#289363 - 06/11/2006 04:09 How to kill a political phone robot
My neice found, by accdent, how to stop one of those phone robots cold. She's been working at the Alldata call center for a few weeks, and for some odd reason when she answered the phone tonight she started to say "Thank you for calling..." at which point the robot said sorry and hung up.
#289364 - 06/11/2006 14:23 Re: How to kill a political phone robot [Re: gbeer]
siberia37
Loc: Tacoma,WA
Maybe it has some kind of AI to detect when it calls business lines? Weird.
#289365 - 06/11/2006 15:09 Re: How to kill a political phone robot [Re: gbeer]
I'm not sure how the phone system in the US works, but here in the UK a good tip is to hit the recall button, that should give you dial tone and put the person/robot on hold, then hang up the phone, the exchange will ring you back so you can take the call on hold, don't answer it, after a few rings it gives up and the call is dropped
Although your idea sounds pretty good for live cold callers too.
Cris.
#289366 - 06/11/2006 15:58 Re: How to kill a political phone robot [Re: Cris]
Why not just hang up in the first place?
I get bothered by junk FAX machines, so I keep a list of blocked numbers in my VOIP control panel. Obviously these calls have to come in with valid CallerID for the system to sort and deny them.
#289367 - 06/11/2006 16:31 Re: How to kill a political phone robot [Re: hybrid8]
Because they keep calling. And calling. And calling. ("They" being GOP-paid polling outfits who pretend to speak on behalf of the Democratic candidates):
http://www.tpmmuckraker.com/archives/001940.php
http://www.theleftcoaster.com/archives/009152.php
http://www.dailykos.com/storyonly/2006/11/5/225745/298
http://www.prospect.org/weblog/2006/11/post_1891.html
On the bright side, tactics as desperate as these do make me a little less worried that they're stealing the election outright by manipulating voting machines.
#289368 - 06/11/2006 16:37 Re: How to kill a political phone robot [Re: tonyc]
Cybjorg
Loc: Winston Salem, NC
I read about a cool trick using the 3-tone beep (attached) on an answer machine. The trick is to record the 3-tone beep on the first second of your answer machine message, and then start the actual message. A robot that calls a number and "hears" the beep will immediately disconnect and the computer system will log the number as being disconnected.
EDIT: This page does a better job of explaining the concept.
290136-sit.wav (79 downloads)
Edited by Cybjorg (06/11/2006 16:39)
#289369 - 06/11/2006 17:04 Re: How to kill a political phone robot [Re: Cybjorg]
Ooo. Now that is awesome. I'm gonna do that on my answering machine.
#289370 - 06/11/2006 17:09 Re: How to kill a political phone robot [Re: tfabris]
Other than these political ads, which will certainly stop by tomorrow, I have gotten no telemarketing calls since a few weeks after registering on the Do Not Call list.
#289371 - 06/11/2006 17:30 Re: How to kill a political phone robot [Re: wfaulk]
I have gotten no telemarketing calls since a few weeks...
I'm hoping the trick will be useful in another situation. I've been regularly getting an automated phone call that I think is from a bill collector who's got an old number for someone. It goes something like "This is an important and private message for Mercurio So-and-So. If you are not Mercurio So-and-So, hang up now. If this is you, then please call such-and-such right away..."
Anyhoo, my phone is programmable to silence the ring based on incoming callerID number, so at least my phone doesn't RING when that call comes in. But it frequently results in an extra answering machine message that I keep checking and then deleting. Hopefully this trick will make that call disconnect before the answering machine picks up.
#289372 - 06/11/2006 17:53 Re: How to kill a political phone robot [Re: tfabris]
Yeah, I had one of those recently, too. >:(
Took way too much effort on my part to resolve it.
#289373 - 06/11/2006 19:29 Re: How to kill a political phone robot [Re: hybrid8]
I was assuming that it was one of those automatic pre recorded that you hang up on and go back to the phone 5 minutes later and it is still on talking away to itself
Cris.
#289374 - 06/11/2006 21:54 Re: How to kill a political phone robot [Re: Cybjorg]
Glen_L
Loc: Elk Grove, CA
There is also a box that will add the tone before as soon as you pick up the phone. The Telezapper is still available at Radio Shack. I suppose it's slightly less annoying to pick up to a dead line than a live telemarketer.
No longer a stranger, finally a full-fledged member! \:D
#289375 - 07/11/2006 03:23 Re: How to kill a political phone robot [Re: Glen_L]
lectric
Loc: New Orleans, LA
Actually, I had one of those telezapper thingies. It works quite well. Apparently, the beep it makes tells the computer calling you not to any more. My repeat calls dropped significantly after I installed it. The downside is that it makes a beep whenever ANY call is made, which can be annoying.
