#266754 - 05/10/2005 21:22 Tivo and Season Passes
Okay, so hockey is back. YAY! FINALLY!
My preferred hockey coverage is HDNET. What I want to do is tell the HD-Tivo to record all the first-run-only hockey games on HDNET.
So I go to tonight's game and hit "Season Pass", "First Run Only". You'd think, with a name like "Season Pass", the feature would be designed to work with sports. Grr.
It only sets up to record games between those exact two teams. Not all of the hockey season.
I think, possibly, it's because the names of the programs on HDNET aren't the sport, such as, "NHL Hockey", but rather, the exact team name, "Phoenix Coyotes @ Vancouver Canucks". So when I hit season pass, the team names are what it's looking for rather than the sport in general.
Aside from moving to Canada to get CBC coverage, does anyone have any ideas about how to handle this?
#266755 - 05/10/2005 21:57 Re: Tivo and Season Passes [Re: tfabris]
I can't suggest anything to work around it with TiVo other than making a bunch of manual reccuring recording entries. Or a WishList. Unfortunately, I'm not up on current TiVo versions to give much more specific help (older TiVo software didn't have wishlist capabilities that were extremely flexible.) If you can restrict a wishlist to a particular channel that would be a good start.
But I can tell you why what you're trying to do isn't working. I'm pretty positive the TiVo creates its season pass using the EPG data's ShowID. You would think that regardless of the teams playing, and therefore the possibility of alternating titles, the ShowID would remain constant if it's a regular program slot.
For instance, CBC's "Hockey Night in Canada" likely has a unique ShowID, regardless of the teams playing.
I'm running SageTV now as my full-time TV. I think even with that program I'd be stuck unless I used a specific repeating timeslot (and then it would be either once per week or every day - not ideal).
#266756 - 05/10/2005 22:04 Re: Tivo and Season Passes [Re: hybrid8]
That was going to be my suggestion, I'd say you could set up a keyword wishlist for "hockey." You'd still have to go through and manually select programs to record, but it's a step easier than scrolling through the time slots on the channel.
But thanks for alerting us! I've been interested in what hockey looks like in HD, so I'll check it out.
#266757 - 05/10/2005 23:23 Re: Tivo and Season Passes [Re: Dignan]
Waterman981
Loc: Salt Lake City, UT
You can set up keyword wishlists to record automatically. I do that for a couple of my wishlists, then about once every one or 2 weeks I examine my todo list and delete stuff I don't want. I want everything to do with U2, and get a program about the U2 spyplane... close, but not quite what I want.
-Michael
#040103696 on a shelf
#266758 - 05/10/2005 23:28 Re: Tivo and Season Passes [Re: tfabris]
SE_Sport_Driver
The closest thing I could find was a thread on Football Season Passes but skimming it looked like the same type of issue.
#266759 - 06/10/2005 00:02 Re: Tivo and Season Passes [Re: tfabris]
AndrewT
Loc: Oxford, UK
I agree that wishlists sound like your best bet here. Search www.tivocommunity.com for "advanced wishlists" and hopefully you'll be in safe hands - with advanced wishlists you can logically 'AND' multiple wishlist parameters to make a more selective wishlist.
#266760 - 06/10/2005 02:53 Re: Tivo and Season Passes [Re: Waterman981]
Oh I know you can automatically record wishlist shows, but I don't think he'd want to do that in this instance. I guess it would work either way - either you manually add each recording you want or you manually stop each recording you don't.
You're right, your way is probably easier.
#266761 - 06/10/2005 03:16 Re: Tivo and Season Passes [Re: Dignan]
Wish lists are more versatile than just looking for keywords. Filters like movies and or movies of a certain genera. I haven't looked recently but you should check the sports catagory to see if there is a Hockey filter.
#266762 - 06/10/2005 04:01 Re: Tivo and Season Passes [Re: tfabris]
matthew_k
As a ReplayTV user, I should stay out of this thread... But when have I let that stop me? Anyways, this brings up a question I've always had. Tivo users have always talked about how great season passes are, and us replay people got an equivalent a few years ago. However, I never trust it, and always reccord everything, because I'd much rather delete a rerun than miss a new episode.
Do you generally trust season passes to work properly?
#266763 - 06/10/2005 05:09 Re: Tivo and Season Passes [Re: matthew_k]
I probably shoud too, but what the heck.
Menu - Find Shows - "Team Name" - Title - "Create Theme Channel". Done.
I use that for quite a few things. My friend finds it handy for recording classic Star Trek on any channel, as he creates a theme channel to only record shows with a certain actor from the show. Since "Star Trek" on a ReplayTV would record the classic series, TNG, DS9, Voyaher and Enterprise. Replay decided not to use an exact match search in the theme channels (the closest thing I can associate to whatever a TiVO season pass is). I find they work well enough, but there is still the manual deleting of extra shows if something doesn't have a show description to key in the Replay that it is a duplicate.
