#284134 - 07/07/2006 16:38 Problem with new Disk installation
estocks
Loc: Reading UK
Hi
I have searched.
I am attempting a brand new disk install. I am at the step in the FAQ guide where the Disk Builder image is run. I get an error that says "error couldn't find pump".
The disk is in IDE0. I have recrimped the IDE0 and also tried the IDE1 location.
I tried installing V2.00 Developer, that went OK then followed with the Disk Builder, but the Disk Imager won't run still so I can't begin putting music onto the new disk.
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
#284135 - 07/07/2006 16:42 Re: Problem with new Disk installation [Re: estocks]
schofiel
Usual drill - serial log capture, post it here, blah blah
#284136 - 07/07/2006 16:42 Re: Problem with new Disk installation [Re: estocks]
Is the disk more than 60 gig or so? If so, you'll need to manually format and partition it instead of using the disk builder image that is referenced in the drive upgrade guide. Roger's got some instructions somewhere.
EDIT: They're linked from the guide. Read the section entitled "Special note for large drives:".
Edited by JBjorgen (07/07/2006 16:45)
#284137 - 07/07/2006 17:10 Re: Problem with new Disk installation [Re: JBjorgen]
estocks
Loc: Reading UK
It is s 60GB.
@scofeil
I connect to the player with HT after the fail and record
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com
or forever hold their peace...
or forever hold their peace...it s
.com)
#284138 - 07/07/2006 17:17 Re: Problem with new Disk installation [Re: estocks]
Okay. Brand new drive. 60GB. Try this...
- Unplug the player.
- Install disk builder, leaving the empeg OFF until the uploader says that it is trying to find the empeg. Once that happens, plug the empeg in.
- Upload the disk builder software
- As soon as the upgrade completes, and the empeg is rebooting, pull the plug on the empeg
- Set up to capture a hyperterminal session
- Plug the empeg in, capturing the session
- Hit "enter" if you are asked to on console
- When you see the disk stress test running, stop the capture and post it here. Leave the stress test running.
The intent of this is to a) load the builder software while b) capturing the output of the build to make sure it worked.
One the stress test has been running for a while, and if the output from the hyperterm session and build looks good, you will then load the developer software version of the player using the first three steps above.
#284139 - 07/07/2006 17:32 Re: Problem with new Disk installation [Re: pgrzelak]
estocks
Loc: Reading UK
Riiight.
The reboot (I.E: display relighting with the boot logos) was not happening before.
Not realising that, I whipped the power just as the Kernel began flashing and recorded the If there is anyone present who wants to upgrade the flash, let them speak now,
message.
I went through the upload again expecting to whip the power/click cancel just as the disk pump search began.
This time the player lit up and found the disks all on its own, it is now pumping happily.
I HTH the next person.
Speaking too soon; thanks all is fine now
#284140 - 07/07/2006 19:46 Re: Problem with new Disk installation [Re: estocks]
estocks
Loc: Reading UK
Gah! Spoke too soon.
Emplode would not read the music database afer installing Developer V3.
The player does not reboot after the kernel is flashed with the Disk Builder.
Help!
Edited by estocks (07/07/2006 19:47)
#284141 - 07/07/2006 20:27 Re: Problem with new Disk installation [Re: estocks]
Developer V3.
If you're having problems at all, don't use V3. V3 is alpha software and has bugs. Use V2 final.
#284142 - 07/07/2006 20:49 Re: Problem with new Disk installation [Re: tfabris]
estocks
Loc: Reading UK
Overwrote v3 with V2.01 final but Emplode doesn't read the Media database. The player then reboots.
@pgrzelak Because the player does not reboot after the Disk Builder kernel is loaded I cannot get a log.
It remains in the download state after the DC is removed and reinserted also.
Edited by estocks (07/07/2006 21:54)
#284143 - 07/07/2006 22:58 Re: Problem with new Disk installation [Re: estocks]
It's possible that installing version 3 messed up the databases, since it uses a different database format. Also, make sure that your emplode is version 2.0 exactly, not any other version.
If that doesn't work, then see if rebuilding the databases manually fixes the problem.
#284144 - 08/07/2006 00:05 Re: Problem with new Disk installation [Re: estocks]
Help!
That's normal. After the disk builder has finished the "building" parts, it just loops doing tests until you shut it up. Install the normal car2-upgrade image now.
#284145 - 08/07/2006 07:30 Re: Problem with new Disk installation [Re: tfabris]
estocks
Loc: Reading UK
@tfabris this is my log with V2.01 installed. I guess something is wrong with the file system
empeg:/empeg/bin# rwm
mount: /drive0 not mounted already, or bad option
empeg:/empeg/bin# rm/drive0/var/database
bash: rm/drive0/var/database: No such file or directory
empeg:/empeg/bin# rm/drive0/var/database3
bash: rm/drive0/var/database3: No such file or directory
empeg:/empeg/bin# rm/drive0/var/tags
bash: rm/drive0/var/tags: No such file or directory
empeg:/empeg/bin# dd if=/dev/zero of=/dev/hdc bs=1024 count=1024
dd: /dev/hdc: Device not configured
empeg:/empeg/bin# fdisk -l /dev/hdc
empeg:/empeg/bin#
@mlord the disk doesn't reboot to pump the disks, and does not get to the testing stage.
