#281398 - 12/05/2006 23:51 replacement face plate???
dewdman42
Anyone know where I can find a replacement face plate for my MKII? The holes that hold teh screws in place have disintegrated a way and now the screws basically aren't holding the faceplate down. I need a new faceplate. Is anyone making these?
#281399 - 13/05/2006 05:03 Re: replacement face plate??? [Re: dewdman42]
Rob Schofield has plenty of them.
http://empegrepair.com/
(except it seems to be down right now).
#281400 - 14/05/2006 13:10 Re: replacement face plate??? [Re: dewdman42]
FireFox31
Loc: East Coast, USA
I've always wondered if epoxy could help in this situation. Could epoxy be put into the holes to build them inward a bit? Then, drill out any excess and thread the screw in there. Wouldn't the threads dig into the hardened epoxy, making a great fit?
FireFox31
#281401 - 14/05/2006 16:33 Re: replacement face plate??? [Re: FireFox31]
bootsy
Loc: Seattle, WA. USA
I did get a couple replacement fascias from Rob for this same problem. It is now happening again.
The epoxy idea sounds good, but is there a way to avoid this in the future? I made sure not to over tighten the screws. They only thing I can think of that could be causing this is I take my Empeg out every day and put it in the case (empeg branded fabric carry-all mini man bag). It's a snug fit. Toting the bag around could be working the fascia screw columns back and forth until they crumble...?
Anyway... until one of the metal NewNewFaces become available, I am looking for ideas.
Brian H. Johnson
MK2 36GB Blue, currently on life support
"RIP RCR..."
#281402 - 15/05/2006 20:22 Re: replacement face plate??? [Re: bootsy]
matthew_k
I've got one fascia that's the same way, and it did happen shortly after I aquired an empeg bag. Probably a coincidence, as it doesn't seem to be too wide spread a problem.
#281403 - 16/05/2006 15:42 Re: replacement face plate??? [Re: dewdman42]
schofiel
Overtightening, I'm afraid.
#281404 - 16/05/2006 16:56 Re: replacement face plate??? [Re: bootsy]
It is possible that the display is not aligned correctly with the front edges of the steel casing. To prevent this from cracking the fascia, first loosen the four tiny cross-head screws that secure the display module (two on each side of the player). Then install the fascia, and gently tighten the allen bolts to secure it. Finally stick a double-folded banknote between the handle and the fascia (as a spacer), and then re-tighten the four tiny cross-head screws again.
Remove the banknote, and snail-mail it to me or Rob.
Done.
Edited by mlord (16/05/2006 16:57)
#281405 - 17/05/2006 04:45 Re: replacement face plate??? [Re: mlord]
RobotCaleb
Unless you use a substantial banknote. In which case you would NOT remove it and you would then snail-mail it to me. After "processing", I will send it where it needs to go.
:P
#281406 - 24/05/2006 02:49 Re: replacement face plate??? [Re: mlord]
bootsy
This is a really interesting idea... I will have to try it.
Brian H. Johnson
"RIP RCR..."
