Page 1 of 3 1 2 3 >
#308431 - 21/03/2008 01:28 Computer building woes....
burdell1
I had bought a motherboard and processor awhile back to build a media center PC. however, i decided i needed a new case that had more ventilation for my current computer. so, I started the process of transferring the memory and graphics card (PCI express) to the new computer. For some reason, that didn't work, so I decided to put everything back in the old one to get that one working again since I figured the new one's motherboard might be bad. However, when I put the graphics card back in, nothing shows up on the monitor. No BIOS or anything else would show up on screen. I went and bought another graphics card just to see if that went bad somehow, and they only had a PCI one (not sure if that works with this motherboard though) and still nothing on screen. Everything turns on, but just nothing on screen. Is there some obvious thing that I am missing here? it is really frustrating....
#308432 - 21/03/2008 02:07 Re: Computer building woes.... [Re: burdell1]
Check for bent pins on your monitor cable.
#308433 - 21/03/2008 02:14 Re: Computer building woes.... [Re: wfaulk]
burdell1
unfortunately I didn't find any bent pins. However I might buy a new cable to rule that out.
#308434 - 21/03/2008 02:22 Re: Computer building woes.... [Re: burdell1]
Make sure the memory is seated properly?
#308435 - 21/03/2008 02:27 Re: Computer building woes.... [Re: burdell1]
Does the computer beep on powerup? Just once or multiple times? What pattern?
#308439 - 21/03/2008 04:48 Re: Computer building woes.... [Re: burdell1]
I would be checking 2 things, firstly does it have onboard graphics, if it does try that, and secondly is the MB shorting out on the case, sounds silly but i had a friend who swapped cases and there was a stand off where there shouldn't have been and that was shorting something out that stopped the graphics card working.
Cris.
#308442 - 21/03/2008 11:09 Re: Computer building woes.... [Re: Cris]
burdell1
as far as the beeping is concerned, there was a speaker built into the case,however, the two wires connected to it got broken. I was going to solder them back on, but the other connector that (i assume) goes on the motherboard doesn't seem to have a matching connector on the motherboard. Would the motherboard have a built in 'speaker' (just for diagnosing problems?)
#308443 - 21/03/2008 11:28 Re: Computer building woes.... [Re: burdell1]
Dig out the motherboard manual, and read it.
#308445 - 21/03/2008 15:10 Re: Computer building woes.... [Re: Cris]
Cris.
Doesn't even need to be a standoff, I had a motherboard that wouldn't boot in a case. If you left it on an antistatic bag then it worked fine. I ended up changing all the standoffs to plastic ones and it worked.
#308463 - 22/03/2008 21:09 Re: Computer building woes.... [Re: andym]
burdell1
I figured it out! Turns out the BIOS jumper came off and as soon as I put it back on, it started working again
#308468 - 23/03/2008 01:07 Re: Computer building woes.... [Re: burdell1]
lectric
Loc: New Orleans, LA
That should NOT have caused that behavior. All that should have happened it that your bios would be erased every boot. A pain, but not a broken computer.
#317023 - 06/12/2008 17:48 Re: Computer building woes.... [Re: lectric]
burdell1
Sorry to rehash an old thread, but my computer stopped working again so I decided to finally finish building my new computer. However, it seems that now the computer starts up, the fan runs, but there is no output of a video signal from the VGA output (which is built into the motherboard.) Then after a few tries, when try starting the computer again, the fan comes on for a few seconds then the fan stops. any ideas on what it might be? i took out the battery to reset the CMOS, but that didn't help. I also read that manual smile but no luck. any suggestions? i just hope I didn't fry the CPU when i put it in.
#317024 - 06/12/2008 18:13 Re: Computer building woes.... [Re: burdell1]
CrackersMcCheese
Can you try a separate graphics card and see if its the same? What about the BIOS - can you access that to check that the in-built VGA option is set to 'on'.
