#279590 - 16/04/2006 20:41
Please help! KVM hell.
Loc: San Francisco, CA
Hi All,
Am visiting a close friend for Easter today and I'm trying to help him diagnose an issue he's having...
He has a Dell laptop (610) that's docked. He has the VGA going to a Viewsonic flat panel, and the DVI going to a 2 port KVM switch, which is also fed by a Mac Mini - the KVM output is going to a Sony LCD. When we switch to the Mac Mini, all is fine, when we switch to the Dell, the Sony LCD will not get itself out of standby.
I attached a diagram which shows the set up.
I've checked all of the drivers, the firmware, etc - all are current. When we hook up the Dell directly to the 2 LCD's, they come up perfectly. Also, when I boot the Dell with the KVM set to use the DVI from the Dell, the boot screen up may come up on the Sony, until XP is near done booting, at which point I can no longer get the Sony to be used. So it seems like a problem with XP...
You guys have any ideas? I'm stuck...
- Thanx - Jon
#279591 - 17/04/2006 00:42
Re: Please help! KVM hell.
[Re: jbauer]
No ideas? You guys are making a liar out of me!!!
- Jon
#279592 - 17/04/2006 00:51
[Re: jbauer]
Loc: Florida
Sounds like it might be a refresh rate issue. Try seting the PC to the same refresh rate at the Mac.
Chad
#279593 - 17/04/2006 01:49
[Re: Attack]
Loc: NH USA
I'm with Attack. Look at scan speed and resolution first. Do you have the documentation for the KVM? It may shed light.
-Zeke
WWFSMD?
#279594 - 17/04/2006 03:51
[Re: Ezekiel]
Paul tried setting the refresh to be the same (60 Hz), no joy...
I read through the dox, couldn't find anything that might be of use. I did learn a few things. Didn't know that you could change a KVM device with built in XP commands (double scroll lock key combos)...
Any other ideas appreciated.
- Thanx - Jon
#279595 - 17/04/2006 04:29
[Re: jbauer]
Loc: Yorkshire UK
I'm no technical person, but I'll throw this in just in case: I have a Sony viao desktop and thought that I would use my DVI output to my plasma screen and the VGA to feed through a TV converter to our kitchen TV, but the DVI and VGA don't work simultaneously, which, in non-technical terms is just about where you are.
I should have added that, at the time, I took it to the Company who provided the support at my office who connected screens to both outputs and spent a long time playing about, but couldn't solve the problem.
Edited by boxer (17/04/2006 04:44)
#279596 - 17/04/2006 04:41
[Re: boxer]
Not the same problem, he said: Quote: When we hook up the Dell directly to the 2 LCD's, they come up perfectly.
So he doesn't have the issue that the Dell can't use DVI and VGA simultaneously, at least when the KVM isn't involved.
#279597 - 17/04/2006 04:46
[Re: andy]
Loc: Yorkshire UK
Quite right, I'd missed that point! - You're an early riser too, I should be out walking the boxers, but it's tipping it down here.
#279598 - 17/04/2006 04:54
[Re: boxer]
I've got a big deadline for a project today, I've been working 18 hours a day for the last couple of days to try and meet it  On the plus side, it is beautifully sunny here...
#279599 - 17/04/2006 09:07
[Re: jbauer]
Loc: Triangle, VA
Have you tried lowering the resolution? I have a KVM that couldnt handle having the resolution as high as the card could handle.. put em at 800x600 and see if it works.
-D
#279600 - 17/04/2006 09:24
[Re: SonicSnoop]
Another question. I know you have tried direct connect without the KVM. Have you tried booting the laptop / docking station with the KVM connected and switched to the PC? I am wondering if the Dell needs to see the DVI at boot.
Another thought. I know that some laptops (particularly IBM Thinkpad variations) have a lot of trouble running with KVMs when docked (more typically mouse than monitor trouble). Have you tried a DVI / switch connection undocked?
#279601 - 17/04/2006 10:10
[Re: jbauer]
Loc: NH USA
Resolution will be your resoulution.  -Z
WWFSMD?
#279602 - 17/04/2006 10:27
[Re: Ezekiel]
<groan>
#279603 - 17/04/2006 11:21
[Re: jbauer]
Loc: Florida
I have KVM's that require a signal from the PS2 keyboard before it would send the video signal to the monitor. This would be for each port on the KVM. Do you have the KVM connected to the PC keyboard and mouse ports? I also have a PC that the keyboard won't work if the KVM isn't switched to it before the PC is turned on.
Chad
#279604 - 17/04/2006 11:26
[Re: jbauer]
Try pressing the power button (twice) on the monitor when it seems stuck in standby.
I have an (other brand) LCD panel here (also on a KVM) that sometimes forgets to come back from standby, and just tapping it's (soft) power button twice does the trick. Rare event, though.
#279605 - 17/04/2006 12:08
When I was there, I tried all kindsa resolutions, no joy. Also, the manual says it supports up to 1600x1200 for DVI.
