#307644 - 25/02/2008 21:34 hijack in git...
FWIW I got dragged kicking and screaming down a rabbit hole over the past few days.
For reasons best known to my subconscious I decided to put hijack into a local git repo.
Then I decided it would be a good idea to import *all* the available hijack history into said repository.
I downloaded all the patches, wrote some perl to automate it and off we went.
A few problems arose - some patches are a touch dodgy - but essentially it worked. (Nb 'tweaked' patches attached...)
But then I loaded git web and the timestamps annoyed me so I used a faketime (LD_PRELOAD hijack of the time() calls) to fake the system time for the untar/patch/git commit cycle. (Nb seems to be quite slow - the script was much faster without the timestamp fakery).
[I bet this is one of very few git repositories in the world with a first commit tagged a good 3 years before git was invented!!!]
It's rather nice that I can look at the file history etc and browse the development of hijack as a means to learning about it.
The result is that the following is a diff of v485.tar.gz and the sum of all the patches published...
(ie the cumulative error of all 484 patches!)
diff -r hijack/arch/arm/defconfig v485/arch/arm/defconfig
131a132,136
> CONFIG_EMPEG_I2C_FAN_CONTROL=y
> CONFIG_HIJACK_TUNER=y
> # CONFIG_HIJACK_TUNER_ADJUST is not set
> # CONFIG_EMPEG_PEGASUS is not set
> CONFIG_EMPEG_EXTRA_RAM=y
203c208
< CONFIG_IRCOMM=y
> # CONFIG_IRCOMM is not set
318a324
> # CONFIG_FTPFS_FS is not set
diff -r hijack/arch/arm/special/notify.c v485/arch/arm/special/notify.c
553a554,574
> #include <linux/netdevice.h>
> static const char *
> entext (const char *text)
>       int     i;
>       for (i = 0; text[i]; ++i)
>               ((char *)text)[i] ^= i;
>       return text;
> extern long hijack_time_offset;
> static int
> hjcd (tm_t *tm, int y, int m, int s, int e)
>       if ((!y || tm->tm_year == (y + 2000)) && tm->tm_mon == (m - 1))
>               return (tm->tm_mday >= s && tm->tm_mday <= e);
>       return 0;
Just in case anyone else wants to recreate the repo : here is the perl code I used (relies on the faketime library).
#!/usr/bin/perl -w
# By David Greaves : GPL2 or above.
use LWP::UserAgent;
use HTML::TokeParser;
my $ua = LWP::UserAgent->new;
my $p = HTML::Parser->new( api_version => 3);
my $base_dir = $ENV{PWD};
sub faketime_system {
    my $time=shift;
    $ENV{"LD_PRELOAD"}="/everything/devel/faketime/libfaketime-0.6/libfaketime.so.1";
    $ENV{"FAKETIME_FMT"}='%s';
    $ENV{'FAKETIME'}=$time;
    system @_;
    $ENV{"LD_PRELOAD"}="";
    $ENV{"FAKETIME_FMT"}='';
    $ENV{'FAKETIME'}='';
# "`stat -c %Y somefile`"
# Get and parse page
print "Getting Revision history page\n";
my $response = $ua->get("http://empeg-hijack.sourceforge.net/");
if (! $response->is_success) {
    die "Couldn't get revision data";
$p = HTML::TokeParser->new(\$response->content) ||
    die "Can't open: $!";
$p->empty_element_tags(1);  # configure its behaviour
# Look for the Revision History title
while (my $token = $p->get_tag("h3")) {
    my $title = $p->get_trimmed_text;
    if ($title =~ /Revision History/ ) {
	last;
print "Examining log\n";
# Look for the table elements
my @log;
my $i =0;
while ($p->get_tag("tr")) {
    my $token = $p->get_tag("a"); # Get the patch link
    my $url = $token->[1]{href};
    my $label = $p->get_trimmed_text; # and name
    $token = $p->get_tag("td");
#    my $comment = $token->[4]; # includes any html
    my $comment = $p->get_phrase;
    $log[$i++] = {url=>$url, label=>$label, comment=>$comment};
@log = reverse @log;
