#318500 - 27/01/2009 15:42 Rebuilt empeg, now it doesn't turn off when the car's off (?)
dionysus
Loc: San Francisco, CA
Hi,
I had to rebuild my empeg with a new hdd recently (the old drive died..) - everything went well (replaced two 30gb drives with one 80gb drive, took 2+ days to fill it up..) - BUT
Now, when I turn the car off, it doesn't turn off:( Did something change in hijack? I was running an old build from years ago.. Just updated (since I had to, rebuilding.) to the latest as updated from jemplode, 508? )
In hijack, the force ac/dc mode is set to normal, yet it detects it as ac/home (instead of dc..)
I'm also noticing that brightness doesn't turn down when I turn on my headlights.. (obviously nothing's changed w/ the car dock/wiring..)
Any ideas? This is on an mk2 (originally 2x30gb drives)
Thanks,
-mark
#318501 - 27/01/2009 15:44 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: dionysus]
dionysus
btw - I'm running the 2.0.1 empeg software w/ hijack on top. built using car2_v2.01_hijack.upgrade then updated to latest hijack with jemplode.
On a personal note, I can't believe this bbs is still active, that's awesome! and Mark - I can't believe you're still updating hijack - you rock!
-mark
#318505 - 27/01/2009 16:24 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: dionysus]
Hi dude!
If your player is truly set for "normal" AC/DC detection, then the power connector (AC adapter jack) may be b0rked. This would explain why it thinks "AC" when in the car.
#318506 - 27/01/2009 16:38 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: mlord]
dionysus
..But shoudln't forcing it to dc mode fix this? (I've forced it to dc mode/rebooted, but it still has the same issue..:( )
-m
#318507 - 27/01/2009 16:41 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: dionysus]
What issue is that?
#318509 - 27/01/2009 18:00 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: mlord]
dionysus
actually; it's working now - I think forcing dc mode *did* cause it to behave correctly...
(thank goodness for hijack:) thanks mark..) -m
#318511 - 27/01/2009 18:14 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: dionysus]
Good! smile
Someday, you could replace that dead AC-adapter jack, but I think it's mostly harmless in the meanwhile.
#318515 - 27/01/2009 18:57 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: dionysus]
There are other unwanted side effects of a malfunctioning AC jack. For example you can't pull the player out of the dash without sleeping it by hand or else it will make a loud pop from your speakers. It's just a pain. See if Eutronix can fix of for you.
#318735 - 02/02/2009 12:57 Re: Rebuilt empeg, now it doesn't turn off when the car's off (?) [Re: dionysus]
Yep, still here. Always good to see one of the original moderators stop by, and glad to hear your empeg is still in use today.
