#265582 - 20/09/2005 17:09 Windows Media Lossless
faceless041974
Loc: Chicago, IL
Just wondering if the player plays WMA's why doesnt it play when the files are encoded with the lossless setting?
#265583 - 20/09/2005 18:10 Re: Windows Media Lossless [Re: faceless041974]
The lossless codec is newer than the code used to decode WMAs. That is, WMA-Lossless is completely different than WMA-Lossy.
You can reencode your WMA-Lossless files to FLAC (in v3) or WAV and play them on the empeg with no loss in quality.
#265584 - 20/09/2005 19:16 Re: Windows Media Lossless [Re: faceless041974]
Also, please note that it only plays WMA files of 160kbps or less. This is microsoft's own supplied binary, the empeg guys didn't write that part.
#265585 - 20/09/2005 22:46 Re: Windows Media Lossless [Re: wfaulk]
faceless041974
Loc: Chicago, IL
Forgive my ignorance but what is FLAC? Also if I were to convert everything to WAV wouldnt that take up alot of room compared to WMA or MP3?
#265586 - 20/09/2005 22:51 Re: Windows Media Lossless [Re: faceless041974]
FLAC is another lossless codec that the empeg supports (but only in v3 software). Its compression is probably in the same ballpark as WMA-Lossless. Yes, WAV would take up a lot more room, as well as some other things. Go for v3 and FLAC if you can. Otherwise, just transcode your WMAs to MP3s and go with that.
#265587 - 20/09/2005 23:02 Re: Windows Media Lossless [Re: faceless041974]
Also remember that lossless codecs like FLAC or WAV mean that the car player has to keep its disk drives spun-up all the time in order to keep up with the data rate. You're much better off using a compressed format for car usage.
