Page 4 of 4 < 1 2 3 4
#310647 - 29/05/2008 17:05 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
Loc: Denmark, Odense
serial log at power up (ip: 192.168.1.102) :
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102286) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004680).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
hdb: ST9808211A, ATA DISK drive
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: ST9808211A, 76319MB w/8192kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:08:ee
Partition check:
hdb: unknown partition table
empeg-pump v0.03 (19980601)
Mounting proc
Mounting second music parattempt to access beyond end of device
tition
03:44: rw=0, want=2, limit=0
dev 03:44 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Tried to mount /dev/hdc4 but got error 22
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
Timezone: Atlantic/South_Georgia
player.cpp : 385:empeg-car 2.01 2004/07/06.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
#310651 - 29/05/2008 17:40 Re: more RAM+Harddisk errors [Re: Boelle]
Mmm.. is this a completely "blank" player (no tunes or playlists installed yet) ?
I think the Hijack servers do not start up unless a config.ini file exists on the player. That's something I ought to fix someday, but it is easier to just create the config.ini file.
Connect using ckermit or putty or even hyperterm over the serial cable, hit control^C, and type these commands at the prompt:
rwm
echo "[hijack]" >> /empeg/var/config.ini
rom
exit
Then cycle the power and try again.
Edited by mlord (30/05/2008 00:30)
Edit Reason: changed row to rom
#310653 - 29/05/2008 17:43 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
it's complete blank
log from diskbuild:
warning: can't open /etc/mtab: No such file or directory
Setting up swapspace version 0, size = 17027072 bytes
Warning: insecure permissions 0644, 0600 suggested
Adding Swap: 16628k swap-space (priority -1)
Making first drive...
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/ hda4 is mounted.
Linux ext2 filesystem format
Filesystem label=
152000 inodes, 19451880 blocks
0 blocks (0.00%) reserved for the super user
First data block=1
Block size=1024 (log=0)
Fragment size=1024 (log=0)
2375 block groups
8192 blocks per group, 8192 fragments per group
64 inodes per group
Superblock backups stored on blocks:
8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409, 663553,
1024001, 1990657, 2809857, 5120001, 5971969, 17915905,
Writdone
Writing superblocks and filesystem accounting information: done
real 1m19.953s
user 0m0.450s
sys 0m5.430s
Partitioning second drive...
Partitioning /dev/hdb
Initialising /dev/hdb complete
Making second drive...
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdb4 is mounted.
Filesystem label=
609728 inodes, 78043770 blocks
First data block=1
9527 block groups
64 inodes per group
1024001, 1990657, 2809857, 5120001, 5971969, 17915905, 19668993,
25600001, 53747713,
Writing inode tables: done
real 4m2.952s
user 0m1.890s
sys 0m14.420s
hdstress.cpp 189 ( 54): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Stressing /dev/hda: Spinning up.
Speed checking /dev/hda3
Read/write of 8Mb took 6.64 seconds
Drive length is 39070080 blocks, seek testing
#310656 - 29/05/2008 18:01 Re: more RAM+Harddisk errors [Re: Boelle]
The serial output seems to indicate it's doing the stress test, meaning the player software hasn't been installed. It looks like all it has in place is the builder, not the player. I think you need the player softare and hijack in place before FTP will work. Someone correct me if I'm wrong?
#310657 - 29/05/2008 18:28 Re: more RAM+Harddisk errors [Re: tfabris]
Boelle
as i wrote the log is from the diskbuild process
#310662 - 29/05/2008 19:24 Re: more RAM+Harddisk errors [Re: Boelle]
Okay. Why?
I thought maybe we were still working on the bad sectors (?).
#310663 - 29/05/2008 19:50 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
weare.. i just wrote the log so you could see whee i was in the progress...
for now i have done:
1. diskbuild
2. install ver 2.01 devel
3. installed newest hijack
4. run the commands:
rwm
but it says that the command row can not be found... but there is the commands ro and rom (pressing the tab key)...
edit: none of those 2 did work
Edited by Boelle (29/05/2008 20:09)
#310665 - 29/05/2008 20:34 Re: more RAM+Harddisk errors [Re: Boelle]
He meant "rom".