He doesn't have any of the PS2 cables hooked up to the KVI... The Mini has a bluetooth keyboard and mouse, and he uses a Logitech wireless on the Dell. Hm. Do you think it's needed? That's a possibility.
I also tried to boot the Dell with the KVM set to display the Dell through to the Sony. I thought that the Dell might be disabling the DVI when it no longer sees a signal from the Sony, but I don't think that's it. I can't get the Dell to recognize a 2nd monitor no matter what I do when it's going through the KVM.
I've also tried mlord's suggestion in taking the Sony out of standby so that the Dell could see it. No joy there either...
Without the Dell docked, there's no DVI port on the laptop, so I couldn't try an undocked solution.
Are there different types of DVI cables? Is DVI bi-directional? I told Paul to try another cable as it seems that perhaps the Dell isn't receiving whatever signal is needed to tell the Dell that there's an active monitor on the DVI...
- Jon
#279606 - 17/04/2006 12:22
[Re: jbauer]
Quote: He doesn't have any of the PS2 cables hooked up to the KVI... The Mini has a bluetooth keyboard and mouse, and he uses a Logitech wireless on the Dell. Hm. Do you think it's needed? That's a possibility.
My cheap KVM at home will not select a PC unless there's a PS/2 device (usually a keyboard) connected. Regardless of there being a signal on the VGA port.
Come to think of it, the expensive KVM I have at work is exactly the same....
#279607 - 17/04/2006 14:32
[Re: jbauer]
That's the problem -- the KVM needs a PS2 cable to draw power from for it's internal circuits.
#279608 - 17/04/2006 14:40
If you look at the diagram it claims that the PS/2 socket on the KVM is actually hooked up to the Dell.
#279609 - 17/04/2006 14:41
Well, he was using a PS2 cable to power the KVM, but we switched that for an AC power cable. Other than providing power, is the PS2 cable important in any other way? We were only trying to use the KVM for video...
- Jon
#279610 - 17/04/2006 14:51
[Re: jbauer]
Loc: Florida
What is KVM model? Every PS2 KVM I've used required the PS2 keyboard connection to be active on the port I wanted to have video on.
Chad
#279612 - 17/04/2006 16:41
[Re: jbauer]
Erm. It is the 7th item down on the Switches / Cables page...
#279613 - 17/04/2006 16:43
[Re: tman]
Quote: Erm. It is the 7th item down on the Switches / Cables page...
Ah. Thanks. Missed it when I looked at that page...
- Jon
#279614 - 17/04/2006 17:54
[Re: jbauer]
Loc: NH USA
Quick question - were you using any type of DVI to analog adapter cable between the Dell and the KVM?
The reason I ask is that I pulled my hair out for 1/2 a day while (Ghost) imaging an Optiplex. It would display until it switched to the higher resolution mode just before the login prompt (I thought I had a display driver mismatch between the Ghost image and the Optiplex). It turned out that replacing the cable from a DVI/Analog adapter (to the analog input on monitor) to a straight DVI cable (to the DVI input on the monitor) fixed the issue.
Why it fixed the issue I have no idea, but it did, so I thought it couldn't hurt to ask here.
-Zeke
WWFSMD?
#279615 - 17/04/2006 18:04
[Re: Ezekiel]
Nope, no adaptors used at all...
- Jon
#279616 - 17/04/2006 18:34
[Re: jbauer]
Loc: NH USA
Ok, well then I'm officially out of ideas. Sorry!
-Zeke
WWFSMD?
#279617 - 17/04/2006 21:10
[Re: jbauer]
Loc: Triangle, VA
Does the laptop require you to hit the function key along with a specific number key or F key to activate/cycle through the displays? maybe thats needed to activate the DVI port? If this has already been brought up sorry.
-D
#279618 - 17/04/2006 21:26
[Re: SonicSnoop]
Quote: Does the laptop require you to hit the function key along with a specific number key or F key to activate/cycle through the displays? maybe thats needed to activate the DVI port? If this has already been brought up sorry.
Hm. Well, when we had it directly connected to the Sony LCD, we could select the monitor with XP, click "extend my desktop to this monitor", and we'd be good to go. When we go through the KVM, it would allow you to make the change, but when you applied it, XP wouldn't enable the DVI and turn on the monitor. The box that represented monitor 2 on the XP setup screen would go grey...
- Jon
#279619 - 18/04/2006 16:07
[Re: jbauer]
Hey All, I'm Jon's friend, Paul. The guy with KVM madness. After a short discussion, we thought it would be good of me to login and introduce myself. So here goes... My name is Paul but my friends call me, well, um, "Paul". I'm a Capricorn and enjoy rainbows and unicorns. I also, according to my wife, work best with a cluttered work space with countless devices laying about the desktop in various states of operation. Seems to keep me focused and out of trouble. Except of course when they don't behave in an expected manner, to which end I spend more time and money.
You have all made great suggestions and have given me a few more options to explore before I go out and just buy an effing 3rd monitor to hang on the wall. I have a similar work station in the corporate office with access to another (more expensive) KVM where I will likely continue these efforts.
I'll keep you posted.
Thanks again! -P
