Page 2 of 2 < 1 2
#318910 - 06/02/2009 23:09 Re: linux only hard drive upgrade? [Re: tfabris]
ajayrockrock
Loc: Riverside, CA
wow, I'm glad this thread is continuing! It took a few days but I finally got my replacement serial cable. And my "cat /dev/ttyS0" stuff did work. All it did was print out some garbage which was enough to tell me that it's active.
I couldn't get it to work via virtualbox so I grabbed the upgclient and yeah, that doesn't work either:
$ ./upgclient  Windows_Share/builder_bigdisk_v4.upgrade
empeg-car Upgrade client.
empegupgrade: Using upgrade file 'Windows_Share/builder_bigdisk_v4.upgrade' to device '/dev/ttyS0' (115200 baud)
 Checking upgrade file integrity                                        [100%]
Pumping player software
 Finding unit                                                           [  2%]
Upgrading flash (bootloader)
 Erasing flash                                                          [  0%]
 ERROR: 8 Flash erase failed
 Upgrade aborted due to errors                                          [  0%]
Upgrade failed :-(
Upgrade failed with error 0x80040057
Any ideas?
#318911 - 06/02/2009 23:15 Re: linux only hard drive upgrade? [Re: ajayrockrock]
Attack
Loc: Florida
I think you have to plug in the Empeg power when it says "Finding Unit", but I could be wrong.
Chad
#318912 - 06/02/2009 23:17 Re: linux only hard drive upgrade? [Re: ajayrockrock]
ajayrockrock
Loc: Riverside, CA
just for the hell of it, I grabbed the v3alpha one that was posted and got similar results:
$ ./upgclient.static ../../Windows_Share/builder_bigdisk_v4.upgrade
empegupgrade: Using upgrade file '../../Windows_Share/builder_bigdisk_v4.upgrade' to device '/dev/ttyS0' (115200 baud)
 Finding unit                                                           [  1%]
   connection_all.cpp: 155 (2000): Connection::FlushReceiveBuffer throwing away...0x84b843d: 0d 0a 30 30.39 61 32 33|30 34 0d 0a.33 61 37 61    ..009a2304..3a7a
0x84b844d: 38 33 65 39.0d 0a 34 35|31 38 61 62.36 30 2d 37    83e9..4518ab60-7
0x84b845d: 62 35 62                                           b5b
   connection_all.cpp: 155 (2000): Connection::FlushReceiveBuffer throwing away...0x84b8439: 65 64 35 2d.33 64 64 37|61 66 30 38.2d 64 33 36    ed5-3dd7af08-d36
0x84b8449: 65 65 34 39.32 0d 0a 30|30 0d 0a 30.30 0d 0a 3f    ee492..00..00..?
0x84b8459: 75                                                 u
Upgrade failed :-(
Same error code though... Do you guys know what 0x80040057 means? Google doesn't really give me any results except for this thread:
http://empegbbs.com/ubbthreads.php?ubb=showflat&Number=46154
Edited by ajayrockrock (06/02/2009 23:20)
#318915 - 07/02/2009 07:53 Re: linux only hard drive upgrade? [Re: Attack]
ajayrockrock
Loc: Riverside, CA
Yup, I waited until the "Finding Unit" prompt before I plugged in the power.
--Ajay
#318916 - 07/02/2009 12:57 Re: linux only hard drive upgrade? [Re: ajayrockrock]
This all means that you'll be needing a real hardwired serial port
with that software, rather than a USB serial adapter.
#318923 - 08/02/2009 08:07 Re: linux only hard drive upgrade? [Re: mlord]
ajayrockrock
Loc: Riverside, CA
Yeah, I have a real hardware serial adapter connected to my empeg. Any other ideas?
--Ajay
PS. I've had an empeg since 2002 and I'm so excited to be in a thread with mlord. smile
#319008 - 10/02/2009 04:27 Re: linux only hard drive upgrade? [Re: ajayrockrock]
Hmm, I mean there's nothing particularly special about the protocol (timing-wise) - the only time critical bit is interrupting the bootloader at the right moment.
