#31483 - 24/05/2001 04:30 voladj kernel
jstrain
Loc: philadelphia pa
can i still use the volume adjustment kernel, or is it tied to a specific version of the empeg software?
12 gig, green...
12 gig, green...
#31484 - 24/05/2001 05:13 Re: voladj kernel [Re: jstrain]
Since it is a recompile of the kernel, and since the kernel usually gets changed between versions, yes, it is tied to a specific version. Occasionally, a minor empeg upgrade won't change the kernel, and you'll be able to use the previous voladj kernel with no ill effects. But usually, you need to version-match them.
You should be able to find a proper version of the voladj kernel if you know where to look...
