#295536 - 19/03/2007 22:57
Help EMPEG has locked up and refuses to unlock.
Loc: Reading UK
Herro
When I start my EMPEG it is freezing at the point when it should begin playing the music. I cannot unfreeze it and the USB and LAN sockets are not functioning. I have taken this log from the serial port. I can see it is not getting me to the command prompt before it freezes. It continues to echo characters to the screen but they have no effect.
Can you clever chaps tell me how to fix it please? I have searched the FAQs.
Cheers. SW is V3.11. Audio was a .OGG.
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #16 Mon Jul 25 18:54:48 BST 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read 9afffff0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101510) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004f80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e 6 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k init player.cpp : 587:empeg-car 3.00-al pha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#295537 - 19/03/2007 23:14
Re: Help EMPEG has locked up and refuses to unlock.
[Re: estocks]
Hit Control^C on the serial port after the log you posted appears.
#295538 - 20/03/2007 00:04
[Re: estocks]
Quote: I can see it is not getting me to the command prompt before it freezes.
As Mark said, ctrl-C or ctrl-break at some point during the boot sequence will drop it to the shell prompt before it tries to play the bad track.
Quote: I have searched the FAQs.
The one you're looking for, and the thing that Mark is suspecting (and I am too) is this problem.
See if that fixes it for you.
#295539 - 20/03/2007 22:47
Loc: Reading UK
OK here is my log of pressing Control C, sorry!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #16 Mon Jul 25 18:54:48 BST 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read 9afffff0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101510) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005000). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive hda: WDC WD600VE-75HDT1, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e 6 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initPlayer received SIGINT, user interruption Switching to shell-player loop cStarting bash. no shell! Shell exit cPlayer received SIGINT, user interruption Switching to shell-player loop Shell exit player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Player received SIGINT, user interruption Switching to shell-player loop Shell exit player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Player received SIGINT, user interruption Switching to shell-player loop Shell exit player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. CProlux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000 ^HPlayer received SIGINT, user interruption Switching to shell-player loop Starting bash. no shell! Shell exit Player received SIGINT, user interruption Switching to shell-player loop Starting bash. no shell! Shell exit player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000 Player received SIGINT, user interruption Switching to shell-player loop Starting bash. no shell! Shell exit player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Player received SIGINT, user interruption Switching to shell-player loop Starting bash. no shell! Shell exit player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25. Prolux 4 empeg car - 2.1485 Jul 25 2005 Vcb: 0x4073a000
#295540 - 21/03/2007 10:14
[Re: estocks]
Been a while since 'I read an empeg boot log, but I believe you've got the consumer version of the software loaded on the player - it doesn't provide a shell. Load the 'developer' version instead and try again!
#295541 - 21/03/2007 10:34
[Re: mtempsch]
Which you can find at the Latest Software link at the top of the page. I'd recommend the v2.00 developer edition if you have an unmodified empeg.
#295542 - 21/03/2007 13:52
[Re: estocks]
Quote: Starting bash. no shell! Shell exit
You definitely have the consumer version of the firmware installed. You can't fix the problem unless you install the developer version of the firmware.
Remember above, where I said...
Quote: The one you're looking for, and the thing that Mark is suspecting (and I am too) is this problem.
... Well, that link I gave is very specific on that point: you need the developer firmware installed to fix it. Please follow the steps at that link carefully.
#295543 - 21/03/2007 15:21
Quote: Please follow the steps at that link carefully.
Tony, you might want to correct the "Hypterterminal" typo at that link.
#295544 - 21/03/2007 15:46
[Re: estocks]
Loc: Bendorf, Germany
What also should help is hitting the "forward" button during the boot process repeatedly until it skips the song that locks up the player. I had the same problem recently and it worked for me.
#295545 - 21/03/2007 15:49
[Re: dr_dos]
Yeah. Happens to me about once a month. I've learned how to skip it on bootup so it's not a big deal any more.
#295546 - 21/03/2007 16:10
[Re: Roger]
Quote: Tony, you might want to correct the "Hypterterminal" typo at that link.
Gah. Done.
#295547 - 21/03/2007 21:05
[Re: estocks]
Loc: New Jersey, United States
My Empeg also locks up when displaying the birth days.
I'm running v3.00 A11.
The only difference between science fiction and reality is about 60 years. 100GB MK2 Green 080000171 + OEM tuner v3.00a11 hijack v450 jEmpload v70
#295548 - 23/03/2007 21:45
[Re: mtempsch]
Hey Mike. Long time no see. How's things?
#295549 - 24/03/2007 07:55
[Re: schofiel]
Quote: Hey Mike. Long time no see. How's things?
Reasonably well - though it sucks still not being allowed to drive...
#295550 - 21/05/2007 21:27
[Re: mtempsch]
I am sure Anita will be only to happy to sort that out for you