#266764 - 06/10/2005 09:15 Re: Tivo and Season Passes [Re: matthew_k]
SE_Sport_Driver
[quoteDo you generally trust season passes to work properly?
The only time mine has messed up is when DirecTV messed up the program schedule. This has only happened twice that I know of. The Tonight Show started at 11:28, ended at 11:33 for some reason, resumed at 11:33 and ended at the normal time. So Tivo saw this as two runnings of the same show, not as one show that was mistakenly cut in two. Clearly DirecTV's fault. But other than that, I have it set to record only new episodes of Family Guy and South Park. So if I ever see an episode recorded, I know it's new. Works every time, especially for popular shows like that.
#266765 - 06/10/2005 11:34 Re: Tivo and Season Passes [Re: tfabris]
How would that handle nights like last night? It was the first time since the expansion era that all teams played on the same night. I suppose it would be a 'first on gets recorded' type of deal.
I haven't bothered learning much about the Tivo other than season passes so far. I guess I need to start taking a look at wishlists and see if I can get all the Coyotes games and Blackhawks games.
#266766 - 06/10/2005 11:41 Re: Tivo and Season Passes [Re: Tim]
Yes. The only time I've been burned so far is when I don't check the priority of my season passes and one of my favorite shows gets lower priority than a show I only watch when bored.
#266767 - 06/10/2005 12:18 Re: Tivo and Season Passes [Re: Tim]
Attack
Loc: Florida
I haven't bothered learning much about the Tivo other than season passes so far. I guess I need to start taking a look at wishlist and see if I can get all the Coyotes games and Blackhawks games.
TiVo's Advanced Wishlists
Enable 30 second skip on the TiVo
Sort the TiVo's Now Playing List
I don't know what version software is on the HD-TiVo and I also can't remember what version software you need to each of these TiVo hacks. I'm running three SA series 1 TiVo's running the 3.0 software. I use both the 30 second skip and the Sort hack. I've not found a use for the Advanced Wishlist since I've only made one wishlist. Sports -> Auto Racing, "World Rally" as the keyword.
#266768 - 06/10/2005 12:32 Re: Tivo and Season Passes [Re: Attack]
SE_Sport_Driver
My kind of guy!
#266769 - 06/10/2005 12:36 Re: Tivo and Season Passes [Re: Attack]
I tried some of the hacks listed a few months ago in a thread about DirecTivo, but I couldn't get any of them to work. I just assumed that it was because it was a brand new machine and different brand than what was listed. I was particularly interested in the 30 sec commercial hack.
I will take a look at the advanced wishlists. Thanks!
- Tim
Edit: Had playlist instead of wishlist. Pavlovian response for this forum I guess
Edited by Tim (06/10/2005 12:37)
#266770 - 06/10/2005 12:57 Re: Tivo and Season Passes [Re: matthew_k]
Yes. I barely use anything else, I get all the programs I want (with a few irritating exceptions) and I almost never record anything manually.
The irritating exceptions are when the DirecTV guide data isn't good enough, and that's because Tribune Media's data isn't good enough and that's because the channel doesn't provide good enough data to them. In particular, this means USA Network doesn't provide correct First-Run/Rerun information for its original shows, so I have to pay attention to when the Monk and Dead Zone seasons start and reenable the Season Pass, at which point I get the new shows and some reruns, especially when they decide to run a marathon. Comedy Central used to be this way, too (you'd get like a hundred South Parks and Daily Shows a day) but they seem to have fixed that now. (Actually, they were even worse; the TiVo couldn't even tell if it was the same episode, so it'd record the same episode a dozen times.)
#266771 - 06/10/2005 13:13 Re: Tivo and Season Passes [Re: Tim]
I'm very suprised that the 30 second skip didn't work on yours. I thought that worked on every version of Tivo by any company. It's software based, after all, so it shouldn't matter who made it. Are you certain you did it correctly? I find that the best way to do it is to play a recorded video and then enter the keystrokes, so that when you press the "3-0" it doesn't start changing the channel.
I think the ReplayTV v Tivo arguments that are starting are a little misplaced. The heart of the problem here is that the program data that is supplied to Tivo isn't what was expected or wanted, so Tony had to work around it somehow.
I know about advanced filters, I was just offering an umbrella suggestion. Your method would also work, but it would still additionally record sports shows that mentioned hockey. It's a good suggestion though, as it is narrowing the field to only sports shows that mention hockey. But who knows, maybe you want to record The Mighty Ducks 4
#266772 - 06/10/2005 13:19 Re: Tivo and Season Passes [Re: Dignan]
Actually, I think program category is a feature of the regular, non-Advanced Wishlists.
#266773 - 06/10/2005 13:44 Re: Tivo and Season Passes [Re: Dignan]
Yes. Usually, when I want to get all first-run episodes of a series, all I have to do is say Season Pass, First Run Only, and it Just Works.
