#310843 - 02/06/2008 10:51
Re: Hijack v490 and hdparm-8.6+
Loc: Denmark, Odense
just to be as sure as a "monkey" im doing another diskbuild and then i will use your script as provided, it was just me that was a bit confused about the renameing of the files smartctl and hdparm
#310844 - 02/06/2008 10:54
so i should just rename them to smartctl and hdparm? Duh, like, YES. hey, i'm just a beginner.... and slow at learning (as a monkey) :-)
#310845 - 02/06/2008 11:11
[Re: tman]
Is there a particular reason why you keep persisting with this drive? Get it replaced... On a (slight) tangent: is it worth me grabbing some 2.5" PATA drives now, while they're still available? I've got two empegs, and both seem to be fine, but I don't want to be caught out when the disks die, and there are no replacements available.
#310846 - 02/06/2008 11:47
[Re: Roger]
I've got two empegs, and both seem to be fine, but I don't want to be caught out when the disks die, and there are no replacements available. That's when you replace them with CompactFlash cards, assuming those are still available. I think they're a safe bet yet for the next 3 years, at least. Cheers
#310847 - 02/06/2008 13:30
*wanders off to check the prices on 64GB CF cards again*
#310854 - 02/06/2008 19:59
hdparm-8.7 for the empeg
Version 8.7 of hdparm is now available from Sourceforge.net.
A binary built for the empeg is attached to this posting.
cheers
hdparm.bin (239 downloads)
#310856 - 02/06/2008 20:49
Re: hdparm-8.7 for the empeg
after another diskbuild and loading ver. 3 alpha 11 + newest hijack, i did these commands (i used the script mark made, not the "screwed up" one i did post here):
./smartctl -S on /dev/hda ./smartctl -t long /dev/hda ./smartctl -S on /dev/hdc ./smartctl -t long /dev/hdc ./fix_bad_sectors.sh /dev/hda ./fix_bad_sectors.sh /dev/hdc
the output is still the same:
empeg:/tmp# ./fix_bad_sectors.sh /dev/hda empeg:/tmp# ./fix_bad_sectors.sh /dev/hdc /dev/hdc: Examining LBA 21168128: not bad. /dev/hdc: Examining LBA 118681552: not bad. /dev/hdc: Examining LBA 101619881: not bad. /dev/hdc: Examining LBA 101618857: not bad. /dev/hdc: Examining LBA 101617328: not bad. /dev/hdc: Examining LBA 101517771: not bad. /dev/hdc: Examining LBA 101517771: not bad. /dev/hdc: Examining LBA 17631400: not bad. /dev/hdc: Examining LBA 101458623: not bad. empeg:/tmp#
i will give it another go with the new hdparm, but i dont know how i do delete the one i have on the player...
but doing hdparm --read-sector ******** /dev/hdc replacing ****** with the lba numbers listed only returns that reading those sectors is succeeded
Edited by Boelle (02/06/2008 21:00) Edit Reason: doing hdparm --read-sector
#310864 - 03/06/2008 00:37
[Re: Boelle]
Okay, the drive is good, for now.
And there's no need to run it again with the newer hdparm -- the features you are using have not changed in the new version.
#310873 - 03/06/2008 08:31
a big thanks for all the help, one last note is that the display shows: pump hda5 648:2 during boot (just before it says loading visuals etc.)
#310898 - 03/06/2008 12:35
[Re: Boelle]
a big thanks for all the help, one last note is that the display shows: pump hda5 648:2 during boot (just before it says loading visuals etc.) Oh.. Yeah, I meant to get rid of that message from Hijack. New version coming soon. Cheers
#310900 - 03/06/2008 12:43
is there a chance for a diskcheck / repair thing in hijack? so one just choose that in the menu? maybe along with some progrss info on the display? of course it should only be there is it is in public interest and not just for a single person
#310906 - 03/06/2008 13:08
[Re: Boelle]
is there a chance for a diskcheck / repair thing in hijack? so one just choose that in the menu? maybe along with some progrss info on the display? of course it should only be there is it is in public interest and not just for a single person Too big/complex for hijack itself, though anyone who wants to could write a script/program to call the fsck program from the Hijack menu -- it's user-extensible, you know.
#310908 - 03/06/2008 13:16
yep, but what good would come out if let a "monkey" write a script?
#310942 - 04/06/2008 14:28
[Re: Boelle]
yep, but what good would come out if let a "monkey" write a script? Well, if the monkey were to write it, post it here with questions and corrections, and repeat until done, I'd say you'd get a more knowledgeable monkey, which would be good, no?
#310973 - 05/06/2008 13:00
[Re: canuckInOR]
i was just trying to make a joke on myself. It's me that is the monkey
#311276 - 11/06/2008 13:44
hdparm-8.8 for the empeg
As it turns out, hdparm-8.7 had broken -r and -a flags, so here is hdparm-8.8 (for the empeg) with those issues fixed.
hdparm.bin (228 downloads)Description: hdparm-8.8 binary for the empeg.
