#296175 - 01/04/2007 17:06 Mac OSX Root Directory across network?
With Windows boxes, and an administrator's password, I can reach their hidden root directory share across the network by going to the following share URL:
\\boxname\c$
What's the equivalent URL to reach the root directory of a Mac OSX box across the network?
#296176 - 01/04/2007 17:19 Re: Mac OSX Root Directory across network? [Re: tfabris]
AFP://boxname/NameOfRootDrive
Via SMB, you need something like SharePoints to share anything beyond home directories. Lepoard will have similar functionality (finally). Keep in mind that even as an "admin" user, writing to files at the root or other places is usually restricted. You will only be able to modify files where you normally can on the local machine without seeing the authentication popup.
#296177 - 01/04/2007 18:12 Re: Mac OSX Root Directory across network? [Re: drakino]
So in other words, I can't do it (without sharepoints) from a Windows box because windows boxes only speak Samba?
#296178 - 01/04/2007 18:56 Re: Mac OSX Root Directory across network? [Re: tfabris]
Windows boxes (and OS/2) speak SMB, correct. Samba is a program used to speak SMB on non MS/IBM platforms, like OS X.
Sharepoints isn't required, but makes it easier in your case then learning how to edit the smb.conf file on OS X to share what you want. OS X by default only shares user folders via SMB when it is enabled, unlike Windows where it also shares the entire hard drive.
AFP is Apple's network file protocol, dating back to the days of AppleTalk networks. On OS X when enabled, it shared the entire disk to admin users, and user folders. There was an AFP client for Windows that Microsoft included, but it was dropped in XP and above, likely due to MS not wanting to update it to the OS X version 3 protocol.
#296179 - 01/04/2007 18:57 Re: Mac OSX Root Directory across network? [Re: tfabris]
That's nearly always the problem. Mac's, Linux's, and other OSs generally speak many tongues, but white man from Redmond refuseth to listen.
But Mac's do run Samba, which is a form of Redmond-speak, so you oughta be able to get it working.
I'll try it here, once my G3 OS/X reinstall finishes.
#296180 - 02/04/2007 01:21 Re: Mac OSX Root Directory across network? [Re: tfabris]
If you don't care about security at all, you could add something like this to your smb.conf file. (disclaimer: I don't own a mac...this would work under linux)
[root$]
path = /
read only = no
guest ok = yes
guest only = yes
public = yes
#296181 - 02/04/2007 02:03 Re: Mac OSX Root Directory across network? [Re: mlord]
Heh.. ran into a bit of bad RAM troubles here.. still working on it.
#296182 - 02/04/2007 15:01 Re: Mac OSX Root Directory across network? [Re: JBjorgen]
I do care about security, unfortunately. But thanks.
#296183 - 02/04/2007 15:03 Re: Mac OSX Root Directory across network? [Re: tfabris]
And yet you use Windows.