#310668 - 30/05/2008 00:31 Re: more RAM+Harddisk errors [Re: wfaulk]
He meant "rom".
Yes. Thanks Bitt. Now fixed in original posting.
#310671 - 30/05/2008 07:09 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
the commands did the work.. did not even had to cycle power
Restored terminal settings
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
empeg:/empeg/bin# rwm
empeg:/empeg/bin#
empeg:/empeg/bin# echo "[hijack]" >> /empeg/var/config.ini
empeg:/empeg/bin# rom
empeg:/empeg/bin# exit
logout
Shell exit
Starting player
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
#310672 - 30/05/2008 08:39 Re: more RAM+Harddisk errors [Re: tfabris]
Boelle
i'm a windows man so i don't know much about linux, can you make a very quick step by step?
The FAQ has a step-by-step here, but I haven't sanity-checked it in a long time, so it might be outdated. Worth a try though.
i did get the .bin file to player by reading the faq..
right now i'm doing the test as the faq says... but no errors for hda so far...
is it usefull if i put together a guide?
#310675 - 30/05/2008 09:28 Re: more RAM+Harddisk errors [Re: Boelle]
Boelle
got errors on /dev/hdc:
empeg state support initialised 0089/88c1 (save to d0005400).
Partition check:
Mounting proc
Starting player
Vcb: 0x4073a000
Starting bash.
empeg:/empeg/bin# cd /tmp
empeg:/tmp# ./smartctl.bin -l error /dev/hdc
smartctl version 5.33 [arm-empeg-linux-gnu] Copyright (C) 2002-4 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF READ SMART DATA SECTION ===
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 4
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 3887 hours (161 days + 23 hours)
When the command that caused the error occurred, the device was in a vendor specific state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
51 01 01 00 00 43 a1 Error: UNC, IDNF, AMNF at LBA = 0x01430000 = 21168128
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
40 20 fe f9 6f 00 00 f6 12d+10:16:25.350 READ VERIFY SECTOR(S)
00 20 fd f9 6f 00 00 f6 00:00:43.016 NOP [Reserved subcommand]
00 20 fb f9 6f 00 00 f6 00:00:40.968 NOP [Reserved subcommand]
00 20 f9 f9 6f 00 00 f6 00:00:38.920 NOP [Reserved subcommand]
00 20 f7 f9 6f 00 00 f6 00:00:36.872 NOP [Reserved subcommand]
Error -1 occurred at disk power-on lifetime: 34824 hours (1451 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
19 43 f7 51 01 00 00 Error:
00 19 f7 20 0a 76 0d 2f 00:14:28.352 NOP [Reserved subcommand]
00 18 f7 20 ce 74 0d ef 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 97 74 0d af 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 8e 74 0d 6f 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 31 98 0d 2f 00:14:11.968 NOP [Reserved subcommand]
Error -2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
d0 00 6f 16 f7 51 01
76 cf 6f 16 f7 20 0a 02 22d+22:06:06.861 SEEK [RET-4]
74 cf 2f 16 f7 20 ce 02 22d+16:20:57.485 SEEK [RET-4]
74 cf ef 15 f7 20 97 02 22d+15:20:53.005 SEEK [RET-4]
74 cf af 15 f7 20 8e 02 22d+15:11:03.181 SEEK [RET-4]
74 cf 6f 15 f7 20 87 02 22d+15:03:24.429 SEEK [RET-4]
Error -3 occurred at disk power-on lifetime: 3721 hours (155 days + 1 hours)
When the command that caused the error occurred, the device was active or idle.
