#26481 - 11/02/2001 04:26
please geeks!!!
Someone hack the kernel to accept a different remote, the pioneer steering wheel one.. or something similar...THE KENWOOD SUCKS, I CAN"T TAKE it anymore :)
SOMEONE has to know how to do this.
#26482 - 11/02/2001 07:23
Re: please geeks!!!
[Re: rockstar]
Loc: Windsor, Ontario Canada
I second that too, I am not willing to give up my Pioneer remote either, but right now it's kinda useless with the Empeg until someone takes the time to figure out the hack....wish I knew Linux better, I would attempt it myself  Technoweenie
12 GB Blue / Red MK2
#26483 - 11/02/2001 08:51
Re: please geeks!!!
[Re: ineedcolor]
Wasn't there a thread recently where Frank had posted software to dump IR codes received to the console? I thought that Mark Malleck was able to use that as a starting point for something like what you're trying. Did you guys try that? ___________ Tony Fabris
#26484 - 11/02/2001 09:42
Re: please geeks!!!
I wouldn't try it myself until I have had my player awhile and get to know all of it's nuances...I will have to buckle down and get into the Linux as well, I have been stictly a Windows kinda guy to this point (with a very little of UNIX sprinkled in ha ha) John
Technoweenie
#26485 - 12/02/2001 20:09
Re: please geeks!!!
Yes, he did. And yes I tried, but none of my other remotes generated any codes on the Empeg. I tried every remote that I had, from car stereo to VCR to TV to home stereo. From Pioneer to Alpine to RCA to Hughes. Nothing bu the Empeg generated any codes. So all the remotes I have must be on a different freq.
I want a patch for this too. I am learning Linux as fast as I can. I am sure some of the others could whip up something faster though.
Proud Owner of MK2 080000558 - 18gb Blue
Sonic Blue 03 Cobra Vert Owner!!!
#26486 - 13/02/2001 06:30
Re: please geeks!!!
[Re: 94cobra]
/dev/ir won't show any codes at all that aren't totally recognised unless you put it into raw mode.
Mike - did you have that tool kicking about which (a) puts it into raw mode and (b) dumps the timings onto the screen?
#26487 - 14/02/2001 16:47
Re: please geeks!!!
[Re: altman]
#26488 - 26/04/2001 10:00
IR Keyboard
[Re: altman]
I have a IR keyboard (http://www.fentek-ind.com/wireless.htm) and wanted to play with the /dev/ir device - but I have no idea how to put it in raw mode. (cat /dev/ir shows nothing...)
bobo
29266- (147 downloads)
#26489 - 26/04/2001 10:27
Re: IR Keyboard
[Re: bobo]
Bobo, there's something about your browser that's confusing the BBS. When you post, the BBS seems to think your messages have an attachment of some kind, but it's Null.
We should notify the WWWThreads people. ___________
#26490 - 26/04/2001 11:09
Re: IR Keyboard
Loc: Berlin, DE
it's probably an auto-form complete feature of IE or something like that
12gig red mk2 -- 080000125
#26491 - 26/04/2001 11:34
Re: IR Keyboard
hmmm.... at the moment I use Konqueror - no idea what went wrong :(
#26492 - 27/04/2001 07:17
Re: IR Keyboard
[Re: bobo]
Loc: Florida
I'd like to find this out, too. I still want to remap the SRC button on my steering wheel remote, but I don't know what code it sends.
Thanks,
Jason
_~= Dearing =~_ "WAY too happy about having #99."
_~= Dearing =~_ Gettin' back into it thanks to slimrio!
#26493 - 27/04/2001 08:54
Re: IR Keyboard
[Re: Dearing]
Loc: Netherlands
here's a simple program which will show all IR-codes received.
If you start it without arguments, it is in normal mode; if you give one or more arguments, it will be in raw mode :
normal mode:
# ./trace_ir
raw mode:
# ./trace_ir raw
Frank van Gestel
29319-trace_ir.zip (30 downloads)
Frank van Gestel
#26494 - 30/04/2001 15:16
Re: IR Keyboard
[Re: fvgestel]
Loc: Florida
Frank, thanks a lot for the program. A couple questions, though: - Can I send this output to blitoutput? I need to get the codes for my SW remote and don't have a laptop handy. I'd like to just scroll each new code read to the screen so I can read it. - How do I quit from trace_ir?
