#303814 - 03/11/2007 13:58 Need BIOS help?!?
Ladmo
Loc: Oklahoma
I've been trying to figure out how to get my BIOS updated on my backup computer, and it has been a pain, probably cuz I don't know what I am doing.
It's a home brew computer so I ran a utility called ADIA32 to see what it had inside it. It reads the motherboard info and BIOS as listed below.
I have gone to Phoenix's website which was usless. I did google, but I could not find my motherboard or old or new bios listed....Am I hosed? Since about everyone on this board is more techie than I am, I am really hoping someone happens to know how/where to get this from. I really don't want to turn the motherboard into a brick...
Many Thanks!
**********MOTHERBOARD****************
Motherboard Properties
Motherboard ID 01/07/2005-KT600-8237-6A6LYA1HC-14
Motherboard Name Unknown
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 200 MHz (DDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 280 MHz (DDR)
Effective Clock 560 MHz
Bandwidth 4480 MB/s
Chipset Bus Properties
Bus Type VIA V-Link
Bus Width 8-bit
Real Clock 80 MHz (ODR)
Effective Clock 640 MHz
Bandwidth 640 MB/s
********BIOS******************************
BIOS Properties
BIOS Type Award
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message
System BIOS Date 01/07/05
Video BIOS Date 04/07/05
BIOS Manufacturer
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
Problems & Suggestions
Suggestion System BIOS is more than 2 years old. Update it if necessary.
Suggestion Video BIOS is more than 2 years old. Update it if necessary.
#303815 - 03/11/2007 14:01 Re: Need BIOS help?!? [Re: Ladmo]
Best bet is to look inside the box at the top of the motherboard. Somewhere, it probably has the model number silk-screened (painted) onto the surface. Google that model number along with "BIOS".
#303816 - 03/11/2007 14:15 Re: Need BIOS help?!? [Re: mlord]
Ladmo
Loc: Oklahoma
Nope, not that I can find...all I can find is a sticker that says KV7V-C51000924
#303817 - 03/11/2007 14:19 Re: Need BIOS help?!? [Re: Ladmo]
Have you ruled out the possibility that it's an Abit KV7V?
#303818 - 03/11/2007 14:22 Re: Need BIOS help?!? [Re: peter]
Ladmo
Loc: Oklahoma
Yes! It is an ABIT board...thanks...now I just need to figure out which bios to use...
#303819 - 03/11/2007 14:24 Re: Need BIOS help?!? [Re: Ladmo]
Motherboard page here, bios download here.
#303820 - 03/11/2007 14:26 Re: Need BIOS help?!? [Re: peter]
That's what the bios string seems to indicate as well. Abit KV7V
#303821 - 03/11/2007 15:02 Re: Need BIOS help?!? [Re: JBjorgen]
Ladmo
Loc: Oklahoma
Thanks for all the help! I followed the directions (a first for me!) and it worked great!
Thanks again for all the help and proving that you are still willing to help an idiot who doesn't even have a working empeg!
#303822 - 03/11/2007 15:18 Re: Need BIOS help?!? [Re: Ladmo]
Attack
Loc: Florida
Download and run CPU-Z. Then click on the Mainboard tap, this will show you your motherboard make, model and current bios version.
Chad
#303823 - 03/11/2007 15:19 Re: Need BIOS help?!? [Re: Ladmo]
Any particular reason why you want to update the BIOS?
#303824 - 05/11/2007 03:11 Re: Need BIOS help?!? [Re: Ladmo]
SuperQ
Loc: Berlin, DE
The best app I know for getting board/BIOS info is for linux. It's called "dmidecode" and should be included with most linux rescue USB/CD images.
80gig red mk2 -- 080000125
