#287179 - 26/09/2006 14:23 BT Voyager 2100/2110 connect issue with Linux (solved)
The B&B hotel that SWMBO and I are at today has a British Telcom supplied wireless DSL router, which refuses to work with Linux by default. Fine with that other common system, though.
So, being what I am, I sorted it all out and posted the solution for others who might find themselves in the same situation some day. With lots of UK folks on the BBS here, I figure I might as well post a link to it here as well.
http://justlinux.com/forum/showthread.php?t=147096
#287180 - 28/09/2006 01:01 Re: BT Voyager 2100/2110 connect issue with Linux (solved) [Re: mlord]
adavidw
Loc: Utah, USA
You mean you didn't just reverse engineer the firmware upgrade sequence, write a new firmware for the router on the spot, and upload it to the router, fixing it for good? I expected more from you, Mark...
-Aaron
#287181 - 29/09/2006 19:42 Re: BT Voyager 2100/2110 connect issue with Linux (solved) [Re: adavidw]
Translation: Thanks!
