#296366 - 04/04/2007 13:37 Bigdisk builder gets stuck on "Selecting pump device" on 120G Samsung
julf
Trying to add a 120G disk, I am trying to run the "Mark Lord Special Disk Builder" (builder_bigdisk.upgrade), it gets to "Selecting pump device" but then nothing further happens.
The disk is a 120G Samsung, connected as the main and only disk.
Any hints/suggestions?
#296367 - 04/04/2007 13:55 Re: Bigdisk builder gets stuck on "Selecting pump device" on 120G Sams [Re: julf]
Mmm.. I've never actually used the builders myself, or at least not on any drive over 30GB. They reportedly do work, though. So I wonder what's strange in this case. Master/slave jumper?
Any chance of a serial port capture (log) ?
#296368 - 04/04/2007 15:27 Re: Bigdisk builder gets stuck on "Selecting pump device" on 120G Samsung [Re: julf]
#296369 - 04/04/2007 15:28 Re: Bigdisk builder gets stuck on "Selecting pump device" on 120G Sams [Re: mlord]
julf
Found the problem - the classic bent IDE header on main board
Guess what I have to do is switch over the display board and the disks from this one to the spare unit (that has a failing rotary encoder). Are the display boards of MK II:s and Rio's interchangeable?
#296370 - 04/04/2007 15:39 Re: Bigdisk builder gets stuck on "Selecting pump device" on 120G Sams [Re: julf]
Yes, quite interchangeable.
#296371 - 04/04/2007 16:20 Re: Bigdisk builder gets stuck on "Selecting pump device" on 120G Sams [Re: julf]
As long as you remember that the knob is different for the Mk2 encoder shaft and the Rio Car enoder shaft.
#296372 - 04/04/2007 16:25 Re: Bigdisk builder gets stuck on "Selecting pump device" on 120G Sams [Re: tfabris]
julf
Ahh, good point, thanks!
