#294203 - 24/02/2007 19:26 Does This Look Right?
JeffreyB
Loc: Cincinnati, OH
Does this log look OK? My Empeg has been working fine, no problems, but I see in the log a bunch of read and writes to registers on the IDE interface that don't match. It looks like there's a stuck bit, but the unit works fine. I'm totally confused...
JeffreyB
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v464 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Oct 27 01:00:29 EDT 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102985) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb84
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005e80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xff80
ide_data_test: wrote 0xffff read 0xff80
ide_data_test: wrote 0xaaaa read 0xaa80
ide_data_test: wrote 0x5555 read 0x5580
ide_data_test: wrote 0x0000 read 0xff00
ide_data_test: wrote 0xffff read 0xff00
ide_data_test: wrote 0xaaaa read 0xaa00
ide_data_test: wrote 0x5555 read 0x5500
hda: ST9100823A, ATA DISK drive
ide_data_test: wrote 0x0000 read 0xffa5
ide_data_test: wrote 0xffff read 0xffa5
ide_data_test: wrote 0xaaaa read 0xaaa5
ide_data_test: wrote 0x5555 read 0x55a5
hda: ST9100823A, 95396MB w/8192kB Cache, CHS=12161/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:a9
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... | / - \ | / - \ | / - \ | / - \ | / - \ done.
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Starting player
Timezone: EST
/drive0/var/ttsclock: getopts: `Option': not a valid identifier
Saved AC volume was 74
Volume=74
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
#294204 - 24/02/2007 20:59 Re: Does This Look Right? [Re: JeffreyB]
It's fine. The IDE messages are only meaningful when the player is obviously broken (not working).
#294205 - 25/02/2007 14:52 Re: Does This Look Right? [Re: mlord]
JeffreyB
Loc: Cincinnati, OH
Thanks Mark!
Jeff
#294206 - 04/04/2007 17:56 Re: Does This Look Right? [Re: mlord]
mutter, mutter
The FAQ says:
The last four ide_data_test lines should have the same wrote and read values if things are working correctly. For example, here is a screen showing a normal 'good' boot:
ide_data_test: wrote 0x5555 read 0x0080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: IBM-DJSA-230, ATA DISK drive
And yet JeffreyB has:
and both our empegs say:
ide_data_test: wrote 0x0000 read 0xffff
hda: FUJITSU MHL2300AT, ATA DISK drive
It's easy to miss the bit of the FAQ that suggests that this is only a problem if you're having HD problems.
So may I ask:
* why do I get wrote 0x0000 read 0xffff on both my machines?
* should the FAQ emphasise that ide_data_test is not an error but only a diagnostic for other symptoms. In other words don't start pulling your ide cables apart just to cure odd ide_data_test messages?
Possibly replace:
However, if you are having hard disk trouble, these messages can be used to help diagnose the problem.
with:
However, if (and only if) you are having hard disk trouble, these messages can be used to help diagnose the problem. You should not treat these messages as a problem even if the last few wrote/read pairs show different values and certainly shouldn't start playing with IDE cables (and potentially causing real damage) without real symptoms.
I read Marks posts on the subject and looked at the code in ide-probe but was none the wiser.
I also changed the udelay(1) to udelay(2) and added in an extra call to ide_data_test(drive, 0x0000) after the others.
I always get
but now I get more random values between the outw() and inw() so I'm putting it back --- eek!
#294207 - 04/04/2007 18:01 Re: Does This Look Right? [Re: LittleBlueThing]
I reverted the udelay change and left the extra ide_data_test call.
Now I get:
so my last 4 match so I'm happy
#294208 - 04/04/2007 18:46 Re: Does This Look Right? [Re: LittleBlueThing]
If our resident expert and master of all things IDE (Mark) confirms that your suggested wording for the FAQ is accurate, then I'll update it.
Mark?
#294209 - 04/04/2007 19:57 Re: Does This Look Right? [Re: tfabris]
Mark?
My response to this was posted much earlier, higher up in this very thread:
#294210 - 04/04/2007 20:41 Re: Does This Look Right? [Re: mlord]
Yes I know - I read it
However I didn't come straight here.... being a good boy the first thing I did when I saw this odd mismatch for real on my systems was to read the FAQ.
Then after reading the FAQ I thought I had a problem that simply hadn't tripped up the player.
In particular "if you are having hard disk trouble" came across as "if your hard disks are flakey then you may get these messages".
Then I did some research before following the FAQ suggestion of taking my empeg to bits...
Then I found this post.
And there was just this short "it's fine" message which left me a bit confused since it *looked* broken.
Then I checked all your other posts about this message.
Then I looked at the source.
Then I played a bit.
THEN I asked my followup question.
Okay?
Oh, and since I thought others may see these messages and be confused I drafted a modification to the wording - but since there's no info about this (even in the code) I thought Tony's suggestion of asking you was sensible - but since it sounds like you're feeling grumpy and it "works for me" I can just drop it.... ?
#294211 - 04/04/2007 21:17 Re: Does This Look Right? [Re: LittleBlueThing]
FAQ updated. Thanks BlueThing and Mark.
