#29492 - 13/04/2001 08:02 X on empeg
fvgestel
Loc: Netherlands
as an experiment, I've setup an X-environment on my empeg. look at the attachments for screenshots.
Frank van Gestel
Frank van Gestel
#29493 - 13/04/2001 08:03 Re: X on empeg [Re: fvgestel]
fvgestel
Loc: Netherlands
and windowmaker...
Frank van Gestel
Frank van Gestel
#29494 - 13/04/2001 08:39 Re: X on empeg [Re: fvgestel]
You're certifiably insane, Frank, you know that?
I like it.
#29495 - 13/04/2001 10:15 Re: X on empeg [Re: fvgestel]
phaigh
Coooooooooooooooooooool.
Performance must be pretty bad.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#29496 - 13/04/2001 10:35 Re: X on empeg [Re: fvgestel]
eternalsun
Loc: San Jose, CA
Wow.....
Calvin
#29497 - 13/04/2001 10:47 Re: X on empeg [Re: eternalsun]
loren
I'll second that with a "holy crap" =]
|| loren.cox ||
|| loren ||
#29498 - 13/04/2001 14:07 Re: X on empeg [Re: phaigh]
fvgestel
Loc: Netherlands
Actually, it was quite workable. What you saw in the xterm were all the processes running on the empeg. Of course I stopped the player first and I only tested the config-util for windowmaker, but that worked pretty smooth. It would be funny to run ethereal on it and have a portable sniffer
BTW, It's also possible to run a VNC-server on it, so you could login using a webbrowser
Frank van Gestel
Frank van Gestel
#29499 - 13/04/2001 16:56 Re: X on empeg [Re: fvgestel]
Janosch
Loc: Berlin, Germany
Just a matter of time until we will see a debian based complete empeg linux distributiion from you frank, right ? Great Job....checked your homepage but couldn't find anything related to you X Installtion....will there be some kind of "how to" some day ? Having a portable Ethereal would be so nice.........
janosch
#29500 - 14/04/2001 01:17 Re: X on empeg [Re: Janosch]
fvgestel
Loc: Netherlands
Once you've got the debian tarball installed, you can go to ftp.debian.org and fetch all packages you like and install it using the dpkg command.
For X you need to install the base X-package, some fonts, a windowmanager and xdm for graphical login.
If someone knows the command to show all installed packages ala "rpm -q -a", I can give a complete list.
Frank van Gestel
Frank van Gestel
#29501 - 14/04/2001 05:18 Re: X on empeg [Re: fvgestel]
mtempsch
dpkg -l lists all available packages, with their status first on the line.
Something like dpkg -l | grep ^ii should give you
all installed packages. (That's a literal caret (^), not to be confused to represent Ctrl)
The info is also, normally, found in more human readable form in /var/lib/dpkg/status
#29502 - 14/04/2001 11:09 Re: X on empeg [Re: fvgestel]
synergy
dpkg --get-selections will return your package list.
dpkg --set-selections will take the same list on another machine and make a pseudo-clone. (pseudo in the fact that any customizations that are not in the dpkg .deb file will not carry over... But it's a hell of a start. )
