#317433 - 19/12/2008 23:58 Using a Y-adapter on optical digital audio cable
My audio amplifier has an inadequate number of optical digital audio inputs to match the number of pieces of equipment that I want to have playing in 5.1 surround sound.
I'd like to overload one of the inputs and have the playstation 2 and the playstation 3 both go into that same input. Since I won't be playing the two game consoles at the same time, it seems to me that I should be able to just Y the two optical audio cables into the one input and they should work. Would they?
Would something like this do what I want? Anyone know if this idea will work?
#317434 - 20/12/2008 00:16 Re: Using a Y-adapter on optical digital audio cable [Re: tfabris]
robricc
Monoprice has the same (looking) one for cheaper. The customer reviews indicate that it will work for your intended use even though their description says otherwise.
Link
#317455 - 20/12/2008 18:39 Re: Using a Y-adapter on optical digital audio cable [Re: robricc]
Thank you very much for this information! Parts ordered. And especially thank you for the information about Monoprice, because that was a web site whose existence I had forgotten about. I have made a special note to myself so that I won't forget about them again.
#317460 - 21/12/2008 04:16 Re: Using a Y-adapter on optical digital audio cable [Re: tfabris]
Should be just fine as long as the outputs of the PS2 and PS3 actually turn off in standby mode. Pretty easy to tell - just look in the socket and see if you can see a light whilst in standby. Otherwise use the switch as recommended for a dollar more:
http://www.monoprice.com/products/produc...=1&format=2
#317463 - 21/12/2008 15:05 Re: Using a Y-adapter on optical digital audio cable [Re: Shonky]
Ah right! Thanks for that advice about checking to see if the outputs go off.
I saw that three way switch before, but I was looking for a hands-free solution.
