#278332 - 05/04/2006 13:54
Re: Low battery icon adjustment???
[Re: Robotic]
Guys, I changed the value of the 3.3V reference divider and now the Empeg runs to a lower voltage before it signals the processor. The battery icon was never the problem, just the audio cutting out. It now seems to run down to @ 10.0V or so before reporting low voltage. This will help me greatly. The biggest problem with the op amp signalling circuit is that it has almost no hysteresis, therefore it senses low battery, cuts out, comes back on, then the voltage rises slightly and the icon goes away. Then with a good bass note or even pushing a front panel button the voltage dips again and the condition repeats. So in other words, just listening, the Empeg can cut out several times a minute if the battery is sitting on the 10.5V threshold. With the divider modification it will still cut in and out multiple times but just at a lower overall voltage which will be just fine for me.
Thanks for all the help.
Nick
#278333 - 05/04/2006 14:43
[Re: farmtech]
But isn't this along the lines of getting a bigger can to bail out your leaking rowboat, instead of fixing the leak?
There should be no circumstance (except maybe when actually starting the engine) that your voltage drops much below 12 volts. You have a problem in your car's electrical system (specifically in the charging circuit) that you need to address, otherwise you are likely to find yourself stranded with not only a non-functioning empeg, but a non-functioning car.
#278334 - 05/04/2006 16:00
I agree, a battery dropping to less than 10.5V under load has lost a cell, or has a high-impedance cell. I would have thought it more practical to sort out the battery/charging circuit than operate on your empeg
#278335 - 05/04/2006 19:01
[Re: schofiel]
Or a slipping alternator belt... or a bad diode in the alternator... or a faulty voltage regulator... or worn/sticking brushes in the alternator... or low fluid [acid] in the battery... or dirty/corroded connections on the battery... or a poorly crimped battery cable... or a bad connection on the ground strap... or excessive sulfation on the battery plates... or... well, you get the idea.
Lots of things it could be, almost all of them easy to find, cheap to fix.
#278337 - 06/04/2006 02:15
[Re: Robotic]
It seems that the direct ground lead solved the player dropping out. At least that's what 10 minutes of testing shows so far. I checked the charging system voltage with the motor at various rpm- all nice and happy- so I doubt I've got any alternator or battery problems. But now the problem is that my ground-loop whine is louder than ever.  Before, I could reduce the whine by pushing on the face of the player (on the bolt heads - don't hate me). Now there is no 'wiggle solution'. Can't say why pushing used to help. I tried holding my new negative terminal lead onto the sled and empeg housing- it did alleviate the whine by about 80%. I'll have to find a screw to fit that threaded hole at the back of the sled. If I can't find a screw or that doesn't solve the whine I'll have to re-install my old head unit for entertainment on the drive. Out would come the empeg for now.  Feel my pain. Grrr.
#278338 - 06/04/2006 10:01
[Re: Robotic]
I would:
- check shield continuity on each audio channel at the sled - likewise at the amp - check the RCA leads - remove the rolloff caps in your player.
#278339 - 06/04/2006 14:47
[Re: schofiel]
Shield as in shielded wires? They're just straight up normal insulated wires. Should I shield them? Or is there some shielding on the player that you're referring to?
Quote: - check the RCA leads
I swapped in a different sled (and sled harness) but that didn't help. The RCA leads from empeg to amp are new, albeit cheap-o, as is the amp. Fiddled with all connections with no luck. The whine disappears when I remove *all* four RCA's from the amp, so the problem is definately inbetween the car, player and the amp.
Quote: - remove the rolloff caps in your player.
Gonna have to search the FAQ for that one! Thanks for the suggestions, Rob! I'll have another look tonight.
#278340 - 06/04/2006 17:33
[Re: Robotic]
Quote: The RCA leads from empeg to amp are new, albeit cheap-o, as is the amp.
RED Alert! Danger! Warning!
I would check the grounding of your amp straight away, don't bother with the rest. You should ensure a short DC ground wire, VERY heavy gauge, grounded to bare metal on the car chassis.
I'm willing to put money on you having a puny ground wire that is grounded onto paintwork.
#278341 - 06/04/2006 18:18
[Re: schofiel]
Quote: You should ensure a short DC ground wire, VERY heavy gauge, grounded to bare metal on the car chassis.
I'll change the ground to the amp. The run to the battery is only a couple of feet, so my new lead for the empeg goes directly to the battery and skips the sheet metal altogether. I'll run the amp ground in the same way. BTW, while under the hood I checked the battery terminals and cable connections for cleanliness and godliness- the factory ground strap goes to painted sheetmetal, but the threads of the nut welded to the sheetmetal are bare metal, so I guess the ground path is through the bolt/nut. I cleaned it all and gave it some grease to fight oxide build-up.
This is a very basic install- no heavy hitting speakers, so the amp is low grade; just to boost the four channels. All I have is the four stock 6" positions, the empeg, and the amp. I'm using the stock harness to connect the empeg to the car and the amp to the speakers. Even with the relative simplicity of this setup it's still the most complex I've ever put together- and the most finicky.
Once I manage to get it fitted right, it will be the most rewarding music system. More later-
#278342 - 06/04/2006 19:49
[Re: Robotic]
Good man: very similar to my setup. Got surprisingly good results from it as well: it has finally been made to sound superb (in my humble opinion, of course) by using John Graley's Auto EQ in V3A11. Worth trying when you have the install in order, but you will need a mic of course.
Don't forget (if possible) to earth the empeg at the same point as the amp, again with heavy gauge wire.
#278343 - 07/04/2006 00:58
[Re: schofiel]
Ah! It's wonderful what a good ground does!!
Thanks, Rob!
#278344 - 07/04/2006 07:58
[Re: Robotic]
So you got rid of the whine then?
#278346 - 07/04/2006 09:33
[Re: Robotic]
Glad to be of service, sir!
#278347 - 07/04/2006 09:34
[Re: schofiel]
I'm getting quite good at this, aren't I?
#278348 - 07/04/2006 17:07
[Re: schofiel]
Tony, how about a distillation of this thread for the FAQ? Or anyone fancy turning it into a Wiki article?
#278349 - 07/04/2006 17:39
[Re: schofiel]
There's a Low Battery Icon article in the FAQ already, and there's a section on ground loops in the FAQ already. Everything he did to solve the problem was already covered in both of those places, save for a few touch-ups to the low-battery icon entry that I made as a result of this thread. What specifically would you want me to write?