#284146 - 08/07/2006 08:04 Re: Problem with new Disk installation [Re: estocks]
Copy-and-paste the commands from the FAQ. You're missing a whole heap of spaces in those commands.
But, also, your second disk doesn't seem to be being recognised (/dev/hdc: Device not configured), so you should attach a complete boot log. Instructions for that are in the FAQ, too.
#284147 - 08/07/2006 10:09 Re: Problem with new Disk installation [Re: Roger]
estocks
Loc: Reading UK
@Roger, This is my boot log (I have one brand new 60GB WD disk in IDE0)
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315 (release)) #20 Tue Jul 6 15:36:06 BST 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 10101510)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005e80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: WDC WD600VE-75HDT1, ATA DISK drive
hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e6
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,4).
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplùStarting player
player.cpp : 385:empeg-car 2.01 2004/07/06.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
I am fairly sure there is a problem with the Disk Builder Image section. It does not work like the FAQ says it will. It does not reboot the player before pumping the disk, like a player image does, and there is no way for me to get a Disk Builder log becasue of that.
Edited by estocks (08/07/2006 10:46)
#284148 - 08/07/2006 11:22 Re: Problem with new Disk installation [Re: estocks]
That particular boot log is from a normal developer image, NOT from a builder image.
What are you trying to do, and what are you trying to show here?
#284149 - 08/07/2006 12:10 Re: Problem with new Disk installation [Re: estocks]
The disk builder didn't successfully format your music partition. This is a fairly common occurrence with larger disks. You should first retry the disk builder, which sometimes succeeds.
If that doesn't work, you'll have to format the partition yourself. Install a developer release, get to a shell prompt, and then follow the instructions on this page.
#284150 - 08/07/2006 12:35 Re: Problem with new Disk installation [Re: Roger]
estocks
Loc: Reading UK
@mlord I have a single 60GB brand new disk I want to partition, format, and add a player image to. I cannot complete the Disk Builder image as it does not reboot the player at the Pump Hard Disk stage of the flashing. Unfortunatly a log is not possible as the player remains in the download state.
It flashed once I thinght and so added a player image. It was V3, and Emplode V2.10 would not recognise the player database. I put on V2.01 Final and Emplode 2.0 and again it would not read the player database.
@roger these are my logs from attempting a partiton followed by a format followed by a partition. They do not seem to be responding as the FAQ suggests.
empeg:/empeg/bin# mke2fs -m 0 -s 1 -i 131072 /dev/hdc4
mke2fs 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hdc4 is mounted.
mke2fs: Device not configured while trying to determine filesystem size
empeg:/empeg/bin#
#284151 - 08/07/2006 12:54 Re: Problem with new Disk installation [Re: estocks]
That's because you're supposed to do it by having the player unplugged initially, and then by reapplying the power.
Also, my instructions assume that you're formatting a second disk, so if you want to format a single disk manually, you'll need to replace every instance of /dev/hdc with /dev/hda in those instructions.
#284152 - 08/07/2006 13:49 Re: Problem with new Disk installation [Re: Roger]
estocks
Loc: Reading UK
I do start with the palyer unplugged and insert the power when instructed I am certain.
Here are the logs I captured.
Starting bash.
empeg:/empeg/bin# dd if=/dev/zero of=/dev/hda bs=1024 count=1024
1024+0 records in
1024+0 records out
empeg:/empeg/bin# fdisk -l /dev/hda
Disk /dev/hda: 255 heads, 63 sectors, 7296 cylinders
Units = cylinders of 16065 * 512 bytes
Disk /dev/hda doesn't contain a valid partition table
empeg:/empeg/bin# fdisk /dev/hda
Device contains neither a valid DOS partition table, nor Sun or SGI disklabel
Building a new DOS disklabel. Changes will remain in memory only,
until you decide to write them. After that, of course, the previous
content won't be recoverable.
