#293061 - 26/01/2007 14:21 Syncing problems
For some reason I cannot sync more than about 3GB of music on my old empeg. After that, it keeps giving me errors and refuses to load more tracks. I started with no music, added about 2GB worth, and started getting errors in both emplode and jemplode. Then I rebuilt the two drives, installed the software, and tried again. Same result with completely different files. It looks like it stops after something like FID 6400.
I've attached a boot log if it helps diagnose. Thanks for any help!
293624-boot01.txt (258 downloads)
#293062 - 26/01/2007 14:59 Re: Syncing problems [Re: Dignan]
maczrool
Loc: Louisiana, USA
Are you copying and pasting from hyperterminal? The boot log is a little jumbled looking. Try using the text capture feature and post the log.
Thanks,
Stu
#293063 - 26/01/2007 15:15 Re: Syncing problems [Re: maczrool]
To clarify what Stu just said: The Windows XP version of hyperterminal has a bug when you try to copy text out of it. The text gets scrambled. So to grab a boot log that others can read, you have to use the "Capture Text" feature instead.
#293064 - 26/01/2007 15:32 Re: Syncing problems [Re: maczrool]
In addition to posting an unscrambled boot log, we really need to see a log from the failed music upload, not from the disk builder.
#293065 - 26/01/2007 15:33 Re: Syncing problems [Re: tfabris]
No problem. Sorry about that. Here's the correct one, hopefully.
293633-CAPTURE.TXT (164 downloads)
#293066 - 26/01/2007 15:38 Re: Syncing problems [Re: Dignan]
Oops. Did that wrong. Here's the boot log. I'll get the other one in a second...
293634-CAPTURE.TXT (208 downloads)
#293067 - 26/01/2007 15:41 Re: Syncing problems [Re: Dignan]
Question: Are you loading only music or a lot of playlists?
I have found when rebuilding players from scratch that there seems to be a hard limit to the amount of playlists you can upload at any given time. And, since the playlists are created before the music is uploaded, emplode will crash each time.
The workaround I use for this specific issue is to create a mirror empty directory tree on your PC and upload the playlists a chunk at a time. Then do the music.
#293068 - 26/01/2007 15:58 Re: Syncing problems [Re: pgrzelak]
That doesn't seem to be the problem. After starting from scratch, I was only uploading about 10 albums at a time, which probably only created 20 playlists at most. When I reach a certain point, I can't upload anything at all. Not even one album.
I've attached a sync log.
293636-CAPTURE.TXT (219 downloads)
#293069 - 26/01/2007 17:48 Re: Syncing problems [Re: Dignan]
Okay. This is an Empeg Mk2 unit, with only 12MB of DRAM.
It is running out of physical memory during the sync.
Not much to be done here, other than enabling swap beforehand (I think this was already tried here, right?), and/or doing smaller uploads.
Edited by mlord (26/01/2007 17:51)
#293070 - 26/01/2007 17:50 Re: Syncing problems [Re: mlord]
It is running out of memory during the sync.
Mmmm.. I wonder if we might "cure" this by having Hijack ignore mlock() and mlockall() calls, as an option. This would permit swapping of player memory, which is not normally possible.
Mmm..
#293071 - 26/01/2007 17:55 Re: Syncing problems [Re: mlord]
Perhaps I loaded too much on at a time at first (which I don't think I did, I've done much bigger uploads in the past). But would that cause permanent damage? That log is from trying to sync one single album to the player.
#293072 - 26/01/2007 17:57 Re: Syncing problems [Re: mlord]
Mmm..
Okay, install this Hijack kernel after repairing your filesystems, and see if it fixes the upload problem. Replace with a "real" Hijack kernel afterwards.
http://rtr.ca/v467+.zImage
#293073 - 26/01/2007 17:59 Re: Syncing problems [Re: mlord]
My apologies, but I'm not sure how to do the filesystem repair.
#293074 - 26/01/2007 18:25 Re: Syncing problems [Re: Dignan]
It's in the FAQ, somewhere. Hopefully FaqMaster will hand us a link..
#293075 - 26/01/2007 18:39 Re: Syncing problems [Re: mlord]
#293076 - 26/01/2007 19:34 Re: Syncing problems [Re: mlord]
Okay. This is an Empeg Mk2 unit, with only 12MB of DRAM. It is running out of physical memory during the sync.
