Page 3 of 4 < 1 2 3 4 >
#310515 - 27/05/2008 12:41 Re: more RAM+Harddisk errors [Re: Roger]
Boelle
Loc: Denmark, Odense
thanks roger
and it's ok to be drunk :-)
#310516 - 27/05/2008 12:49 Re: more RAM+Harddisk errors [Re: Roger]
Boelle
so i should do it for :
/dev/hda
/dev/hdb
/dev/hdc
#310517 - 27/05/2008 13:02 Re: more RAM+Harddisk errors [Re: Boelle]
If you want to do both drives then hda + hdc. No hdb.
#310529 - 27/05/2008 20:13 Re: more RAM+Harddisk errors [Re: tman]
Boelle
why not hdb? i have seen hdb among the errors
#310533 - 27/05/2008 21:45 Re: more RAM+Harddisk errors [Re: Boelle]
The Mk1 had two IDE channels so your two drives ended up as hda and hdc.
The Mk2/Mk2A had 1 IDE channel so your two drives ended up as hda and hdb. However to make it easier, the device nodes in /dev were changed around slightly so you could still refer to the 2nd drive as /dev/hdc.
#310536 - 27/05/2008 23:08 Re: more RAM+Harddisk errors [Re: tman]
Yeah. Blame me (and Linus) for the skip naming, and blame Hugo for his twisted simplification (of empeg s/w) in taking advantage of it. wink
The kernel refers to the second drive in a MkII/MkIIa as hdb, but the non-kernel software uses /dev/hdc for the same unit. This is a peculiar, yet normal, sort of thing for a POSIX style operating system to be able to do.
EDIT: The purists would prefer that we should have used 3,0 and 3,16 in the kernel, instead of hda and hdb. But I argued against that, as being rather unfriendly for common uses and users.
Edited by mlord (28/05/2008 14:13)
#310544 - 28/05/2008 06:40 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
funny thing is that when i zero fill hda at some point it goes crazy and are writing stuff so fast that i cant read it.
if i reboot the player it hits me with a kernel panic
doing the disk build stuff and everything is normal again, but it is only stress testing hda....
#310545 - 28/05/2008 07:05 Re: more RAM+Harddisk errors [Re: Boelle]
Boelle
anyway cat /dev/zero > /dev/hdb can't be done, it tells me that /dev/hdb is read only
a little challange for mark: build a disk test thing in to hijack, with options to test and repair disk, and also stress all installed drives
maybe as a special version that only do that.. or maybe a "bug fix" hijack that can be used for fixing bugs and repairs ?
#310546 - 28/05/2008 07:46 Re: more RAM+Harddisk errors [Re: Boelle]
As I said above, don't do hdb.
There is a finite number of spare blocks available on the drive to remap bad blocks. If your drive is really badly broken then you'll have to replace it.
#310547 - 28/05/2008 07:52 Re: more RAM+Harddisk errors [Re: tman]
Boelle
but there are errors on hdb... guess i can take them out of the player and zero fill them on my laptop
#310548 - 28/05/2008 08:20 Re: more RAM+Harddisk errors [Re: Boelle]
Errors on hdb get fixed when you "cat /dev/zero > /dev/hdc". If you open the player, count the drives carefully! there will be at most two, not three wink
I think, Mark, your clarification itself contained a typo: didn't you mean:
#310549 - 28/05/2008 09:25 Re: more RAM+Harddisk errors [Re: peter]
Boelle
there are 2 drives, i installed the second one myself,
also i used some clear silicon glue on the ide connector on the drives, this becuase the silicon stays flexible and is easy to remove.. i used the clear type as it is the most weak of all types.. you can get greay, white and red types...
i prefered silicon to hot melt glue do to that vibrations could break of the hot melt glue as i cools down and get hard
#310550 - 28/05/2008 11:04 Re: more RAM+Harddisk errors [Re: Boelle]
Ross Wellington
Hi,
Sometimes that type of silicone RTV will leech into the connector mating area and contaminte the gas-tight seal of the pin and socket.
Make sure this is not the problem too.
#310554 - 28/05/2008 11:56 Re: more RAM+Harddisk errors [Re: Ross Wellington]
Boelle
i'm sure it's not the problem, i only applied so little that it would only touch the surface of the connector on the drive and on the ide cable
#310560 - 28/05/2008 14:14 Re: more RAM+Harddisk errors [Re: Boelle]
Silicone uses an acid solvent, which can corrode contacts.
