#272941 - 29/12/2005 08:15
Reeaallllyyyy slow boot up in XP
My PC (p4 XP SP2) is just refusing to boot at the moment, it goes through every pre OS boot check OK but can spend hours at the black Windows XP loadup screen and then even more hours at the blue welcome screen without actually getting to a log in. Managed to get it to boot yesterday by doing a logged startup, but this morning nothings working, any ideas anyone?
#272942 - 29/12/2005 08:33
Re: Reeaallllyyyy slow boot up in XP
[Re: tahir]
Quote: any ideas anyone?
Disk corruption? Boot into the recovery console and run chkdsk C: /r.
#272943 - 29/12/2005 08:39
[Re: Roger]
Will do, though the one time it did boot up (yesterday) everything worked fine.
#272944 - 29/12/2005 11:02
[Re: tahir]
I had this problem - turned out something had gone weird with my usb ports. Unplugged my usb devices and rebooted. All was fine.
#272945 - 29/12/2005 11:15
[Re: CrackersMcCheese]
Quote: I had this problem - turned out something had gone weird with my usb ports. Unplugged my usb devices and rebooted. All was fine.
You know what you may have cracked it, the only change I've made to the PC is plugging in my camera, I used to use a different PC for my USB devices...
Hope thats the one.
#272946 - 29/12/2005 15:47
[Re: tahir]
If it's not the USB ports, try uninstalling the video card drivers, rebooting, then reinstalling the with latest version of the drivers. I've had XP boot up slowly in the past due to a duff video driver
Mk2a RioCar 120Gb - now sold to the owner of my old car Rio Karma - now on ebay...
#272947 - 29/12/2005 16:06
[Re: tahir]
If unplugging USB devices doesn't solve it, start searching the Windows knowledge base and googling for tips on "troubleshooting slow bootup in windows XP". There are a bunch of different diagnostic procedures you can do.
Here's the procedure I'd use in your situation...
1. Assume for the sake of diagnostics that the problem is a SINGLE service or device driver that's causing the computer to boot slowlly.
2. During bootup, press the F8 key as soon as the BIOS is done loading and the OS begins to load from the hard disk. This will give you the windows boot options screen.
3. Choose "Enable Boot Logging" and let it boot. It will start writing every driver load into a log file.
4. Because stupid microsoft doesn't put time-stamps on the lines in the boot log, you have no way of knowing which one of those lines is the slow one unless you do the following....
5. While Windows is booting, you will hear its hard drive working as it loads various things up. When it reaches the point WHERE IT IS SILENT FOR A LONG TIME because there's a failing device driver, press the computer's reset button.
6. Let Windows boot normally this time.
7. Open up c:\windows\ntbtlog.txt and find out where it died.
8. Then start trying to figure out WHY that particular thing died. Perhaps it's just something you can remove.
#272948 - 29/12/2005 16:08
Thanks, I wondered where the bootlog was...
I'm hoping its the USB though because I know somethings changed there, anything else is going to be much more troublesome.
#272949 - 29/12/2005 18:19
[Re: tahir]
Also, try and find a copy of Bootvis, which was a MS utility that times each device driver at bootup so you can see which one is holding things up
#272950 - 29/12/2005 18:27
Glad I'm not the only one to have this issue. I wonder what triggers it, as my gaming laptop no longer boots right unless any USB storage device I have is unplugged. Normally I keep a portable drive attached to it for CD images instead of taking my CDs to LAN parties.
Mine started doing it when I went to uninstall betas of .Net 2.0 for the final, and of course I blamed the betas and not the USB drive. Only by chance did I unplug the drive later andfind that was the problem, after wasting a few hours on the issue and ranting here.
#272951 - 29/12/2005 20:04
[Re: drakino]
Edited by Phil. (29/12/2005 20:05)
#272952 - 29/12/2005 20:10
Quote: I can write to it but the data is all corrupted. I'm bloody annoyed cos it was a 2gb sony one
I once had memory card problems, and it was't the memory stick. It was that the memory reader device wouldn't properly read cards larger than 128 megabytes.
Maybe there's nothing wrong wtih the card, maybe the memory stick reader built into the PC is one of the ones that won't read past 128 meg. Maybe you just need to format the card on a device that can handle the larger cards.
#272953 - 29/12/2005 20:17
Yeah, I'd find a mac and try reformatting the flash drive. Every six months a cow-orker hands me his flash drive and I reformat it in the mac mini. His windows box won't even see the thing, the mac reformats it and works in everything for the next six months.
#272954 - 29/12/2005 20:17
Tried it on 3 PCs (one of them had worked flawlessly with the stick a month ago) and still nothing. I could format, write and read existing data - a few word docs - but anything new I added just coudn't be read. It was just... strange. Can the chips just die?
#272955 - 29/12/2005 20:30
I don't know that much about whether the chips can die or not, but if you can see some semblance of a drive when it's hooked up you should be able to mess about with it in any number of drive utilities.
Haven't ever had to do so myself, but I've heard of it being done.
I just learned a whole lot from this 'flash drive roundup' article: it's 28 pages long!
(no answers there to your questions, but a good intro to the guts of flash drives for the likes of me)
#272956 - 29/12/2005 20:51
Yup, the chips can and will die. Flash memory has a limited number of write cycles. You can read it as much as you want, but you can only write to it a couple hundred thousand times. They may be up to millions these days, with inflation as it is.
#272957 - 30/12/2005 08:28
[Re: matthew_k]
Not the USB  I'll try the other stuff over the weekend
#272958 - 30/12/2005 08:43
[Re: furtive]
Quote: Also, try and find a copy of Bootvis, which was a MS utility that times each device driver at bootup so you can see which one is holding things up
Will do
#272959 - 16/01/2006 08:49
[Re: Roger]
Forgot to say, Roger was right, but by the time I figured out how to use recovery console I'd rebuilt the system anyway.
#272960 - 16/01/2006 09:12
[Re: tahir]
Loc: Yorkshire UK
Quote: Not the USB
Just a very, very long shot on this one: In another thread, I recommended to you the DigiTV Freeview, as a good source for recording radio programmes. If, on the off chance you took my advice: The current beta does something very much like this in certain circumstances, I've just cleared it out of mine.
#272961 - 16/01/2006 09:28
[Re: boxer]
Thanks Boxer, will definitely go down the Freeview route but haven't had time yet as I'll probably build a new quiet system for that.
#272962 - 16/01/2006 10:53
[Re: tahir]
Loc: Yorkshire UK
I've just added a slave unit to mine and are thinking of spending £50 on another one, you can record a bewildering number of programmes simultaneously: The manufacturers tell me that they've got 12 going at once. I have it linked to digiguide, so that I just click on a programme to record it each week. I've also got a video editing package called Videoredo (I know there are lots of these about and this is not free), which is faster and easier to use for cutting out the commercials than others I've tried.
