#271960 - 12/12/2005 00:53 Where do most people mount their amps?
burdell1
I put my last one underneath the passenger side seat, but wasn't sure if the new one will fit there...where do most people put theres?
Edited by wfaulk (16/12/2005 17:11)
#271961 - 12/12/2005 02:11 Re: Where do most people mount there amp? [Re: burdell1]
robricc
On my Isuzu Rodeo it was under the driver's seat. Saab Viggen it's in the rear hatch area. 1993 Isuzu Trooper was under the driver's seat. Subaru SVX has it in the trunk under a false floor. On my friend's two Explorers we put it under the passenger side rear bench. Another friend with a Saab 900 put it in the rear hatch area. Same thing with another friend and his Saab 9000.
I guess I/we put it wherever it fits best as far as being out of the way and still being able to access the controls go.
#271962 - 12/12/2005 07:00 Re: Where do most people mount there amp? [Re: burdell1]
Currently just have a little 640 Watt amp under the driver's seat. Easy to get at and install.
[Edit for Schido]I have a feeling the 640 is Max power output, and I only have it turned up to 2 anyway. With the empeg at -10dB it is plenty loud enough even on a motorway with the windows down and the sunroof open!
Edited by frog51 (12/12/2005 09:23)
#271963 - 12/12/2005 07:19 Re: Where do most people mount there amp? [Re: frog51]
Schido
640 watt rms?? Must be a nice heated seat too then.
#271964 - 12/12/2005 07:37 Re: Where do most people mount there amp? [Re: Schido]
Under the drivers seat, not much choice in a Smart!
My two previous cars had the amp in boot/trunk.
#271965 - 12/12/2005 08:07 Re: Where do most people mount there amp? [Re: burdell1]
After a lot of messing about, I found that it really couldn't go anywhere else.
#271966 - 12/12/2005 23:00 Re: Where do most people mount there amp? [Re: burdell1]
See attached...
#271967 - 13/12/2005 00:01 Re: Where do most people mount there amp? [Re: tanstaafl.]
/looks at picture.
It seem, then, in your case, the answer is... everywhere?
#271968 - 14/12/2005 02:24 Re: Where do most people mount there amp? [Re: burdell1]
FireFox31
Loc: East Coast, USA
Under the front seats. That's about as stealth as it can get, though it's impossible to change the settings.
FireFox31
#271969 - 14/12/2005 07:51 Re: Where do most people mount there amp? [Re: burdell1]
On the right-hand side of the boot (trunk). See this photo from Amersfoort 2005.
#271970 - 14/12/2005 09:37 Re: Where do most people mount there amp? [Re: burdell1]
cushman
Loc: Erie, CO
In the garage, or if you aren't installing it, in your installer's garage. I've seen some people do it in parking lots, too.
/obvious?
Mark Cushman
#271971 - 14/12/2005 16:53 Re: Where do most people mount there amp? [Re: cushman]
#271972 - 14/12/2005 18:18 Re: Where do most people mount there amp? [Re: cushman]
Daria
/obvious?
Only the more perverse ones. I suspect most to try mount only in the privacy of their own homes.
#271973 - 15/12/2005 01:26 Re: Where do most people mount there amp? [Re: tanstaafl.]
See attached...
How long does it take to cook a pizza in there?
#271974 - 15/12/2005 11:49 Re: Where do most people mount there amp? [Re: burdell1]
I feel your pain. I just got my new sub amp last night and it's twice as big. The old one was 9" long this one is 18". It won't fit under the rear seat. At least not as the floor pan is now .
I hate to take a hammer to my floor pan but it sure is nice to have my amps hidden.
One bit of advice. Keep the amp as close as you can to the head unit to keep noise and ground loops to a minimum.
#271975 - 15/12/2005 12:46 Re: Where do most people mount there amp? [Re: gbeer]
Remeber, we are talking about Alaska here...
#271976 - 15/12/2005 22:20 Re: Where do most people mount there amp? [Re: pgrzelak]
StigOE
And class-t amps...
Stig
#271977 - 15/12/2005 22:54 Re: Where do most people mount there amp? [Re: gbeer]
Funny you should ask...
Those are all Class-T amplifiers, and even after running continuously for five or six hours, there is nothing in there more than lukewarm to the touch. The case of my empeg is considerably hotter than any of those amplifiers ever get.
#271978 - 16/12/2005 04:37 Re: Where do most people mount there amp? [Re: tanstaafl.]
cool
#271979 - 16/12/2005 08:11 Re: Where do most people mount there amp? [Re: gbeer]
cool
Exactly.
#271980 - 16/12/2005 15:35 Re: Where do most people mount there amp? [Re: tfabris]
ninti
Loc: Los Angeles
We have two pages of posts and nobody has mentioned the problem of confusing there and their?
You people are slipping.
Mine are in the trunk. One of these days I will finish the false floor. It's on my ever-growing to-do list.
#271981 - 16/12/2005 17:10 Re: Where do most people mount there amp? [Re: ninti]
It's driving me nuts. I'm changing the initial post now so I don't have to look at it in the forum listing.
#271982 - 16/12/2005 17:16 Re: Where do most people mount there amp? [Re: wfaulk]
Thank you! Thank you!
My sig on another board used to be:
"They're not very careful with their English over there on the BBS"
#271983 - 19/12/2005 16:07 Re: Where do most people mount their amps? [Re: burdell1]
bbowman
Loc: Virginia, USA
This may seem like a stupid question, but...
I've been wondering about mounting the amp on my sub. I can understand the initial reasoning why people would avoid this, but I'm wondering if the vibrations would really cause that much trouble for the amp.
My specs:
Memphis Belle 5 channel amp (Memphis Audio)
10 inch long-throw Sub wired at 1 ohm for 1000 Watts rms
This setup provides really good vibes. Should I worry about mounting my amp on it?
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
#271984 - 19/12/2005 18:22 Re: Where do most people mount their amps? [Re: bbowman]
mtempsch
With a properly built/braced enclosure I believe you should be OK... And I imagine mounting it on a panel in the trunk would also expose it to vibrations...
Here's a link on the issue. (about 40% down the page)
#271985 - 19/12/2005 21:36 Re: Where do most people mount their amps? [Re: bbowman]
My sub amp is mounted that way, has been for a few years, no problems. Amp manufacturer is Jensen.
#271986 - 20/12/2005 16:40 Re: Where do most people mount their amps? [Re: burdell1]
Caps
Loc: Arizona, USA
I put mine under the front passenger seat. It barely fits, with about 1/2" clearance overhead. I also welded 2 one inch wide steel bars over the top so it won't get stolen if someone breaks into my car. My subs are attached to my car by locks as well.
#271987 - 20/12/2005 19:15 Re: Where do most people mount their amps? [Re: Caps]
Ezekiel
Loc: NH USA
Here's hoping the amp never breaks down then!
WWFSMD?
#271988 - 18/01/2006 12:12 Re: Where do most people mount their amps? [Re: Ezekiel]
burdell1
ok...i finally got it installed, but I asked the people who put it in (best buy) to put it underneath the passenger side seat if possible, but they put it in the trunk.....and crooked nonetheless. I think it would've fit just fine under the seat....
