#310178 - 14/05/2008 17:52
Re: Click(s) when starting playing
[Re: mardibloke]
If it's a managed Cisco, try forcing the interface to 10/Half and see if it helps. Also try 10/Full.
#310182 - 14/05/2008 19:35
[Re: andy]
Loc: Florida
Just got in a "new" SlimP3 from eBay (SWMBO swears I just collect these things  ). Sync works correctly between the receiver in my office and the SlimP3 only after pausing and restarting the track, and even then drifts intermittently. However, once it gets in sync, it never drifts FAR out and has played in sync for at least 2 tracks in a row. I'll try to play them in sync for a couple hours tomorrow and let you know what I find. EDIT: Oh yeah, I did have to turn down the "Max Number of Bytes of Audio Data" to 1000 before I could get any decent sound out of the SlimP3. Maybe smaller data packets will help the syncing on SlimRio also?
Edited by Dearing (14/05/2008 19:37)
_~= Dearing =~_ Gettin' back into it thanks to slimrio!
#310217 - 16/05/2008 00:15
[Re: Dearing]
Loc: Florida
Well, Syncing is still not perfect. Sometimes it will stay in sync for a few tracks in a row, sometimes I have to pause/restart and sometimes I have to adjust the Audio Delay from SC for the receiver. I may have to stick to the SlimP3 and SB3 when I want to sync, and the 2 receivers just for non-synced listening. Has anyone else had any luck syncing consistently between SlimRio and Squeezeboxen?
#311202 - 10/06/2008 01:10
[Re: Dearing]
I'm new here. Hi.
I've been using SlimRio for a while and love it. I am now trying to move the NFS mount part to my MacBook Pro running Mac OS 10.4.11.
So far, I've gotten it to the point that I see "EMPEG Penguins Found" on the RIO (Dell) screen, but then nothing after that. So, I think the kernel is loaded, but there's a problem loading the file system over NFS.
I've tried 7.0 and 7.0b...same problem. I *did* notice that the lib directory has a group name of "Robin" which doesn't translate to a group on my Mac. Could that be the problem?
Anyone know why the boot up process could be stopping after the "Penguins Found" screen is loaded or what this means?
Thanks!
Edited by Hedges (10/06/2008 01:28)
#311261 - 10/06/2008 21:40
[Re: Hedges]
It's possible that the SlimRio NFS client is using non-trusted port and that MacOS is denying the connection because of it. I seem to recall that happening to me with my OpenBSD server, and there's a lot of OpenBSD in MacOS.
#311262 - 10/06/2008 22:50
Yup...I started researching down that path yesterday but got distracted. I'll pick that back up and see if I can find a work-around. Thanks for the tip.
#311266 - 11/06/2008 02:06
[Re: Hedges]
I did a tcpdump and watched what the rio is doing once it puts up the "EMPEG Penguins Found" on the screen. Basically, it is in a loop whereby it requests busybox, ld-linux.so.2, libc.so.6, slimrio, etc, v4l ir, font6x16, sleep and display...and it just keeps on doing this over and over again. It gets errors on "etc" and others since they don't exist in the tar file. It just keeps looping on these requests. So, it successfully downloaded the kernel image, but is having troubles with some of the other files.
Anyone have any ideas what's wrong? As stated above, I'm running NFS on a Mac os 10.4.11.
#311462 - 18/06/2008 20:43
[Re: Hedges]
Loc: IL, U.S.A.
Now that skipping has been eliminated, all singers seem to have a lisp. Has anybody else noticed this?
#311465 - 19/06/2008 07:30
[Re: gerald_clark]
Now that skipping has been eliminated, all singers seem to have a lisp. Has anybody else noticed this? No, but it sounds like MP3 artefacts to me. Maybe you still have bitrate limiting enabled on the server and set to a low rate ? With the latest SlimRio I returned all the other tweaks on my server back to normal.
#311483 - 19/06/2008 21:00
[Re: andy]
Loc: IL, U.S.A.
It is the --downsample option to madplay.real that is causing the sibilance.
#311484 - 19/06/2008 21:12
[Re: gerald_clark]
Ah, that would explain a couple of things. I had the feeling the quality of SlimRio's playback wasn't as good as the original Rio code, but I had convinced myself I was imagining it. So all my 44khz files are actually being downsampled to 22khz  It also explains how Robin managed to "fix" the stuttering problem without a working tool chain. I'll have to do some testing and see whether I prefer 128k MP3 transcodes or a 22khz sample rate...
#312562 - 29/07/2008 18:16
[Re: andy]
Loc: North Bay, CA
I found the text wrapping very annoying. It is possible to modify SqueezeCenter 7 to display only 20 rows. The file is located in /usr/lib/perl5/vendor_perl/Slim/Display/Text.pm
It's a simple matter of changing all "40" to "20" and "39" to "19".
