#283770 - 30/06/2006 21:35 Tuner not receiving
My Tuner has been working great for the last year or so since installed. Then last week I turned it on and I’m now just getting static. The player recognizes there is a tuner but I just get static on all frequencies, AM and FM. I pulled the car’s antenna wire (yes it was connected OK) and put a piece of wire in the antenna hole to check to see if the car’s antenna was bad, still just static. I even tried my wife’s player in my car and I got the same thing.
Does anybody have any suggestions or is the receiver part of my tuner fried?
#283771 - 01/07/2006 02:51 Re: Tuner not receiving [Re: Redrum]
You've done pretty much everything I think would help.
Does the static change at all as frequency is changed? Is AM different to FM?
#283772 - 01/07/2006 09:34 Re: Tuner not receiving [Re: Shonky]
The static does appear to change when the channels change and there is definitely a difference between FM and AM. I took the cover off and did not see any cold solder joints. I even tried flexing the board and pressing on components to see if anything changed, nothing.
One thing I that kind of puzzled me is that when I put the wire in the antenna the static changed. If there is a problem in the front-end of the tuner I don’t understand why the static would change. Maybe the mixer frequency (I think that’s what it’s called) is off somehow.
#283773 - 01/07/2006 17:52 Re: Tuner not receiving [Re: Redrum]
Double check that the problem isn't a frayed wire or a loose connection on the control wires that lead to the tuner from the player's sled.
#283774 - 03/07/2006 07:54 Re: Tuner not receiving [Re: Redrum]
schofiel
Is this a factory (black box) or a PCA (grey box) tuner?
The factory ones regularly suffer from the failure of the audio output amplifier which gives this symptom.
#283775 - 03/07/2006 09:20 Re: Tuner not receiving [Re: tfabris]
Thanks, I slightly pulled on all the wires and nothing came loose. I guess I probably should ohm them. The red LED does come on. Yea, I know there's a lot more wire than just the power.
#283776 - 03/07/2006 09:30 Re: Tuner not receiving [Re: schofiel]
Sorry I thought I posted that it was a factory tuner but I guess I didn't. If you could please share, which chip is the audio output amplifier? I have limited tools now (just a multi-meter) is there any voltages I could check for? I'm pretty good at soldering so I feel confident I could change a surface mounted chip (as long as it isn't huge).
