#274407 - 15/01/2006 14:42
Making a drive image
I'm worried I'll lose my entire collection. Although I have it all on a PC it would just be a hassle to get it all back on the player. Is it possible to just connect my empeg's drive to a PC and make an image which I can write to a spare drive?
#274408 - 15/01/2006 15:07
Re: Making a drive image
[Re: CrackersMcCheese]
Yes. If you've got Linux that is. I've no idea how to do it using Windows. You might be able to do it with Ghost or something similar which can make an image of filesystems that aren't supported in Windows.
#274409 - 15/01/2006 15:54
[Re: tman]
Yes sorry should have mentioned I only have Windows boxes.
And would this also save playlists? Is any data stored on the player and not the drive?
#274410 - 15/01/2006 17:09
Loc: Berlin, DE
the problem is you need to copy the proprietary database partitions.. all the important information is on the drive, playlists etc.
#274411 - 15/01/2006 17:11
Loc: Berlin, DE
ah ha! On linux I would use the dd utility: http://uranus.it.swin.edu.au/~jn/linux/rawwrite/dd.htmFound a windows version, although it's not exactly point and click.
#274412 - 15/01/2006 17:29
[Re: SuperQ]
Quote: ah ha! On linux I would use the dd utility:
cat works just as well, and can be less cryptic. And I think we just discussed this EXACT same subject a day or two ago in a different thread. Backup to Windows *is* point and click (on ftp://your.empeg.ip.addr/dev/hda).
#274413 - 15/01/2006 19:08
On Windows you can also just do this, which takes a bit longer but doesn't involve special cables. It's on my to-do-list to update that FAQ entry with information about doing an entire drive image copy across the ethernet link. I might have that done later today, maybe not.
#274414 - 16/01/2006 02:20
Quote: On Windows you can also just do this, which takes a bit longer but doesn't involve special cables.
Type GET /dev/hda empeg_drive_0.bak (Enter). Wait a very long time. The larger the hard disk, the longer the wait. Expect at least 10 hours for a 30-gigabyte hard disk.
That long? So it would take more than two days to back up my 160 GB player?
#274415 - 16/01/2006 03:08
Without actually TRYING it, yeah, that's what my numbers are telling me. Since you're the one screaming so hard for the backup feature, why don't you try it and let us know?
#274416 - 16/01/2006 05:22
Even at the theoretical line speed of 10mb Ethernet a 160GB disk would take 35 hours to transfer. The empeg can probably only make half of that speed, so I would expect more like 70 hours.
If you were to do this more that once you would want to use something like rsync so that your backups were incremental.
#274417 - 16/01/2006 05:50
[Re: andy]
Quote: The empeg can probably only make half of that speed, so I would expect more like 70 hours.
That's about the speed you would expect using emplode to send songs to the player. But since we're talking about using Hijack to do a direct FTP transfer, I was hoping we'd get a bit more speed than that. I was calculating 7 megabits per second with a bit of overhead, and ballparking from there.
I'm actually curious how long it really would take, but not willing to go through it myself to find out.
#274418 - 16/01/2006 07:44
This is why yanking the drive and plugging it into a PC is still quite a good idea
#274420 - 16/01/2006 15:18
I just did a quick test of grabbing /dev/hda3 (about 30MB or so), and the transfer rate to my PC was 4.4 mbits/sec.
#274421 - 16/01/2006 17:05
#274422 - 16/01/2006 19:02
Quote: Well, darn.
Now you know why none of us have writen, tested and debugged a "one click" backup system...
#274423 - 16/01/2006 20:44
[Re: andy]
It would be a click and wait 4 days backup whilst praying that nothing crashes system
#274424 - 16/01/2006 23:15
Yeah... thinking about it I don't know why it was such a surprise to me. I know from experience how long it takes to load, say, five or six GB into the player, or for that matter how long it takes to download from the player to the PC. Last night I loaded about 9 GB into Jean's (formerly Loren's brother's) empeg, I let it run overnight so I don't know exactly how long it took, but it was probably in the vicinity of six hours or so. Sigh...  tanstaafl.