#310561 - 28/05/2008 14:15 Re: more RAM+Harddisk errors [Re: peter]
Yup. Typo now fixed by an EDIT in the original post.
Thanks.
#310563 - 28/05/2008 15:54 Re: more RAM+Harddisk errors [Re: mlord]
I'd have preferred Solaris-style c0t0 and c0t1 namings. It's so easy to figure out what's what under Solaris in a way that it is not under most other Unices, Linux included.
#310564 - 28/05/2008 16:33 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
so it's 100% safe as long óne does not put it on the contact pins
#310570 - 28/05/2008 18:25 Re: more RAM+Harddisk errors [Re: Boelle]
Vapours.
#310589 - 29/05/2008 08:45 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
i did some heavy vent. wkile i dried up
anyway after some diskbuilds and zero fills it all comes down to this:
empeg:/empeg/bin# cat /dev/hda > /dev/null
empeg:/empeg/bin# cat /dev/hdc > /dev/null
hdb: read_intr: status=0x59 { DriveReady SeekComplete DataRequest Error }
hdb: read_intr: error=0x40 { UncorrectableError }, LBAsect=115459753, sector=115459753
end_request: I/O error, dev 03:40 (hdb), sector 115459753
cat: /dev/hdc: Input/output error
empeg:/empeg/bin#
i will be fixing the temp sensor later, so the unit will get a very close inspection while i have it open
as for the Silicone i have only used it on the drive end of the IDE cable... i could never dream of using the stuff on the mainboard.. there is no need to either as the connector is more a theight fit than on the drives
#310591 - 29/05/2008 09:05 Re: more RAM+Harddisk errors [Re: Boelle]
Boelle
just loaded ver. 3 alpha 11.. i feel like an idiot, i can't find the auto eq feature
do i have to plug in the mic to have the menu option displayed?
#310597 - 29/05/2008 11:46 Re: more RAM+Harddisk errors [Re: Boelle]
The smartctl program is the only real way to know if the drive is the issue.
I've placed a binary copy (for the empeg) on the Hijack site (links at top of this page and that page.
#310598 - 29/05/2008 11:52 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
how do i use the tool? sorry for asking stupid
#310604 - 29/05/2008 12:54 Re: more RAM+Harddisk errors [Re: Boelle]
Use it the same as you would on any other Linux system.
The man page is here, courtesy of Google.
The normal sequence is to do something like this:
## Enable the S.M.A.R.T. monitoring in the drive firmware:
smartctl -s on /dev/hdc
## Check current drive status. "-a" means "all", or "everything":
smartctl -a /dev/hdc
Then scour the output looking for error reports.
(and post the complete output here for us to help with)
If you don't see any errors, then do the "cat /dev/zero > /dev/hdc"
thing again (sorry), and this time the drive will record errors
for later retrieval with smartctl -a
Edited by mlord (29/05/2008 12:55)
#310606 - 29/05/2008 13:01 Re: more RAM+Harddisk errors [Re: mlord]
Boelle
i'm a windows man so i don't know much about linux, can you make a very quick step by step?
#310627 - 29/05/2008 14:38 Re: more RAM+Harddisk errors [Re: Boelle]
The FAQ has a step-by-step here, but I haven't sanity-checked it in a long time, so it might be outdated. Worth a try though.
#310629 - 29/05/2008 14:48 Re: more RAM+Harddisk errors [Re: tfabris]
Boelle
i will say it does work or not
#310640 - 29/05/2008 16:02 Re: more RAM+Harddisk errors [Re: Boelle]
Boelle
damn.. i cant connect to ftp... :-(
newest hijack installed
#310644 - 29/05/2008 16:45 Re: more RAM+Harddisk errors [Re: Boelle]
Boelle
still no go at the http or ftp in hijack
i installed ver 2.01 kernel and newest hijack
#310646 - 29/05/2008 16:49 Re: more RAM+Harddisk errors [Re: Boelle]
Check the ethernet connections. Go to the "about" screen on the empeg front-panel, and see what IP address it is using.
You know the drill by now.. post a serial log here along with the IP address info.