In fact, the instance that I'm having trouble with, the reason I started this thread, is the only time I've had trouble doing that.
The other time, when I wanted to get all episodes of West Wing when Bravo started re-running them (and therefore they weren't first-run-only), I was pretty easily able to use the season pass feature (combined with a little fiddling of the Upcoming Episodes screen) to do what I needed.
I'm very suprised that the 30 second skip didn't work on yours. Are you certain you did it correctly? I find that the best way to do it is to play a recorded video
In my experience, that's the most common reason for the 30 second skip trick to fail. You have to make sure you're playing a recorded video from the Now Playing list before it'll work. Either that or you skipped one of the "selects" in the key sequence. The sequence, if you want to try it again, is:
- Go to the Now Playing list.
- Select and play something.
- Press: SELECT, PLAY, SELECT, 3, 0, SELECT.
If you've got sounds turned on, you should hear BONG BONG BONG at that point.
Anyway, thanks everyone for the tips. I'll follow the link to Advanced Wish Lists and see if that works for me.
#266774 - 06/10/2005 14:03 Re: Tivo and Season Passes [Re: tfabris]
Hm. According to one of those links, I can't get advanced wishlists without enabling backdoor, and I can't enable backdoor on my S2 HD DirecTivo without hardware hacking, something I'm not prepared to do right now. And even then, I'm not sure what kind of ANDs I'd be able to do that'd get me what I wanted.
Starting to sound like my only option is to print the HDNet hockey schedule and manually select the games I want to watch.
#266775 - 06/10/2005 14:04 Re: Tivo and Season Passes [Re: tfabris]
I meant to respond to that as well: yes, in every instance yes.
I've never had a single problem with this. The only problem with recording first run shows is when networks are lazy. Comedy Central is infuriating in this regard. It is impossible to record the Daily Show in this manner, because they appear to almost randomly supply information for their episodes.
#266776 - 06/10/2005 14:22 Re: Tivo and Season Passes [Re: Dignan]
I've been meaning to ask about this. I keep going into the episode list and unchecking all the episodes that aren't first-run, i.e., everything that isn't an 8pm weekday show. But one thing I've noticed is that as you get closer to the actual air time of a given show, they update the DirecTV information with the name of that night's guest. So I'm wondering if the Tivo is catching that at update-time, and if I hadn't manually fiddled with it, if it would have Done The Right Thing anyway.
Anyone know if this is the case?
#266777 - 06/10/2005 14:27 Re: Tivo and Season Passes [Re: Dignan]
matthew_k
Most everyone says yes and then goes on to qualify it to a "well, mainly". I'm NOT trying to start a Replay vs Tivo thread. As far as I know they both use the same flawed guide data. As I suspected, it sounds like I could trust them for big shows, but not for smaller shows on small networks?
#266778 - 06/10/2005 14:32 Re: Tivo and Season Passes [Re: matthew_k]
USA Network seems to be the only one with consistently flawed data. I've not personally had any problem with Comedy Central shows of late, but others might. Everything else is perfect.
The only problem I have with the TiVo about this is when there's a conflict. You can select which show is preferred, but sometimes shows change slots and you might not have set the preferences right. It'd be nice if it would prompt you when that happened so that you could verify that it was going to do the right thing or let you change it. If you're vigilant, this will never happen, but I'm certainly not that vigilant.
Edited by wfaulk (06/10/2005 14:34)
#266779 - 06/10/2005 14:34 Re: Tivo and Season Passes [Re: tfabris]
Thank both of you for the tips on that, I'll try it when I get home tonight. I never really gave it a second thought when it didn't work. I guess it is because the player is a Phillips (no clue what model) and I don't remember seeing it listed on that page of compiled hints/tips/hacks. I'll have to go back and check out it again.
Thanks again.
- Tim
#266780 - 06/10/2005 14:36 Re: Tivo and Season Passes [Re: Tim]
All of the TiVo units are actually identical regardless of manufacturer, with the exception of the Sony ones, and I don't think they've done them since S1.
#266781 - 06/10/2005 16:31 Re: Tivo and Season Passes [Re: wfaulk]
A friend of mine has a S2 TiVo and DVD player in one that doesn't even have the 30-second skip button on the remote. You can enter the code and hear the Bong Bong Bong but then you can't use the new feature. Weird, eh?
EDIT: It's the Toshiba SD-H400. Here's a pic of the remote:
#266782 - 06/10/2005 16:39 Re: Tivo and Season Passes [Re: JBjorgen]
Ah. Well, if your friend ever gets a One For All universal remote, I know the advanced function codes to assign that button.
#266783 - 06/10/2005 16:56 Re: Tivo and Season Passes [Re: JBjorgen]
Attack
Loc: Florida
Looking at that remote, I'm sure that it is the button to the right of that yellow button.
Chad