After this, the "brightness" value of "3" provides the best result.
#315619 - 28/10/2008 01:28
Re: Slimserver Instructions
[Re: caederus]
Loc: Qc, Canada
Hi!
I'm using slimrio here at home since last year. Recently, I installed slimserver and then squeezecenter under windows at my father's house. All was working fine!
But, I'm slowly converting him to linux, so the computer with squeeze is currently being transfered to ubuntu 8.04. He installed squeezecenter, dhcp server, ssdp.py and nfs server. He gets to the point of "Finding SlimServer...", but then get the message "Failed to connect to server" (or something similar).
The squeezecenter is working properly as he uses softsqueeze from another computer to play music. DHCP, SSDP and NFS seem to work correctly because he gets through "Penguins Found", then SlimRIo splash screen. He can connect to the rio using nc, so network is working for sure. He tried to specify the server's ip in /sbin/init with -s option, but it doesn't help.
Any other idea?
Patrick
#315623 - 28/10/2008 07:58
[Re: elperepat]
I'm not sure what to suggest: if you give it the -s option, slimrio doesn't do anything fancy; it just sends UDP packets to port 3483 on the specified host, so it's hard to think of anything that could be wrong on the slimrio end. Is there anything in the server's log? Does the receiver show up on the server's list of recognised players (on the status page)?
Perhaps a tcpdump of traffic between the rio and squeezecenter would shed some light on what's going on.
#315637 - 29/10/2008 00:15
[Re: caederus]
Loc: Qc, Canada
Does the receiver show up on the server's list of recognised players (on the status page)? No, only the softsqueeze clients are showing, no trace of slimrio. Now, here are a few details on to the tcpdumps: mars.local is the server, 192.168.1.101 is the rio receiver and 192.168.1.20 is the softsqueeze client The first file (riotcpdump.txt) is the tcpdump of the rio getting it's ip from dhcp, then getting in touch with ssdp, then getting it's filesystem from the nfs server. Then, nothing. No request on port 3483. Second file (softsqueeze.txt) is a tcpdump from a softsqueeze connecting to the squeezecenter. Traffic on port 3483 without problem. Finally, last file (dhcpd.conf) is dhcp configuration. I tought the problem might be in here, but I can't find anything wrong. If we don't find a solution, we'll try to do the same on an other computer, runing ubuntu 6.06. We'll see... One last thing. in /proc/kmsg, my father's rio stop the log at "<4>Starting kswapd v 1.5", while mine continue further. Here's my receiver's log. nc doesn't seem to be "stable" as a lot of commands just hang it, so I suspect the abrupt end of files is linked to a nc crash. <4>Linux version 2.2.14-rmk4-mercury19 (robin@victoria) (gcc version 3.4.2 (release) (CodeSourcery ARM Q3D 2004)) #1 Mon Jul 16 17:37:22 BST 2007
<4>NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.
<4>IP-Config: Parameter #0: `192.168.0.101'
<4>IP-Config: Parameter #1: `192.168.0.23'
<4>IP-Config: Parameter #2: `111'
<4>IP-Config: Parameter #4: `255.255.255.0'
<4>IP-Config: Parameter #7: `off'
<4>Calibrating delay loop... 65.33 BogoMIPS
<4>Memory: 3156k/4M available (712k code, 20k reserved, 200k data, 8k init)
<4>Dentry hash table entries: 512 (order 0, 4k)
<4>Buffer cache hash table entries: 2048 (order 1, 8k)
<4>Page cache hash table entries: 1024 (order 0, 4k)
<4>POSIX conformance testing by UNIFIX
<6>Linux NET4.0 for Linux 2.2
<6>Based upon Swansea University Computer Society NET3.039
<6>NET4: Unix domain sockets 1.0 for Linux NET4.0.
<6>NET4: Linux TCP/IP 1.0 for NET4.0
<6>IP Protocols: ICMP, UDP, TCP
<4>TCP: Hash tables configured (ehash 4096 bhash 4096)
<4>empeg clps7212 audio driver initialized
<4>mercury display initialised.
<4>mercury infra-red support initialised.
<4>mercury rotary support initialised.
<4>mercury buttons support initialised.
<4>Probing for cs8900a
<4>eth0: cs8900 rev J found at 0x300 media RJ-45, IRQ 7 00 90 00 11 4f 1d
<4>IP-Config: Entered.
