#280812 - 27/04/2006 22:34 help with extra memory
oliver
I just got around to testing the memory I had added to one of my spare empegs, and it didn't work on the first try. If anyone can help me out, I've tried to figure it out but I don't quite understand how to decrypt the text below. (complete boot log attached)
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
280759-memlog2.TXT (214 downloads)
#280813 - 27/04/2006 22:53 Re: help with extra memory [Re: oliver]
No chip select.
#280814 - 27/04/2006 23:25 Re: help with extra memory [Re: mlord]
oliver
So that would be the RAS1 line on the strongarm, or either of the stacked chips on pin 14, right?
Everything seems to have continuity, I haven't tested the resistance yet.
#280815 - 28/04/2006 01:40 Re: help with extra memory [Re: oliver]
Right. Most likely at the RAS1 (pin 123?) of the SA-1100 CPU.
Or (much less likely) one of the control lines to the RAM chips (eg. the RW, CS, or OE lines).
Edited by mlord (28/04/2006 01:42)
#280816 - 22/10/2006 19:41 Re: help with extra memory [Re: mlord]
oliver
I just got around to trying to figure out this memory issue. After replacing a chip I'm now getting this error.
I'm really bad with decipher these error messages into binary to get the troubled pins. Can anyone help me out?
c1000000: wrote ffffffff, read aaaaffff
#280817 - 22/10/2006 20:07 Re: help with extra memory [Re: oliver]
oliver
Ok, I touched up a few pins that were open, now i'm getting this... does this mean everything is groovy? The one thing i'm wondering about, is the "Command line: mem=16m"
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v455 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Mon Apr 24 20:27:47 EDT 2006
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 30102485) 32MB DRAM
#280818 - 22/10/2006 20:35 Re: help with extra memory [Re: oliver]
Everything is groovy. Ignore the "mem=16m" line -- that is just a factory firmware default for the mk2a.
#280819 - 22/10/2006 21:20 Re: help with extra memory [Re: mlord]
oliver
Excellent
Now, I have to figure out this stupid display fuse issue to actually use the memory. I'll be switching out the fuse with the one you sent me a few months ago. Hopefully that will fix the problem.
Thanks again!