TIA, JAson
#26495 - 30/04/2001 15:49
Re: IR Keyboard
[Re: Dearing]
Loc: Netherlands
Yes, though in raw mode all codes won't fit on the display
Press CTRL-C to terminate, which reminds me of the fact that if the default init isn't executed, the CTRL-C doesn't work!
if you've got a custom init, make sure to exec /sbin/[original init] at the end
You can also kill the process : kill [pid], where pid can be found in the output of command : ps
Frank van Gestel
Frank van Gestel
#26496 - 01/05/2001 07:38
Re: IR Keyboard
[Re: fvgestel]
Loc: Florida
I figured CTRL-C was it, but I couldn't get it to work over HyperTerminal. If I piped it to Blitoutput, I could run it in the background(not in raw mode) and then kill it, but if it's in the foreground and CTRL-C doesn't stop it, then what? (I had to yank the plug once, sweating bullets because I had the drives rw)
Also, any idea why I got the error from blit?
Thanks,
Jason
#26497 - 01/05/2001 08:25
Re: IR Keyboard
[Re: Dearing]
Loc: Netherlands
then you must pull the plug... look at this thread for details
As long as there hasn't been any recent writing on disk, you're pretty safe. Use emplode to synchronize and it will mark the disk as OK again.
I've rebooted a lot of times when mounted rw, without any problems (yet)...
I assume you use blitoutput, which uses the front-panel buttons to scroll through the text, so it is trying to access /dev/ir, which is used by ir_dump.
Try blitecho instead:
ir_dump | while read CODE
do
echo $CODE | blitecho
done
Frank van Gestel
Frank van Gestel
#26498 - 03/05/2001 07:02
Re: IR Keyboard
[Re: fvgestel]
Loc: Florida
Sorry for all the confusion. I got the new init to work, and I'm trying to put the IR-code to the display, but I can't find ir_dump. Is it different from trace_ir?
Thanks,
Jason
#26499 - 03/05/2001 07:25
Re: IR Keyboard
[Re: Dearing]
Loc: Netherlands
ir_dump = trace_ir. I just forgot how I named it...  Frank van Gestel
Frank van Gestel
#26500 - 03/05/2001 07:41
Re: IR Keyboard
[Re: fvgestel]
Loc: Florida
I was afraid of that, 'cuz that means something else is wrong. I've attached the script file I made from your posted code, irlog. It still outputs to stdout, and nothing to the display. Any ideas?
Thanks again, Jason
29653-irlog (189 downloads)
#26501 - 03/05/2001 08:14
Re: IR Keyboard
[Re: Dearing]
Loc: Netherlands
My fault; It is sending out to STDERR instead of STDOUT.
So the following should work :
trace_ir 2>&1 | while read CODE
do
echo "$CODE" | blitecho
done
maybe you should also put some waiting time in the loop, to let the codes scroll slowly. Unfortunately sleep isn't available in the default dev-image, but I think I saw it in another thread. Frank van Gestel
Frank van Gestel
#26502 - 03/05/2001 13:59
Re: IR Keyboard
[Re: fvgestel]
Loc: Florida
Thanks for the fix. I'd have been lost otherwise.
Speaking of being lost...I can now get the ilog script to run and send IR-codes to the display, but only if I 'q' at the terminal and start irlog that way. When picker tries to start it, it doesn't do anything. I've attached my pick_list file, if that helps.
Thanks,
Jason
29690-pick_list (196 downloads)
#26503 - 03/05/2001 15:11
Re: IR Keyboard
[Re: Dearing]
Loc: Netherlands
blitecho expects the file ascii.raw in the directory it is being executed, maybe that's causing the problem?
Frank van Gestel
Frank van Gestel
#26504 - 14/05/2001 05:28
Re: please geeks!!!
[Re: rockstar]
what about hacking into the IR support for the latest Sony wireless remote. Looks pretty cool and would be easyish to plug in the commands in the IR dev? No?
go here and get the demo on the remote Murray 06000047
I don't think, therefore I am not.
Murray
Is it the 'N', or the 'Zero'?
#26505 - 23/05/2001 07:55
Late follow-up for Steering Wheel Remote Remap
[Re: Dearing]
Loc: Florida
Just to let you all know, I got the remapping to work great on my Mk1. If anyone else has the steering wheel remote, here are the IR codes:
DEC,HEX,FUNCTION
47380,0000B914,Vol-
47381,0000B915,Vol+
47371,0000B90B,Track+
47370,0000B90A,Track-
47373,0000B90D,FF
47372,0000B90C,Rev
47382,0000B916,ATT
47379,0000B913,SRC
Thanks again, Frank, for all your help!
Jason