Just to play Devil's Advocate... Um, shouldn't the player firmware, the kernel, and Emplode all just Do The Right Thing so that the player doesn't run out of memory during big file uploads? Doesn't a big file upload like this Just Work for pretty much everyone else? (Except for the aforementioned and already-known Too Many Playlists bug.)
#293077 - 26/01/2007 19:38 Re: Syncing problems [Re: mlord]
Mmm..
Hmm, I may have already run into a problem. I ran fsck on hdc4 and it went fine, but when I try it on hda4 I get the following:
empeg:/empeg/bin# fsck -fay /dev/hda4
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
The filesystem size (according to the superblock) is 156183930 blocks
The physical size of the device is 134110620 blocks
Either the superblock or the partition table is likely to be corrupt!
Abort? yes
empeg:/empeg/bin#
#293078 - 26/01/2007 19:42 Re: Syncing problems [Re: Dignan]
That's bad. I'd run the builder again, if I were you.
#293079 - 26/01/2007 19:53 Re: Syncing problems [Re: wfaulk]
Crap. Question: which drive is hda4? Is it the one with or without a jumper?
#293080 - 26/01/2007 20:08 Re: Syncing problems [Re: Dignan]
It would be the "master", whichever jumper configuration that is.
#293081 - 26/01/2007 20:09 Re: Syncing problems [Re: wfaulk]
maczrool
Loc: Louisiana, USA
A jumper makes the drive a slave.
Stu
#293082 - 26/01/2007 20:24 Re: Syncing problems [Re: maczrool]
Crap, then that's my 160GB drive. I really hope that doesn't die. The build is proceeding, but I noticed this error in the log:
hda: read_intr: status=0x59
hda: read_intr: error=0x40...VFS: Mounted root (ext
end_request: I/O error, dev 03:04 (hda), sector 311820292
change_root: old
EXT2-fs error (device ide0(3,4)): read_inode_bitmap: Cannot read inode bitmap -
block_group = 19032, inode_bitmap = 155910146: "Hard Disk Detection"
#293083 - 26/01/2007 21:04 Re: Syncing problems [Re: wfaulk]
Rebuilt the drive. I had some odd behavior the drive builder, but it seemed to work. Then I installed the firmware. Now I've tried to upload a single album, and got an error that said something like "Operation exceeded maximum retry count" in jemplode.
#293084 - 26/01/2007 21:11 Re: Syncing problems [Re: Dignan]
Oh. 160GB. You have to take special measures to use a drive that big. That may be the problem. Some of the particulars are over here.
#293085 - 26/01/2007 21:12 Re: Syncing problems [Re: Dignan]
maczrool
Loc: Louisiana, USA
If you are suspecting it to be one drive or the other, try the upload with the drive you think is okay and keep the other one disconnected, removing the slave jumper on the connected drive (if any) of course.
Stu
#293086 - 26/01/2007 21:20 Re: Syncing problems [Re: wfaulk]
In theory, Mark's latest builders (now correctly linked from the main Drive Upgrade Guide) should handle this properly, assuming that he puts the latest hijack back onto the player as soon as the player software gets installed and before anything else gets written to the drive.
In theory.
#293087 - 26/01/2007 21:26 Re: Syncing problems [Re: tfabris]
Just peeked at the drive upgrade guide. In theory, he was using (a) Mark's bigdisk builder, and (b) 2.01 Final For Large Disks upgrade file. If so, the manual procedures at Roger's site shouldn't be needed.
Again... in theory. :-)
#293088 - 26/01/2007 21:47 Re: Syncing problems [Re: tfabris]
Is it actually called "(b) 2.01 Final For Large Disks upgrade file"? If so, I wasn't using that. I was using the files off of the empeg site...
#293089 - 26/01/2007 21:56 Re: Syncing problems [Re: Dignan]
Those old ones (empeg site) don't have a hope of working with a 160GB drive.
#293090 - 26/01/2007 22:15 Re: Syncing problems [Re: Dignan]
<adam savage> Well THERE'S yer problem! </adam savage>
Go back to the original drive upgrade guide, which has recently been updated with links to both mark's bigdisk builder and mark's 2.01 for large disks. Read through the section about formatting the drive and make sure to scroll down to the part where it says SPECIAL NOTE FOR LARGE DISKS.