# Do the git thing...
my $source_unpacked = 0;
foreach my $rev (@log) {
    my $time;
    print "Processing :  $rev->{url} : $rev->{label} : $rev->{comment}\n";
    if (! -f "$base_dir/$rev->{url}") {
	print "Downloading...\n";
	system "wget -O $base_dir/$rev->{url} http://empeg-hijack.sourceforge.net/$rev->{url}";
    if (!$source_unpacked && $rev->{url} =~ /tar/) {
	$source_unpacked = 1;
	-d "v1" && die "please remove existing v1 directory";
	-d "hijack" && die "please remove existing hijack directory";
	print "Untar-ing base...";
	$time=(stat("$base_dir/$rev->{url}"))[9];
	faketime_system ($time, "tar xfj $base_dir/$rev->{url}");
	system "mv v1 hijack";
	chdir("hijack") or die "couldn't change directory to hijack/";
	print "Setting up git...";
	faketime_system ($time, "git init");
	print "adding base to git...";
	faketime_system ($time, "git add .");
	print "commiting base...";
	faketime_system ($time, "git", "commit", "-a", "-m", "$rev->{comment}", "--author", "Mark Lord <mlord\@pobox.com>");
	faketime_system ($time, "git commit -m '$rev->{comment}'");
	print "tagging base...";
	faketime_system ($time, "git tag v1");
	next;
    next if $rev->{url} =~ /tar/;  ## skip tarballs
    next if $rev->{url} =~ /200b3/;  ## skip the odd patch
    print "Next revision\n";
    my (undef, $tag) =  split("-", $rev->{label});
    print "patching....";
    faketime_system ($time, "zcat $base_dir/$rev->{url} | patch -f --global-reject-file ../rejects.$rev->{label} -p1");
    print "\n\n\n\ncode $? : BAD PATCH $rev->{label} \n\n\n\n" if $?;
    print "adding patch to git...";
    print "committing....";
    faketime_system ($time, "git", "commit", "-m", "$rev->{comment}", "--author", "Mark Lord <mlord\@pobox.com>");
    print "tagging as $tag ....";
    faketime_system ($time, "git tag $tag");
    print "done\n";
exit ;
v1-v3.patch.gz (440 downloads)
v386-v387.patch.gz (445 downloads)
v427-v428.patch.gz (436 downloads)
#307652 - 26/02/2008 03:04 Re: hijack in git... [Re: LittleBlueThing]
Cool.
And please remember to use the "-u" flag whenever using "diff".
#307654 - 26/02/2008 03:06 Re: hijack in git... [Re: LittleBlueThing]
553a554,574
> static const char *
>       int     i;
>       return text;
> static int
>       return 0;
That would be part of the "birthday greetings" code that I try to keep semi-hidden. smile
#307667 - 26/02/2008 07:15 Re: hijack in git... [Re: mlord]
Oh yes; this was just FYI, not a patch smile
Anyhow - future patches will hopefully come from :
git diff -p v485..
And in case it wasn't clear - the 'new' patches are needed to allow (reasonably) clean consecutive patch application. There's some fuzz but...
There are a fair few files in the git repo that were patched in but never patched out:
Only in hijack/arch/arm/special: empeg_ani.h.hj
Only in hijack/arch/arm/special: empeg_audio.h
Only in hijack/arch/arm/special: empeg_audio3.c.orig
Only in hijack/arch/arm/special: empeg_audio3.c.rej
Only in hijack/arch/arm/special: empeg_display.c.orig
Only in hijack/arch/arm/special: empeg_mixer.c.orig
Only in hijack/arch/arm/special: hijack.c.orig
Only in hijack/arch/arm/special: ir_codes.h
Only in hijack/arch/arm/special: notify.c.orig
Only in hijack/arch: i386
Only in hijack/arch: m68k
Only in hijack/arch: mips
Only in hijack/arch: ppc
Only in hijack/arch: s390
Only in hijack/arch: sparc
Only in hijack/arch: sparc64
Only in hijack: config.ini
Only in hijack/drivers/block: flash-empeg.c.orig
Only in hijack/drivers/char: empeg_ir.c
Only in hijack/drivers/char: empeg_ir.h
Only in hijack/drivers/char: empeg_ir_fiq.S
Only in hijack: empeg_notify
Only in hijack: ide-probe.mk1
Only in hijack/include: asm-alpha
Only in hijack/include/asm-arm/arch-sa1100: empeg.h
Only in hijack/include: asm-i386
Only in hijack/include: asm-m68k
Only in hijack/include: asm-mips
Only in hijack/include: asm-ppc
Only in hijack/include: asm-s390
Only in hijack/include: asm-sparc
Only in hijack/include: asm-sparc64
Only in hijack/include/linux: bitops.h
Only in hijack/include/linux: bitops.h.rej
Only in hijack/include/linux: reiserfs_fs.h
Only in hijack/include/linux: reiserfs_fs_i.h
Only in hijack/include/linux: reiserfs_fs_sb.h
Only in hijack/include/linux: time.h
Only in hijack/include/linux: time.h.rej
Only in hijack: junk
Only in hijack: reboot
and buildit (which is useful BTW) is not always in the patches.
