#301592 - 16/08/2007 19:04 Another "No hard disk found" diagnosis
This is a KNOWN GOOD DISK, built in another empeg and working just fine.
When this drive is transferred to the "broken" empeg, I get the attached bootlog. Any hints as to what the problem could be from the log? The header doesn't have any visibly separated pins, I definitely wouldn't rule it out.
302668-boot.txt (175 downloads)
#301593 - 17/08/2007 12:48 Re: Another "No hard disk found" diagnosis [Re: JBjorgen]
maczrool
Loc: Louisiana, USA
It looks like either a cable or header problem. The cable may be coming apart and just happen to have worked in the other Empeg. I've seen this many times. How long ago did you build the drive in another Empeg? Can you try swapping a know good cable into the Empeg with the problem and see what happens?
Hope this helps,
Stu
#301594 - 17/08/2007 13:54 Re: Another "No hard disk found" diagnosis [Re: maczrool]
Drive was built about 3 minutes before in another empeg. Uploaded music and worked fine. The cable is a replacement cable with fantastic crimps. Tried with another known working cable. Same problem. Tried with another known working drive. Same problem. Looks like it's a header issue.
#301595 - 01/09/2007 17:54 Re: Another "No hard disk found" diagnosis [Re: JBjorgen]
Sent to Stu and he fixed it up (retouched header) and sent it back fairly quickly. Worked great upon return. Excellent service!