ISTR there is no problem driving the erase commands (etc) interactively... which points to a problem with the upgrader code which is making it susceptible to differences? Does anyone have the code unzipped so they can post the relevant section?
#319013 - 10/02/2009 10:32 Re: linux only hard drive upgrade? [Re: altman]
The main difference in Mark's "USB-compatible" version seems to be that it buffers up the outgoing data and then sends it in one system call -- the stock download.c sends it a byte at a time.
The only theory I have as to how this could possibly make a difference, is if somehow the USB-to-serial adaptor can't saturate 115200bps transmit if it's only getting one byte per USB packet. (Perhaps, when driving it interactively, the terminal is line-buffered.) But actually I can't make the numbers for that add up, even for a USB-to-serial adaptor that's Low Speed 1.5Mbps.
#319014 - 10/02/2009 10:54 Re: linux only hard drive upgrade? [Re: ajayrockrock]
*Sigh* Looking at the Emptool sources, 0x80040057 is UPG_E_SOMETHINGBAD, the associated error message being "Something bad happened". blush
Upgrader::ErasePage() has failed for some reason, but the exact error code (which would have allowed us to determine whether you have a connection problem, or a player problem) is thrown away and replaced by meaningless generic ones twice before being reported to the user. eek
#319015 - 10/02/2009 11:58 Re: linux only hard drive upgrade? [Re: peter]
Yeah, without that buffering, downloads take *hours* rather than a minute or two. The other changes were to improve tolerance in delays on recept of ack's and the like from the empeg, though this obviously still needs work -- that's where the remaining timing dependencies still lurk.
#319017 - 10/02/2009 12:16 Re: linux only hard drive upgrade? [Re: mlord]
If that's the case, did your investigation ever reveal why? I'd love to know, however inefficient userland is, how come it's not saturating 115200bps over the serial link. On a modern PC, that's tens of thousands of CPU cycles per bit...
#319021 - 10/02/2009 14:28 Re: linux only hard drive upgrade? [Re: peter]
It was years ago, and I didn't dig too deeply.
But my impression was, that sending one or two bytes at a time,
through a packetized transport (USB), and waiting for it to complete
before sending the next one or two bytes.. kinda made sense that
throughput would be slow.
I don't think the USB serial stack uses windowed transport
like TCP does.
EDIT: Mmm.. some memory is returning now..
I think it might have been the bluetooth
serial dongles here that were the slowest before those mods
Edited by mlord (10/02/2009 14:35)
#319202 - 12/02/2009 16:40 Re: linux only hard drive upgrade? [Re: mlord]
ajayrockrock
Loc: Riverside, CA
Update, I have since installed Windows on a spare box and upgraded my empeg (now have 300gigs across 2 drives).
I still would like a linux-only way to upgrade my empeg in the future. So if anyone has any tips on getting this to work I'd be more then willing to test anything.
--Ajay, shopping for a new empeg-friendly car...
#319355 - 16/02/2009 04:40 Re: linux only hard drive upgrade? [Re: peter]
It's definitely not a line buffered type thing; the bootloader will wait forever for the next byte (no timeouts). My guess is that my possibly overzealous flushing of input buffers in the upgrader so as I don't have to parse the echo from the bootloader is falling over. Nobody ever does flush the way I like it (which is: zero the head/tail pointer at that instant) - which tends to get replaced by "read with zero timeout until you see empty" which I can see getting seriously upset by USB.
With that in mind, can anyone nearer the code look? If not I will fire up gcc and compile it on my macbook, find a usb-serial adaptor, and see what happens wink
#319356 - 16/02/2009 04:42 Re: linux only hard drive upgrade? [Re: mlord]
Depending on how janky the stack implementation is, the worst case could well be 1 byte per frame (1 millsecond). In reality, it should definitely get aggregated before that point, so even if the first byte takes a while millisecond to go out, the subsequent ones would at least fill a USB1 64-byte out packet.
Still, you can't argue with what actually happens in real life smile
Page 2 of 2 < 1 2