#317025 - 06/12/2008 18:33 Re: Computer building woes.... [Re: CrackersMcCheese]
Partial thread hijack...
Can anyone recommend a decent motherboard to run one of the newer Core2Duo chips that won't run me more than US$90 or so? I mainly buy parts from http://canadacomputers.com as they're not too far from me. But I'm happy to stop in at a TigerDirect as well.
I'm going to replace the majority of my PVR system, so it's time for a new mobo, CPU and then some RAM.
I'd like to avoid ASUS if possible. I've always bought ASUS in the past and I'm tired of them.
Mobo needs to have Gigabit LAN, built-in GFX, PCIe and some standard 32-bit PCI slots (at least 2).
Goals for this system are going to be brisk speed, rock-solid stability and as low power consumption as possible (24x7 operation).
#317026 - 06/12/2008 18:43 Re: Computer building woes.... [Re: hybrid8]
Even if you don't want to or can't purchase from NewEgg.com, they have a fairly broad selection and a great search utility.
Plugging in your requirements, I get:
ASRock G43Twins-FullHD
Foxconn G43MX-K
Foxconn G45M-S
Intel BOXDG43NB
MSI G45M-FD
Supermicro MBD-C2SEE-O
Supermicro MBD-C2SEA-O
I'd go with the Intel one myself.
Edit: Whoops. I specified PCIe 2.0. Specifying "regular" PCIe gives 68 models, as low as $30.
Edit edit: There
is a NewEgg.ca.
Edited by wfaulk (06/12/2008 18:54)
#317027 - 06/12/2008 19:48 Re: Computer building woes.... [Re: CrackersMcCheese]
burdell1
I've tried a separate graphics card and it doesn't work either (nothing, including the BIOS, shows up on screen)
If the CPU is shot, would the CPU fan still work?
#317028 - 06/12/2008 20:29 Re: Computer building woes.... [Re: burdell1]
CrackersMcCheese
Yes, the fan would still work.
What makes you think its the processor at fault? Try a bare bones boot with nothing but one stick of ram, cpu and the graphics card (or integrated graphics). Try the one stick of ram in all available slots. Maybe try another stick to check that its not the problem.
What about the PSU... could it be on the way out?
#317029 - 06/12/2008 22:41 Re: Computer building woes.... [Re: burdell1]
Yes. See if it boots with nothing but one stick of RAM plugged into it. If not, then try the other stick of RAM.
Make sure the video monitor you're using and the video cable are known to be good. Sometimes it's something as simple as that making you *think* the PC isn't booting.
#317030 - 06/12/2008 22:43 Re: Computer building woes.... [Re: tfabris]
And double check every jumper on the mobo to make sure none of them are in a funky position. Also if there is a "reset BIOS" jumper, do the necessary procedure to reset the BIOS to defaults.
#317031 - 07/12/2008 01:16 Re: Computer building woes.... [Re: hybrid8]
Asus has the "plus" of providing regular BIOS updates and stuff, which helps as new CPUs come to market. But they tend to omit details such as back-panel SPDIF connectors and such. I have a P5B-VM mobo that was in our PVR originally.
It has since been replaced by a Foxconn mobo, which has buggy DSDT tables (ACPI BIOS stuff), but otherwise works reasonably well in the PVR. The back panel optical SPDIF is how we connect it to the 5.1 amp/speaker system. But its back panel eSATA port has never worked -- the BIOS never sees drives on it, and neither does Linux.
Both boards were chosen for their PCIe plus 2 PCI slots in a mATX form factor to fit the Antec Fusion case.
So, hohum average rating from me on either.
#317032 - 07/12/2008 01:19 Re: Computer building woes.... [Re: wfaulk]
Edit edit: There [/i]is a NewEgg.ca.[/color]
They still ship from the USA, but collect sales tax at the source, so no brokerage fees. Shipping costs are good, though they do insist on using UPS Ground (ugh).
