#305645 - 02/01/2008 11:11
Re: Digital TV and the Goverment
[Re: Redrum]
#305649 - 02/01/2008 12:41
[Re: tman]
We've had a few discussions here in which US posters have thought it odd that we Brits pay the government in order to watch television... is that really any odder than, in the USA, the government paying you...?  Peter
#305650 - 02/01/2008 14:09
[Re: peter]
I'm sure that the amount of money they're getting for auctioning off the old NTSC spectrum vastly outweighs the amount they're paying to the few people who will sign up for $40 off a converter. (If that is, in fact, what all this is about. I can't seem to extract any information from the first web site, and, despite Trevor's assertion, the new web site is not "up".)
#305653 - 02/01/2008 15:10
despite Trevor's assertion, the new web site is not "up".) Works here.
#305660 - 02/01/2008 16:33
[Re: JBjorgen]
I'm more amazed that instead of the long, drawn out changeover procedure the UK is adopting, the US is simply turning it all off at once.
#305662 - 02/01/2008 16:53
[Re: andym]
I'm more amazed that instead of the long, drawn out changeover procedure the UK is adopting, the US is simply turning it all off at once. It's probably because they learned that adoption via a long, drawn out changeover procedure doesn't work so well. *cough*metric*cough*system*cough*
#305663 - 02/01/2008 17:19
The sites say the new frequencies are for emergency communication. So no new government money should be raise. However I'm skeptical too.
#305664 - 02/01/2008 17:25
[Re: andym]
I'm more amazed that instead of the long, drawn out changeover procedure the UK is adopting, the US is simply turning it all off at once. Do you have converted boxes in the UK? I can't seem to find one. I did a brief search on-line. I imagine this Feb 17 2009 date will be pushed back if none are available soon. People here will put up with a lot from the government but "we's got to has our TV."
Edited by Redrum (02/01/2008 17:26)
#305665 - 02/01/2008 17:34
[Re: tman]
That was easy to use. Not anything like our government. However when I filled it out it then told me the coupons expires in 90 days and no boxes are available yet, great! I should have waited.
#305667 - 02/01/2008 17:37
[Re: Redrum]
Do you have converter boxes in the UK?
They're called Freeview boxes, and are available everywhere and fairly cheap. Peter
#305668 - 02/01/2008 17:44
[Re: peter]
Thanks, do you know if they work well in poor reception areas? I know HD FM radio cuts out way before analog dies. I suspect the same for digital TV.
#305671 - 02/01/2008 18:16
[Re: Redrum]
They don't work at all well in poor reception areas; or, at least, not without upgrading the roof aerial. In some transmitter areas, including the Sandy Heath transmitter which serves Cambridge, roof-aerial replacement is basically unavoidable, as the analogue channels were all closely grouped together in frequency, so most houses had narrow-band aerials installed. But the replacement digital channels are all over the (relevant part of the) spectrum, requiring a wide-band aerial. Peter
#305672 - 02/01/2008 19:11
[Re: peter]
In some transmitter areas, including the Sandy Heath transmitter which serves Cambridge, roof-aerial replacement is basically unavoidable, as the analogue channels were all closely grouped together in frequency, so most houses had narrow-band aerials installed. I don't know if this was the case with the (communal) aerial at Jen's old flat, but the local council (who were responsible for it) stated only that they'd fix it before analogue was turned off. In the end, we moved house.
#305673 - 02/01/2008 19:35
[Re: Roger]
What will be really cool in the UK will be SFN. It would allow even more services as there's no need to worry about interference. I think once the changeover is complete in 2012 there will be a move to it.
Edited by andym (02/01/2008 19:35)
#305674 - 02/01/2008 19:40
[Re: andym]
What would interest me more would be HD Freeview.
#305675 - 02/01/2008 19:53
[Re: CrackersMcCheese]
It's technology like SFN that will make HD on Freeview possible.
#305676 - 02/01/2008 20:09
[Re: Redrum]
The sites say the new frequencies are for emergency communication. So no new government money should be raise. However I'm skeptical too. That is incorrect: 700 MHz wireless spectrum auction
#305678 - 02/01/2008 21:25
It was a half truth though:
"Block D of the spectrum will be used for a national public safety network."
#305693 - 03/01/2008 13:54
[Re: andy]
Alas, I don't think a converter will work well with the Casio 2"-ish portable TV I've had for years!
Harrumph.
Anyone know if the $40 coupon will work for a new digital portable? And who makes the good ones these day?