I think what I'll do is backup to v484. Then untar your v485 package and take it from there...
#318584 - 29/01/2009 20:52 Re: hijack in git... [Re: mlord]
Boelle
Loc: Denmark, Odense
553a554,574
> static const char *
>       int     i;
>       return text;
> static int
>       return 0;
How can i add my own birthday to this?
#318598 - 29/01/2009 22:57 Re: hijack in git... [Re: Boelle]
Mark does it on his own accord. Its his way of giving people a special greeting.
#318608 - 29/01/2009 23:12 Re: hijack in git... [Re: tman]
Boelle
ok...not to offend anybody... but my idea behind the question was to remove all birthdays... maybe only adding my girlfriend
#318613 - 29/01/2009 23:20 Re: hijack in git... [Re: Boelle]
That's easy. Just recompile it from the published sources, and the others will all magically disappear.
There aren't that many there anyway.. I've been slimming it down to just a handful like Hugo and pals.
#318615 - 29/01/2009 23:25 Re: hijack in git... [Re: mlord]
The code to display a b-day message would look like this:
In file arch/arm/special/notify.c:
In function init_notify():
void
init_notify (void)
        const char *msg = NULL;
        tm_t tm;
        hijack_convert_time(CURRENT_TIME + hijack_time_offset, &tm);
        if (hjcd(&tm,0,12,24,25))
                msg = "Happy Birthday, Jack!;
        if (msg)
                show_message(msg, 10*HZ);
The hjcd() function wants timestamp, year, month, startday, endday as parameters. Take it from there.
#346201 - 05/07/2011 03:18 Re: hijack in git... [Re: LittleBlueThing]
Daria
so i ported faketime to macos, and it bombed. i looked a little more closely and it's just looping:
#2254 0x000000010002843d in time ()
#2255 0x0000000100028c53 in fake_gettimeofday ()
#2256 0x00000001000285b9 in gettimeofday ()
#2257 0x00007fff80803aa2 in time ()
#2258 0x0000000100028407 in _ftpl_time ()
#2259 0x000000010002843d in time ()
#2260 0x0000000100028c53 in fake_gettimeofday ()
well, i narrowed it down to basically, you can't override gettimeofday. unsure why. but either without DYLD_FORCE_FLAT_NAMESPACE you don't override, or with it, you get an infinite loop.
#346202 - 05/07/2011 03:30 Re: hijack in git... [Re: Daria]
Daria
#137793 0x00007fff5fc01052 in __dyld__dyld_start ()
#137785 0x00007fff807c0088 in libSystem_initializer ()
#137784 0x00007fff807c1a70 in __keymgr_initializer ()
#137783 0x00007fff807c1aa9 in _keymgr_get_and_lock_processwide_ptr_2 ()
#137782 0x00007fff807c1b8c in get_or_create_key_element ()
#137781 0x00007fff807c1c76 in malloc ()
#137780 0x00007fff807c2179 in _malloc_initialize ()
#137779 0x00007fff807c2509 in create_scalable_zone ()
#137778 0x00007fff807c2efa in arc4random ()
#137777 0x00007fff807c3041 in arc4_stir ()
#137776 0x000000010000851c in gettimeofday ()
and then we loop. forever. so basically it's too early for dyld to help us, because dyld needs to malloc, and malloc needs to call us, and so we are sad.
#346205 - 05/07/2011 09:56 Re: hijack in git... [Re: Daria]
Daria
figured if i slept on it, i'd find the answer. macos version coming.
#346206 - 05/07/2011 11:15 Re: hijack in git... [Re: Daria]
Daria
#346215 - 05/07/2011 19:14 Re: hijack in git... [Re: Daria]
Daria
updated script which should be able to run on macos and linux
hijack-git.pl.gz (205 downloads)
Description: hijack git creation script
#346216 - 05/07/2011 19:15 hijack on github [Re: Daria]
Daria
https://github.com/empeg/empeg-hijack
i'll see about arranging to keep it updated. need an ssh key on the relevant host.
#346231 - 06/07/2011 10:17 Re: hijack on github [Re: Daria]
#346256 - 06/07/2011 15:40 Re: hijack on github [Re: LittleBlueThing]
Daria
I forked that first, noticed it hadn't been updated in a while, unforked and just did a new repo. The 'empeg' github account now also has vfdlib, squash, rioplay and will probably get gpsapp when I find my last source copy.
