2009 17:46)
#319137 - 11/02/2009 17:41
[Re: Boelle]
damn... i only have the cable that came with the player I *think* the hole in the bottom rear of the sled makes enough room to use the regular serial port that's built in to the player. Check and see.
#319138 - 11/02/2009 17:48
damn... i only have the cable that came with the player I *think* the hole in the bottom rear of the sled makes enough room to use the regular serial port that's built in to the player. Check and see. not in an peogeot 106. like max 5mm space around the sled
#319146 - 11/02/2009 19:30
[Re: Boelle]
source=0x16 vol+=0x88 vol-=0x71 seek+=0x5c seek-0x4a off=0x02 mute=0x2b
and the 3 buttons seen from above with the stalk standing flat on a table.. and the two that side next to each other closeest to you..
single button= 0xb0 left one=0x9b right one=0x3b
#319153 - 11/02/2009 20:09
[Re: Boelle]
Looks like it is all working normally.
#319156 - 11/02/2009 20:20
yeah.. i cant get it either. the next problem is serial port trace.. it will take some days before i can do it since i have to route a flat cable from the sled's db9 connector.. only way i can do a trace right now is to get the sled out of the dash
#319158 - 11/02/2009 20:24
[Re: Boelle]
.. or get an ethernet connection into the dash, if that's any easier. The serial port messages could then be retrieved via FTP, I believe.
#319163 - 11/02/2009 20:44
no, it's the same trouble.. but i think i can get some connectors and cable by sunday...
is there any further test's i can do?
#319227 - 12/02/2009 22:55
[Re: Boelle]
was there no other chioce than serial or network to do the serial trace? or other test that i can do?
#319228 - 12/02/2009 22:56
[Re: Boelle]
#319229 - 12/02/2009 23:01
ok... so i will aim for a serial port
how should i wire the 2 db9 connectors.. from my pc to the sled connector?
#319230 - 12/02/2009 23:23
[Re: Boelle]
like this?
1+6 ------------ 4 (1 and 6 to 4) 2 -------------- 3 (2 connected to 3) 3 -------------- 2 (3 connected to 2) 4 -------------- 1+6 (4 connected to 1 and 6) 5 -------------- 5 (5 connected to 5) 7 -------------- 8 (7 connected to 8) 8 -------------- 7 (8 connected to 7)
#319253 - 13/02/2009 11:30
[Re: Boelle]
Connect *only* the Tx, Rx, and GND pins (3-wires). Ignore the rest of them.
#319258 - 13/02/2009 12:01
ok... but i will report back some time this sunday.... around 20:00 CET i guess
#319329 - 15/02/2009 15:51
[Re: Boelle]
i just soldered a cable... but will the sleds serial work along with the players serial when in the car?
#319331 - 15/02/2009 16:05
[Re: Boelle]
i just soldered a cable... but will the sleds serial work along with the players serial when in the car? The sled serial port and the serial port on the back of the empeg unit are the same port. One is wired DCE and one is wired DTE.
#319334 - 15/02/2009 16:13
[Re: tman]
so if i use the serial on the player while it's docked in the car I just have to cross the wires from pin 2 and 3 ?
just aksing to make sure i dont blow anything up
#319348 - 15/02/2009 19:21
[Re: Boelle]
done the serial trace... but nothing happens in putty when i use the stalk... nor when i use the front panel.. log attached
putty.log (248 downloads)
#319353 - 16/02/2009 01:29
[Re: Boelle]
Okay, add this to the [hijack] section in config.ini, and then get another serial port trace. This time it *will* have stuff in it:
stalk_debug=1
#319359 - 16/02/2009 06:24
No problem... will be around the same time.. have to "steal" the power at an outdoor outlet...
#319380 - 16/02/2009 18:39
[Re: Boelle]
new log...
and when pressing any button on the stalk the sound is stuttering and ful of clicks...
but strange that the end of the log is just one big space.. but nothing happend on screen
putty.log (220 downloads)
Edited by Boelle (16/02/2009 18:42)
#319381 - 16/02/2009 18:52
[Re: Boelle]
btw.. my config.ini... just to make sure
[Network] Gateway=192.168.1.1 Netmask=255.255.255.0 IPAddress=192.168.1.11 DHCP=0 [synchronise] seq_num=41 [wendy] flag_amount=0 [custom] wendy= [searches] amount=0 [VisualFavourites_AM] count=0 [VisualFavourites_AUX] count=0 [VisualFavourites_DSP] count=0 [VisualFavourites_FM] count=0 [Options] Name=Empeg [controls] stalk_side=right [User Info] Email= Phone= Name=Tina Andersen & Bo Herrmannsen [display] play_count=1 visual_names=1 caching=1 [kenwood] disabled=0 [menu] quit=0 sort_playlist=1 [shuffle] deduplicate=1 [sense] muteaction=0 mute=-1 [power] off_timeout=60000 [hush] hushpercent=20 [volumecap] enabled=0 [ramp] disabled=0 [tuner] region=europe [aux] source= title= artist= [hijack] stalk_debug=1 decimal_fidentry=1 ;@MENUEXEC Set_Date_Time /rdate -s 192.168.1.1 &>/dev/null temperature_correction=0 ;; default is -4 fan_control=1 fan_low=16 fan_high=21
#319382 - 16/02/2009 19:18
[Re: Boelle]
Your player is doing the "change the baud rate midway through startup" thing that they do by default when in a car.
Fix it with this, in config.ini, then try again. This might even fix the stalk, too, now that ya mention it..
[serial] car_rate=115200 ; Set default rate when on DC to 115kbps
Edited by mlord (16/02/2009 19:19)
#319383 - 16/02/2009 19:20
no special place to but this?
#319384 - 16/02/2009 20:07
[Re: Boelle]
i added it just before hijack... now the click/stutter is away... but it's too late to start the car just to drive and do the serial trace...
The stalk itself has not changed
#319445 - 17/02/2009 17:07
[Re: Boelle]
now here it is.. i startede by pressing source.. then vol+,vol-,track+,track-
then the buttons.. off first, the 3 when seen from above and lastly mute...
putty.log (249 downloads)
#319454 - 17/02/2009 20:28
[Re: Boelle]
It still all looks normal. Stalk: in=02 01 ff 00 == no button
Stalk: in=02 01 16 17 == 00000031
Stalk: out=02 01 16 17 == 00000031
Stalk: in=02 01 ff 00 == 80000031
Can you use the Radio with this player (eg. does the radio work?)? For some reason, the player software is ignoring the stalk buttons. This generally happens only if the radio is not detected, or if the config.ini file says to disable the stalk. Does this make the button on the end of the stalk work? [ir_translate] KSource=Source
Edited by mlord (17/02/2009 20:32)