<4>eth0: using 10Base-T (RJ-45)
<4>IP-Config: Opened eth0 (able=0)
<4>IP-Config: device=eth0, local=b400a8c0, server=6500a8c0, boot=6500a8c0, gw=0100a8c0, mask=00ffffff
<4>IP-Config: host=192.168.0.180, domain=(none), path=`'
<5>Looking up port of RPC 100003/2 on 192.168.0.23
<5>Looking up port of RPC 100005/1 on 192.168.0.23
<5>VFS: Mounted root (NFS filesystem) readonly.
<4>Freeing unused kernel memory: 8k init
<5>init (1): unsupported llseek call standard
<5>bash (12): unsupported llseek call standard
<5>madplay (14): unsupported llseek call standard
<5>mad
Thanks for your help! Patrick
riotcpdump.txt (1103 downloads)softsqueze.txt (1047 downloads)dhcpd.conf (959 downloads)
Patrick
#315644 - 29/10/2008 21:45
[Re: elperepat]
Loc: Qc, Canada
Replying to my own post:
My father found out the problem. There was a mistake in the /sbin/init file he edited.
Everything works fine now, but he must have the -s option, even though it's only a simple network with only one squeezecenter. Anyway, all is working properly. Thank you very much for your help!
Patrick
Patrick
#373869 - 25/05/2022 23:26
[Re: Raymond Day]
I spent about a hole day installing this on Ubuntu Linux server. I all ready have Slimserver running on it. I had to stop the DHCP server on my router then my RIO got a IP after I got DHCP working on Ubuntu. I wanted to try and make it easy for some one else. It took me all day and made a list of commands I did. I will put them in here. But others will have to change the IP's and MAC addrss's. Just edit the code before you copy and paste each line in the command prompt of you Ubuntu server. I was logged in as root when I did this. apt-get install dhcp3-server
rv /etc/dhcp3/dhcpd.conf~ /etc/dhcp3/dhcpd.conf
rm /etc/dhcp3/dhcpd.conf
echo "authoritative;
subnet 192.168.2.0 netmask 255.255.255.0 {
range 192.168.2.3 192.168.2.100;
option domain-name-servers 192.168.2.1, 192.168.2.1;
option routers 192.168.2.1;
option static-routes 192.168.2.101 192.168.2.230;
option broadcast-address 192.168.2.255;
host HP-Photo-smart-2610-printer {
hardware ethernet 00:0d:9d:12:52:43;
fixed-address 192.168.2.2;
host RIO {
hardware ethernet 00:90:00:11:47:fc;
fixed-address 192.168.2.125;
}" >> /etc/dhcp3/dhcpd.conf
cd /
mkdir tftpboot
cd tftpboot
mkdir 192.168.2.125
cd 192.168.2.125
wget http://empeg.org.uk/slimrio/ssdp.c
wget http://empeg.org.uk/slimrio/download/slimrio-0.7-root.tar.gz
tar -xzf slimrio-0.7-root.tar.gz
apt-get install nfs-kernel-server nfs-common
echo "tftpboot/192.168.2.125 *(ro,sync,subtree_check,insecure,no_root_squash)" >> /etc/exports
exportfs -a
echo "while true; do /bin/slimrio -s 192.168.2.109; done" >> tftpboot/192.168.2.125/sbin/init It be nice if some one could put this in a script and have it ask for the numbers. Then all you have to do is run it and turn on your RIO. I had to set the "reduce the audio bit rate (Player settings - Audio - Bitrate limiting). You'll need to have the LAME encoder installed first." to 128. Now it don't studder the music. I guess some of the RIO code should be made in fast assembly code so it can do faster bitrates. I all ready had a LAME encoder installed. If you don't I guess all you have to do is this command: It's super to have the RIO display look like the slimp3 player. To bad the display is not wide like the slimp3. I am happy got this working. My RIO was just stitting there for years. Just to update Raymond's instructions, revive an ancient thread (and to maybe provide an answer to his 2021 post over here https://ubuntuforums.org/showthread.php?t=2456483). I have Rios running with Centos8 (soon to be Rocky) and had problems getting even to the "penguins found" screen in the boot process. Fired up Wireshark and had an error of NFS2ERR_OPNOTSUPP when trying to load zImage. I found you must enable NFS v2 and UDP for NFS is required -- the info here is key: https://pub.nethence.com/booting/pxe.netbsdTurns out I had to change to no_subtree_check and modify the last line of /tftpboot/RIOADDRESS/sbin/init to say "while true; do /bin/slimrio -s SLIMADDRESS; done" where the RIOADDRESS is the IP of the receiver and SLIMADDRESS is the IP of the LMS / SlimServer. My exportfs is now: /tftpboot/x.x.x.x *(ro,sync,no_subtree_check,insecure,no_root_squash) Hope this can help the very few wanting to keep these going. I plan to use them in the garage, etc.
Edited by admin69 (26/05/2022 08:44)