The number of cylinders for this disk is set to 7296.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
Command (m for help): n
Command action
e extended
p primary partition (1-4)
e
Partition number (1-4): 1
First cylinder (1-7296, default 1): 1
Last cylinder or +size or +sizeM or +sizeK (1-7296, default 7296): +32M
Command action
l logical (5 or over)
p
Partition number (1-4): 2
First cylinder (6-7296, default 6):
Using default value 6
Last cylinder or +size or +sizeM or +sizeK (6-7296, default 7296): +32M
Command action
p
Partition number (1-4): 3
First cylinder (11-7296, default 11):
Using default value 11
Last cylinder or +size or +sizeM or +sizeK (11-7296, default 7296): +16M
Command (m for help): t
Partition number (1-5): 3
Hex code (type L to list codes): 10
Changed system type of partition 3 to 10 (OPUS)
Command action
p
Partition number (1-4): 4
First cylinder (14-7296, default 14):
Using default value 14
Last cylinder or +size or +sizeM or +sizeK (14-7296, default 7296):
Using default value 7296
First cylinder (1-5, default 1):
Last cylinder or +size or +sizeM or +sizeK (1-5, default 5): +16M
First cylinder (4-5, default 4):
Using default value 4
Last cylinder or +size or +sizeM or +sizeK (4-5, default 5):
Using default value 5
Partition number (1-6): 6
Hex code (type L to list codes): 82
Changed system type of partition 6 to 82 (Linux swap)
Command (m for help): p
Device Boot Start End Blocks Id System
/dev/hda1 1 5 40131 5 Extended
/dev/hda2 6 10 40162+ 83 Linux
/dev/hda3 11 13 24097+ 10 OPUS
/dev/hda4 14 7296 58500697+ 83 Linux
/dev/hda5 1 3 24034+ 83 Linux
/dev/hda6 4 5 16033+ 82 Linux swap
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Re-read table failed with error 16: Device or resource busy.
Reboot your system to ensure the partition table is updated.
WARNING: If you have created or modified any DOS 6.x
partitions, please see the fdisk manual page for additional
information.
Syncing disks.
empeg:/empeg/bin#
Then a reboot.
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004300).
6
Partition check:
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
Display says No hard disk found contact support And I cant get to the command shell to format the disk.
#284153 - 08/07/2006 14:36 Re: Problem with new Disk installation [Re: estocks]
Well, since the builder is already giving you troubles, could you please
try this custom builder I have prepared for big disks, and see what it does (or doesn't do).
Thanks.
#284154 - 08/07/2006 15:08 Re: Problem with new Disk installation [Re: mlord]
estocks
Loc: Reading UK
Thanks.
The Disk Builder downloaded, rebooted and began pumping the disk first time thanks. It rebooted and ran the builder image for the first time.
Making /dev/hda4 filesystem
Mounting...
** Some workds and a table flys by **
Spinning Down
Spinning Up
**Screen goes blank. Disk whirs on and off**
The Player V2.01 image is in and the database is being read with Emplode. Thanks guys.
#284155 - 08/07/2006 15:59 Re: Problem with new Disk installation [Re: estocks]
Super. Happy Trails, then!
#284156 - 09/07/2006 22:19 Re: Problem with new Disk installation [Re: estocks]
Wow.
I'm glad Mark's custom builder image worked for you, but I'm stymied as to why the factory builder image didn't behave as expected, unless you somehow got a corrupted file.
#284157 - 23/07/2006 21:29 Re: Problem with new Disk installation [Re: tfabris]
Gize
I encountered the same problem, and this builder fixed the issue. The drive i'm using is a Fujitsu MHV2040AH (40GB 5400RPM). Thank you all for your help, the FAQ and this board have made everything go smoothly for me.
#284158 - 26/07/2006 15:39 Re: Problem with new Disk installation [Re: Gize]
gbsallery
Same here, though with an IBM disk. Did the Disk Builder image get damaged during the restore of the site, perhaps?
#284159 - 26/07/2006 20:35 Re: Problem with new Disk installation [Re: gbsallery]
No, the copy on the site is just fine. It just doesn't always work reliably with drives >= 40GB or so.
#284160 - 13/10/2006 15:12 Re: Problem with new Disk installation [Re: mlord]
JeffreyB
Loc: Cincinnati, OH
I'm having the same problem with the stock builder. Mark's custom builder works fine, but I only have 20GB and 30GB drives. Will using Mark's builder be a problem with these smaller drives? Has anyone actually gotten the stock builder to work lately?
Jeff
Edited by JeffreyB (13/10/2006 15:34)
#284161 - 13/10/2006 15:37 Re: Problem with new Disk installation [Re: JeffreyB]
JeffreyB
Loc: Cincinnati, OH
Edited by JeffreyB (13/10/2006 16:00)
#284162 - 13/10/2006 17:01 Re: Problem with new Disk installation [Re: JeffreyB]
Mark's builder should work fine, but I'm more worried about why you're the third person to report a problem with the stock builder.
Does the empeg support web site have a corrupted file by any chance?
#284163 - 15/10/2006 03:13 Re: Problem with new Disk installation [Re: tfabris]
Ross Wellington
I was able to manually build a 120 GB drive and then I used the Big Disk Builder program for 5 other drives ( I have 3 Mk2s with 2 each 120 GB drives in them).
I have had success with both Hitachi and Toshiba drives. I have not mixed vendor drives in a Rio.
The builder works very well, good work.
