#274092 - 11/01/2006 22:27 jEmplode No Longer Working (For me)
Gallagher419
I have used jEmplode 70 with success in the past but as of last week it no longer works for me. I have connected to my Empeg with jEmplode via USB and via Ethernet but I can no longer connect with either one. Both USB and Ethernet work with Emplode with no connectivity issues. I have tried unstalling and reinstalling jEmplode several times and I still cannot connect with jEmplode. I am running WinXP. Any help is greatly appreciated!
#274093 - 11/01/2006 22:33 Re: jEmplode No Longer Working (For me) [Re: Gallagher419]
Have any settings changed in the options?
Try unchecking "use hijack when possible" and also see if it can connect via ethernet if you feed it a direct IP address instead of broadcast.
Make certain that Ethernet works for regular emplode (i.e., with the USB cable disconnected).
Make certain that you haven't enabled the Windows Firewall or another firewall product that is specifcially blocking jemplode yet allowing emplode.