40 51 00 d0 ef 12 f7 Error: UNC at LBA = 0x0712efd0 = 118681552
20 00 02 cf ef 12 f7 00 6d+09:37:51.899 READ SECTOR(S)
20 00 02 cf af 12 f7 00 6d+09:37:51.888 READ SECTOR(S)
20 00 02 cf 6f 12 f7 00 6d+09:37:51.883 READ SECTOR(S)
20 00 02 cf 2f 12 f7 00 6d+09:37:51.879 READ SECTOR(S)
20 00 02 cf ef 11 f7 00 6d+09:37:51.873 READ SECTOR(S)
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
00 00 00 43 a1 01 00
d0 00 0d 00 00 40 00 8a 40d+09:21:05.071 [RESERVED]
cf 00 0d 00 00 00 02 81 40d+04:43:38.927 [RESERVED]
cf 00 0d 00 00 00 02 76 40d+04:43:38.863 [RESERVED]
cf 00 0d 00 00 00 02 6f 40d+04:43:38.799 [RESERVED]
cf ff 0c 00 00
#310676 - 30/05/2008 09:30 Re: more RAM+Harddisk errors [Re: Boelle]
Boelle
sorry but empeg:/tmp# ./smartctl.bin -l error /dev/hdc freezed so thats why the sudden stop
#310680 - 30/05/2008 10:57 Re: more RAM+Harddisk errors [Re: Boelle]
Okay, so smartctl tells us that the drive definitely has media errors -- and so there is no need to blame the cables/connectors (yet).
If you have the patience to continue writing zeros until all of the errors are repaired, then go for it. But at this point I would pull the drive and send it in for a warranty replacement.
Or at least install it in a PC and run a Seagate low-level format on it. That is, assuming that Seagate provides software (web site?) to do this, like other manufacturers.
#310682 - 30/05/2008 11:01 Re: more RAM+Harddisk errors [Re: mlord]
Google seems to have found it for me.
Or, on a more modern Linux system (than the empeg),
one could use: hdparm --security-erase NULL /dev/sdc
Edited by mlord (30/05/2008 11:01)
#310687 - 30/05/2008 11:17 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
i have the time, but can i do the "zero fill" thing in the empeg?
the problem is that the disk is an OEM from seagate and i can't remember how i got it
and i would be happy if i could avoid opening my laptop to repair the drive
#310688 - 30/05/2008 11:19 Re: more RAM+Harddisk errors [Re: Boelle]
Boelle
btw... can i configure network on the player through putty?
for some reason my old laptop cant find the player through emplode but it can with putty (the drives spins up when opening emplode but it will go on searching for the player forever - if setting it to search my network it finds it in a flash)
i just want to assign the player a fixed ip
#310691 - 30/05/2008 11:41 Re: more RAM+Harddisk errors [Re: Boelle]
If you don't have anything that you care about in the config.ini file, then just connect over serial again, and do this:
## Hit control^C to get a shell prompt, then do:
## Enable read/write access to all disks:
rwm
## Replace config.ini with new contents,
## (edit the IP addresses below to suit your network):
cat << EOF > /empeg/var/config.ini
[Network]
Gateway=192.168.0.1
Netmask=255.255.255.0
IPAddress=192.168.0.9
EOF
## Switch back to read-only disk access again:
rom
## Restart the player s/w:
exit
#310692 - 30/05/2008 11:44 Re: more RAM+Harddisk errors [Re: Boelle]
Sure, just keep attempting the 11-hour operation until it succeeds completely:
cat /dev/zero > /dev/hdc
But on a PC, a reformat/erase operation would take only a single attempt, and complete in less than an hour.
#310693 - 30/05/2008 11:45 Re: more RAM+Harddisk errors [Re: mlord]
Mmm.. perhaps I really should update the empeg's IDE (disk) drivers to support modern hdparm features. Then we could simply let hdparm fix the bad sectors, or do the erase operation, etc..
Not for one person, though, but the need for this sort of thing does seem to be growing in general.
Someday perhaps..
#310697 - 30/05/2008 13:47 Re: more RAM+Harddisk errors [Re: mlord]
Okay, I'm actually having a go at this now, hopefully for Hijack v490.
#310698 - 30/05/2008 13:48 Re: more RAM+Harddisk errors [Re: mlord]
Awesome. Thanks for all the work you've put in on this, Mark.
#310715 - 30/05/2008 17:01 Re: more RAM+Harddisk errors [Re: mlord]
Okay, it is done.
#310742 - 31/05/2008 07:48 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
wow... have to have a look at it
sorry for the late answer..
#310744 - 31/05/2008 08:20 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
i have done a very careful inspect of the whole mainboard... no bad solders or loose conectors
