#299744 - 26/06/2007 23:40 Graceful shutdown of Rio Central???
laserfan
Loc: Frozen North
Living in an area of frequent storms & power failures and wondering about subject. I can't find anything to suggest there is any more graceful way to shut-down the Central than to pull the plug on it!!! Izzat so? I can't Telnet into it and try 'shutdown -h now' or some such...?
Just looking for a better way to do this given I have a UPS with Command capability. Anyone?
#299745 - 27/06/2007 15:09 Re: Graceful shutdown of Rio Central??? [Re: laserfan]
Does your Central do something bad if it's not gracefully shut down?
I'm pretty sure it's designed so that yanking the power doesn't hurt it in any way.
Do you ever worry about gracefully shutting down your CD player, your TV, or for that matter, your refrigerator? The central was meant to be an appliance, just like those.
If there is something that's going wrong with your central after coming back from a power outage, we can look at that particular problem and try to fix it.
#299746 - 28/06/2007 10:49 Re: Graceful shutdown of Rio Central??? [Re: tfabris]
laserfan
Loc: Frozen North
No, at least not that I know of. I'm just a worrywart!!!! I have some other Linux based gizmos i.e. Toshiba Magnia server and Tivo... takes a long time to re-boot these guys after "pulling the plug" cuz I think they go thru a full file-check after a graceless shutdown. Can't imagine that a sudden shutdown is good for the hard drive(s).
Surprised I guess that so little has been done w/the Central re: hacking it--I think if all we had was Telnet access then I could shut it down...
#299747 - 28/06/2007 12:31 Re: Graceful shutdown of Rio Central??? [Re: tfabris]
It is. Same as the car player.
#299748 - 28/06/2007 14:40 Re: Graceful shutdown of Rio Central??? [Re: laserfan]
Fortunately this doesn't apply to the Central.
Doesn't hurt them at all.
The only potential issue is if you were in the middle of a write operation when the power was lost, and the central runs a journaled filesystem so even *that* isn't a problem.
Telnet access exists for the Central, it just requires an additional piece of hardware connected to the correct pins on the motherboard. I forget what this hardware is called, but it's been mentioned elsewhere on this BBS.
You can also reach a shell prompt simply by plugging in a USB keyboard and pressing ctrl-alt-del.
#299749 - 28/06/2007 14:52 Re: Graceful shutdown of Rio Central??? [Re: tfabris]
Yes. And if you don't even trust the journalled filesystem, you just have to wait until the Central is quiescent: the only time it's ever "in the middle of a write operation" is when syncing, ripping, or (as indicated by the little "cogs" icon) encoding ripped tracks.
Actually that's for serial console access. Telnet access just requires installing and running telnetd...
...which is the easiest way to gain enough control to install and run telnetd.
#299750 - 28/06/2007 15:43 Re: Graceful shutdown of Rio Central??? [Re: peter]
Sorry. Briefly got "serial shell" and "telnet shell" mixed up. I'm always switching those terms around, since to me, the look exactly the same. I know the difference between them (the former is a hard wired connection requiring physical proximity, the latter is a network connection requring the proper server-side software to be installed and running), I just think of them in the same way. I probably shouldn't.
Anyway, to clarify it for the original poster: You can get a shell prompt right on its screen (via a USB keyboard), you can do a serial connection (with the right hardware dongle connected to certain pins on the motherboard), and you can do a telnet connection (if you can figure out how to install/activate a telnet server via the USB keyboard).
#299751 - 28/06/2007 23:57 Re: Graceful shutdown of Rio Central??? [Re: tfabris]
laserfan
Loc: Frozen North
You can get a shell prompt right on its screen (via a USB keyboard...
When I run-out of things to play with, maybe I will give this a try, thanks...