30-day return policy on much of the stuff, but returning to the USA from here would be a nightmare, on top of the 15% "restocking" fee.
#317033 - 07/12/2008 01:33 Re: Computer building woes.... [Re: mlord]
burdell1
Now it keeps doing the 'fan start for a few seconds and then stops...." thing and won't keep running. I doubt this is it, but do you think the power supply is not big enough? I have a 400W in it.
#317034 - 07/12/2008 01:35 Re: Computer building woes.... [Re: CrackersMcCheese]
burdell1
The power supply is brand new ...I had taken the fan/heatsink of the power supply and was afraid I might have wrecked it because they are overly sensitive.
#317043 - 07/12/2008 07:54 Re: Computer building woes.... [Re: burdell1]
Schido
I had a problem like this with a msi motherboard recently, the processor i bought for it (e8500) was supported in the new firmware, but not whit the firmware that came in the box.
Had to buy as cheap a processor i could find that worked (celeron e1200) and boot with that, flash the firmware and then i could use the new processor.
It did the fan spinup, stop, reboot loop too.
#317044 - 07/12/2008 08:03 Re: Computer building woes.... [Re: Schido]
Sounds like either the processor is kaputt or something is shorting the motherboard. What I always do in a situation like this is completely remove the motherbord from the case, put it on some sort of non-conducting material (like the bag most motherboards come in) and then build the 'computer' separate from the case.
If it works then, you'll know something about the case was shorting out the motherboard. It could be one of the pegs the motherboards rests on, in which case you could use some of those small plastic grommets to put between the pegs and the motherboard.
#317045 - 07/12/2008 11:01 Re: Computer building woes.... [Re: burdell1]
CrackersMcCheese
400w is more than adequate unless its a gaming rig (overclocked?) or if you have a crazy amount of hardware in the case.
Was this system running at some point in the past? Or is it new? I've also experienced what Schido mentioned with the motherboard being listed as compatible with the processor but the firmware it shipped with didn't. I too had to buy a cheap £30 processor to boot the pc and upgrade the firmware before swapping it over to the new processor.
If all else fails I'd go on eBay (or phone a friend) and find the cheapest earliest cpu the board supports and see what happens. Could be as simple as a firmware update.
#317050 - 08/12/2008 00:43 Re: Computer building woes.... [Re: CrackersMcCheese]
burdell1
it is a new one, however, during this process, I've been trying to get the old one to work too. and now both are doing the same thing (I turn it on, the fan on both the CPU and the power supply and after a couple of seconds, both fans shut off.)
Also, i tried building the computer outside the case, and it still does the same thing. However, if I do it that way, does it matter that the power switch isn't hooked up?
#317051 - 08/12/2008 01:45 Re: Computer building woes.... [Re: burdell1]
Certain kinds of motherboards (newer ones usually) do, in fact, need a power switch attached before they can be turned on.
You turn on the power supply's switch (which is really just a mains cutoff switch) to get power to the motherboard, and the fans run for a moment as it gets its first bit of power. Then it waits for the command from the real power button to turn on all the way.
#317052 - 08/12/2008 01:50 Re: Computer building woes.... [Re: burdell1]
400W is HUGE. More than enough for all but the most packed of systems. By comparison, my PVR here has a Core2-Duo, two 750GB SATA drives, two old-school PCI tuner cards, PCIe graphics card 2GB RAM, external bus-powered USB peripherals, multiple case fans, front-panel alphanumeric display, etc..
And uses only 75-90W most of the time (measured it).
#317053 - 08/12/2008 02:09 Re: Computer building woes.... [Re: mlord]
burdell1
Holy crap!...so I just bought a new power supply from Best Buy...just to rule out the possibility that the power supply got fried and after I hooked it up, there literally was a spark that came off the cpu/heatsink fan! I unplugged it and then tried it again a little while later and the fan would turn on for a little while, stop, and then come on again....and it would keep doing this until i shut off the power supply switch.
Page 1 of 3 1 2 3 >
