#310944 - 04/06/2008 16:37 Hijack v493, v494: recommended upgrades
Hijack v493 is now released.
  • various small fixes
  • gets rid of yet another leftover debug message from boot time
  • add's LittleBlueThing's new menu item "Boot Graphics", to be demonstrated at The Party in July.
Hijack v494 simply fixes some whitespace errors from v493.
If you haven't upgraded your Hijack in a while (or even if you have), then *now* is a good time to do so.
#310966 - 05/06/2008 11:21 Re: Hijack v493, v494: recommended upgrades [Re: mlord]
chrispitude
Loc: Saylorsburg, PA
Mike, thanks for your continued support of the empeg community. This little thing just won't die, and for that I am thankful.
My 250GB drive arrives today - woohoo! Time to retire that pair of noisy 30GB drives.
- Chris
1995 BMW M3 - 250GB RioCar
#310971 - 05/06/2008 12:55 Re: Hijack v493, v494: recommended upgrades [Re: chrispitude]
petteri
Loc: Helsinki, Finland
Thanks Mark. Again the support that the Empeg gets is just unbelievable.
I just wish I had the funds to upgrade the HDs in both my Empegs at this time. Perhaps I'll go the CF route a bit further down the road....
#310974 - 05/06/2008 13:03 Re: Hijack v493, v494: recommended upgrades [Re: petteri]
Boelle
Loc: Denmark, Odense
another question from the "monkey" (me):
if you load only ver. 2.01 of the player there ia a penguin waveing to you during boot, but if i then load hijack this goes away... is there a way to get the "stock" boot logo back?
#310975 - 05/06/2008 13:17 Re: Hijack v493, v494: recommended upgrades [Re: Boelle]
That is because you, or a previous owner, has loaded a custom boot animation into the flash memory, and Hijack knows to look for that.
Use JEmplode to reset it back to default. Others here can probably help with this.
#310977 - 05/06/2008 13:38 Re: Hijack v493, v494: recommended upgrades [Re: Boelle]
The waving penguin animation can be reloaded by downloading it from here ("original empeg 2.0 boot animation") and installing it with Jemplode.
#310978 - 05/06/2008 13:40 Re: Hijack v493, v494: recommended upgrades [Re: mlord]
Are you sure? I could have sworn that Hijack includes its own non-factory boot up animation. Didn't you sort of have a "contest" at some point, and Mike Schrag's animation is the one you decided to permanently include in Hijack by default?
#310979 - 05/06/2008 13:47 Re: Hijack v493, v494: recommended upgrades [Re: tfabris]
Are you sure?
Check for yourself with the latest Hijack -- LittleBlueThing has contributed a Boot Graphics selection to the Hijack menu to show the boot animation as well as the built-in empeg animation.
Ancient history, I'm afraid.
Edited by mlord (05/06/2008 13:48)
#310980 - 05/06/2008 13:51 Re: Hijack v493, v494: recommended upgrades [Re: tfabris]
No. Instead, simply run JEmplode, and select "Clear Animation" from the Tools -> Animation Editor sub-app.
#310981 - 05/06/2008 13:57 Re: Hijack v493, v494: recommended upgrades [Re: mlord]
Gotcha. Updating FAQ entry now.
#310985 - 05/06/2008 15:01 Re: Hijack v493, v494: recommended upgrades [Re: tfabris]
Boelle
i only know that if only ver. 2.01 is loaded the pengiun is waveing at boot, when i load hijack on top the pengiun is non-animated
but i will give it at go with a new hijack first
#310986 - 05/06/2008 15:11 Re: Hijack v493, v494: recommended upgrades [Re: Boelle]
Boelle
i just tried to download auto hijack (the auto update thing) but the link was broken, would this be a feature to come in hijack?
#310994 - 05/06/2008 18:10 Re: Hijack v493, v494: recommended upgrades [Re: Boelle]
I always autopdate from jemplode (when in windows) - it "just works"
