Page 2 of 2 < 1 2
#280688 - 08/05/2006 10:33 Re: Need Help with Upgrade Please [Re: pgrzelak]
Gallagher419
No such luck with that Paul and I have attached another hyperterm capture upon the reboot.
281223-hyper.TXT (232 downloads)
#280689 - 08/05/2006 10:33 Re: Need Help with Upgrade Please [Re: pgrzelak]
Marking thread as having a new post...
By the way, did you initialize the dynamic data partition also? That would have been this command: "dd if=/dev/zero of=/dev/hdc3". Just checking.
#280690 - 08/05/2006 10:35 Re: Need Help with Upgrade Please [Re: pgrzelak]
Gallagher419
Yes I did do that too.
#280691 - 08/05/2006 10:37 Re: Need Help with Upgrade Please [Re: Gallagher419]
Excellent...
#280692 - 08/05/2006 10:42 Re: Need Help with Upgrade Please [Re: pgrzelak]
Gallagher419
Success! It is showing 110 GB of free space in Emplode. You are my hero Paul! Seriously though thank you very much for all the troubleshooting and help I really appreciate it!
#280693 - 08/05/2006 10:46 Re: Need Help with Upgrade Please [Re: Gallagher419]
Cool!!! No worries. Glad I could help!
Roger - if you are reading this, one thing though is that the notes assume that you are always working with the second drive / drive1 / hdc... EXCEPT for the directory creation step, which for some reason assumes the first drive, with a note below saying you might need drive1. You might want to swap this, so that the file is internally consistent. A thought...
#280694 - 08/05/2006 11:06 Re: Need Help with Upgrade Please [Re: pgrzelak]
Done. What I've done is to change the instructions so that it assumes you're doing this to the second drive in an empeg. This seems to be the commonest case.
If you're doing something else (like partitioning and formatting with the new disk plugged into your PC), I've assumed you're smart enough to alter the instructions accordingly.
#280695 - 08/05/2006 11:08 Re: Need Help with Upgrade Please [Re: Roger]
Thanks!!!
#280696 - 08/05/2006 11:09 Re: Need Help with Upgrade Please [Re: Gallagher419]
I do not see any errors at all but when I run emplode it only see's the 20 gb hdd.
If I recall correctly, emplode never sees hdds. It only sees used/free capacity.
What *exactly* indicates to you that there might be a problem?
EDIT: never mind.. I see the problem was resolved already!
Edited by mlord (08/05/2006 11:11)
Page 2 of 2 < 1 2
