#284864 - 28/07/2006 14:40 Factory Tuner ... weak FM
Verteggio
Loc: Atlanta, GA USA
Ok, so apparently I've given myself a renewed interest in my Empeg... and I rediscovered that I have a factory tuner installed. Then I quickly discovered again why I'd forgotten about it... weak sound performance.
I remember having issues with it from the start, but apprently never got around to trying to resolve it <shrug>. Items of note:
- Vehicle is a Jeep Wrangler ('99)
- Not using extension cable (plugged directly into empeg)
- Antenna doesn't have an amplifier (validated with service manual)
- Conductivity is solid from the tip of the antenna connector to the the actual antenna itself
- Resistance is negligable from tip of the antenna to the actual antenna
- Region is set to US and timezone is also set to US
- weak performance on BOTH AM and FM (see notes below)
- Signal strength is a solid 4-5 bars depending on station
- Opened the tuner box, everything "looks" fine (from a non-engineering standpoint... nothing burnt, loose, etc.)
- There is a station here with RDS, TS, [accurate!] RDS clock... the works. However, can barely hear it
- No ground loop present for MP3 playback, so assuming same for radio
Basically, I'll pick up a solid 4-5 bars, all RDS info and everything else but the sound is VERY low - I have to adjust about 25db difference on the volume before I can hear it reasonably. The station *sounds* clear, except for high bass level and hum.. not static, but hum which together drown out the sound as well.
I tried an AM station, and the same thing is happening.
I tried searching for similar items, and found several... ironically, though almost all of them are left hanging. The most relevant one seams to be this post (for the PCATS tuner), but not sure if I could do the same for the factory tuner.
So at this point i'm at a loss... I can run multimeter checks and/or replace items as needed, but need to be told what to do or where to go
Edited by Verteggio (28/07/2006 14:44)
--verteggio
#284865 - 28/07/2006 15:22 Re: Factory Tuner ... weak FM [Re: Verteggio]
Good diagnostic steps. Yep, I'd agree that what you've got is a faulty tuner module.
Hopefully Stu or Rob can sort you out?
#284866 - 28/07/2006 16:26 Re: Factory Tuner ... weak FM [Re: tfabris]
Verteggio
Not the answer I was looking for, but i'll take it =)
I went ahead and sent an e-mail, but am still open to ideas on what else to check / try
--verteggio
#284867 - 28/07/2006 16:46 Re: Factory Tuner ... weak FM [Re: tfabris]
Tony...you might want to update that FAQ entry to denote that Rob S. is now in the UK, not the Netherlands.
#284868 - 28/07/2006 23:17 Re: Factory Tuner ... weak FM [Re: JBjorgen]
Done
#284869 - 10/08/2006 18:07 Re: Factory Tuner ... weak FM [Re: tfabris]
Verteggio
Well, it's been a week and no response from Rob or Stu... I know they do this in their spare time, so no worries.
However, does anyone have any suggestions of things I might be able to try on my own in the meantime?
--verteggio
#284870 - 10/08/2006 18:32 Re: Factory Tuner ... weak FM [Re: Verteggio]
maczrool
Loc: Louisiana, USA
Did you send me an e-mail? If so, I did not receive it.
Stu
